Canon PIXMA MG5750 Wi-Fi Printing Issue - New Printer, Drivers Installed, USB Works Fine
siodemeczka77 8877 7
  • #1 17130256
    siodemeczka77
    As the topic. The printer prints without any problem via a USB cable, and cannot connect via wi-fi with a laptop and smartphone. What could be the fault? I will add that this is a brand new printer (bought a month ago) and the drivers are installed from the manufacturer and not downloaded from the net. From the moment I bought it, I printed once for testing (right after starting it) and everything was well installed. Please help.
  • #3 17131113
  • #4 17131134
    siodemeczka77
    Forkas - using a router.
    Lokis3 - I have downloaded my printer and it did not show any errors in the drivers.
  • #5 17131682
  • #6 17132137
    siodemeczka77
    forkas, please tell me (because I'm a layman in these matters) how to configure a printer using a router? I found this instruction on the web:
    https://www.canon.pl/support/consumer_product...tup/mg7550_printer_wireless_connection_setup/
    Going to step 3, I wonder what to choose: configuration without using a cable (as in the instructions on the website) or using WPS ???
    And one more question. After selecting the appropriate option, will
    The blue Wi-Fi indicator lights up when the wireless connection option is enabled "(as in the manual says) this indicator should light up on the router?
  • #8 17141247
    siodemeczka77
    Thanks for the help. Managed to :)
The discussion revolves around a Canon PIXMA MG5750 printer that successfully prints via USB but fails to connect via Wi-Fi to a laptop and smartphone. The user confirmed that the printer is new, with drivers installed directly from the manufacturer. Suggestions included downloading the "My Printer" software from Canon's website and configuring the printer's Wi-Fi connection using the WPS button on the router. The user sought clarification on the setup process and ultimately succeeded in establishing the wireless connection.
