Black list of power supplies and reputable brands of power supplies
1qaaz 1356 6
  • #1 21315185
    1qaaz
    Rate: 13
    Hi. I have a choice between: be quiet! System Power 10 550W or corsair CX650M?
  • #2 21315192
    badboy84
    Help: 1197
    Rate: 1485
    Then set up your topic. Give the specifications then someone will probably address it.
  • #3 21315239
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8290
    I've separated into a separate topic so you don't need to create a new one, however the question from colleague @badboy84 is absolutely right - in order to be able to choose a PSU you need to know what it will power. If it doesn't necessarily have to be one of these then also state the maximum budget you can spend on buying this PSU.
  • #4 21318789
    1qaaz
    Rate: 13
    I have the opportunity to purchase these power supplies at a good price and I don't know which one will be more future proof and "better" in general Powering a "universal" computer. On board i5 8600, gtx 1050ti, gigabyte B360M D3H board, 32Gb RAM. 512 GB SSD M.2 NVMe drive. Currently a 350W 80 bronze power supply
  • #5 21318794
    dt1
    Help: 7315
    Rate: 8290
    The CX650m should be better, unless it's a very old version. The SP10 is a step backwards from the previous SP9 version. The current 350 sufficient also.
  • #6 21318809
    badboy84
    Help: 1197
    Rate: 1485
    What exact model of power supply do you have?
    The CX650M is a design that could be about 8 years old, so even for a power supply it's already quite old.
    Is there any proof of purchase or warranty for it?
    System Power is again a budget series from this manufacturer and question as above.
    It depends on what budget you are looking for a PSU in.
  • Recommend a proven mid-range PSU for future GPU upgrade
    #7 21323539
    1qaaz
    Rate: 13
    The power supplies are from the stock of a friend of my friend. The CX650, is an unused PSU but has been in the box for 5-6 years, the be quiet! is bought some time ago but also unused. Now I have in this computer a power supply bought together with the case. It is a POWER LC420-12 V2.31 office series 80 plus bronze. Due to the fact that this computer is intended for everyday use with the option of multimedia and simple games, I do not want to invest in some monster "gigawatt" power supply, but rather in a proven, stable reliable model, with the possibility of upgrading the computer with some current mid-range graphics card.
The discussion revolves around choosing between two power supplies: be quiet! System Power 10 550W and Corsair CX650M. The user seeks a reliable and future-proof option for a general-purpose computer with an Intel i5 8600, GTX 1050 Ti, and 32GB RAM. Responses highlight that the Corsair CX650M is generally considered superior, although it is an older design. The be quiet! System Power 10 is noted as a budget option, and the current 350W power supply is deemed sufficient for the user's needs. The user prefers a stable model for everyday use and potential upgrades without overspending on high-capacity units.
