Connecting Vaillant VRT330 Room Temperature Controller to Junkers Ceraclass ZW-24 Boiler
Nephets 1611 1
  • #1 18216633
    Nephets
    Hi, is it possible to connect Vaillant VRT 330 OOM temp. controller to Junkers Ceraclass ZW-24 boiler
  • #2 18418205
    Shark.93
    Nephets wrote:
    Hi, is it possible to connect vaillant Vrt 330 oom temp. controller to junkers ceraclass ZW-24 boiler
    Hello Nephets, you should check the vaillant datasheet. In any way that type of boiler can be connected to a controller, check the datasheet at point 6.2.
    • ZWA-24-2-AE.pdf (2.02 MB) You must be logged in to download this attachment.
