Upgrading to RX5700 + Ryzen 5 3600: Will My Current 500W PSU Handle It or Need Replacement?
Mateos972 7611 4
  • #1 18194942
    Mateos972
    Hello, I currently have such a computer set:
    Processor: Intel Core i7-4770K, 3.5GHz
    Cooling: CPU cooler SilentiumPC Fera 3 HE1224 v2
    RAM: HyperX, DDR3, 8 GB, 1600MHz, CL10 (HX316C10F / 8)
    Motherboard: ASROCK Fatal1ty Z97 Killer
    PSU: be quiet! Power 9 500W system
    Hard disk: Seagate Desktop HDD 1TB [ST1000DM003]
    SSD: Crucial BX500 240GB
    Graphic Card: Zotac GeForce GTX 1060 AMP! 6GB GDDR5
    Housing: SilentiumPC Regnum RG4T Pure Black
    In some time I plan to buy Sapphire Radeon RX 5700 PULSE and Ryzena 5 3600 (same motherboard and ram). I mean the power supply. I'm not sure, but probably the current one will not pull such a set?
    If it does not pull, which power supply to go to? I found 2, but I do not know if there will be something better at this price and which one is better to choose (from these two, if there is no other better equivalent).
    I will add that I will rather buy the processor later, so for now I would work with the i7 + RX 5700 - that's why I ask, is there any point in replacing this power supply now? Or only when I replace the frames, plate and prock.
    https://www.x-kom.pl/p/364864-zasilacz-do-kom...-silentiumpc-vero-m2-600w-80-plus-bronze.html
    https://www.x-kom.pl/p/308095-zasilacz-do-kom...silentiumpc-supremo-l2-550w-80-plus-gold.html
  • #3 18195022
    badboy84
    Help: 1198
    Rate: 1487
    Don't trade better for the worse, leave what you have.
  • Asking if 500W PSU can handle RTX 2070 Super
    #4 18212847
    Mateos972
    Currently, my set is presented like this:
    CPU: AMD Ryzen 5 3600
    Cooling: SilentiumPC Fera 3 HE1224 v2
    RAM: Adata XPG Gammix D10 DDR4 16GB 3000 CL16
    Motherboard: MSI B450-A PRO MAX
    Power Supply: be quiet! Power 9 500W system
    Hard drive: Seagate Desktop HDD 1TB [ST1000DM003]
    SSD drive: Crucial BX500 240GB
    Graphics Card: Zotac GeForce GTX 1060 AMP! 6GB GDDR5
    Case: SilentiumPC Regnum RG4T Pure Black
    In a few days I will change my graphics card from GTX 1060 to RTX 2070 Super Ventus OC.
    Are you sure my power supply will hold it? However, do you buy with more power?
  • #5 18213008
    sosarek
    Help: 9320
    Rate: 15541
    It will stand up to a difference in the performance of miracle cards you do not expect.
    Z
    Pka, Poznań, 60-850
