[Solved] Dualshock 4 Charging Issue: No Orange Glow, Works via Bluetooth, PS4 Used Pad
dyziuleniek 19698 5
  • #1 17697587
    dyziuleniek
    Hello. I recently bought a used pad for ps4 but it turned out to be a problem with charging. No sign after plugging in the cable. I managed to pair it via bluetooth and it works fine. No burn marks or anything on the board. Help What could be wrong?
  • #2 17697808
    2konrafal1993
    Help: 581
    Rate: 746
    It's hard to say because it can be for many reasons, from a problem with the socket to even a problem with the cell or electronics. First check the socket and cable, then you have to fly on, a multimeter and a soldering iron are required, as well as skills in operating these devices.
  • #3 17699700
    xbox-serwis.eu
    Help: 52
    Rate: 210
    Often when the voltage on the bat drops below 3.3V, the charging will not start, just "kick" the bat, of course not literally :)
    XBOX-SERWIS.EU
    Karmelicka 15, Kraków, 31-131 | Company Website: http://www.xbox-serwis.eu
  • #4 17715730
    dyziuleniek
    Okay, but I connected the batteries from a working pad and it didn't want to charge either
  • #5 17717808
    xbox-serwis.eu
    Help: 52
    Rate: 210
    The connector with the tape and shipping costs about PLN 20, just pay attention to order a good one, it's best to check the symbol on the micro USB board.
    XBOX-SERWIS.EU
  • #6 18832460
    dyziuleniek
    Damaged power board.
