[Solved] How much does a 400V installation cost in a 75m2 workshop? I'm looking for an electrician.
16323 12
How much does it cost to install 400V power in a 75 m² workshop, and who should I contact to do it legally?
You need to contact a licensed electrician with the proper papers, not ENEA, because he should assess the required power, check the existing supply cable, and design the installation; if the current connection is too weak, an application for new supply conditions must be filed with the power utility [#18241118][#18243265] For a workshop expected to run two 350A welders, one reply estimated the needed power at about 20 kW [#18241155] If the workshop is or will become a legal business, it should have a separate meter and a C tariff [#18241236] One rough cost hint given in the thread was about PLN 5 per meter for cable plus about PLN 800 for switchboards, plus labor [#18243220] Because the workshop is only about 15 m from the house, running the supply from the house with YAKY cable was suggested as the more economical option, even if the power allocation has to be increased [#18241269]
  • #1 18241105
  • #2 18241118
    brofran
    Help: 650
    Rate: 1408
    First, you need to find out what power you need and what power cable you have at your disposal.
    If the power is too low, an application to the Power Industry for new power supply conditions is submitted. :cry:
  • #3 18241140
  • #4 18241155
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    First of all, will the garage draw electricity from the house or will it have a separate connection with a separate meter?
    Estimated about 20kW. Is Kro your electricity supplier?
  • #5 18241207
  • #6 18241236
    vodiczka
    Help: 1185
    Rate: 4311
    TomaszNZM wrote:
    for now, the garage draws electricity from the house 230v, and the electricity is 400v. I really don`t know whether to do it with a separate meter or from the house because I really don`t know which option is more profitable and whether it makes any difference at all.
    Does the house have a three-phase or single-phase power supply?
    TomaszNZM wrote:
    It is not a large workshop, it has 75 m2
    It`s not small either.
    TomaszNZM wrote:
    I`m not alone there, so one welder won`t be working, but two
    If this workshop is a legal business, you must have a separate meter and a C tariff (unfortunately more expensive than G) to make it legal.
  • #7 18241269
    Help: 1405
    Rate: 6430
    TomaszNZM wrote:
    400v electricity, I really don`t know whether to do it with a separate meter or from home
    It is profitable to buy YAKY and sip from home. Even at the cost of increasing power allocation.
  • #8 18241311
    opornik7
    Electrician specialist
    Help: 316
    Rate: 1571
    only if
  • #9 18243200
  • #10 18243220
    Help: 1405
    Rate: 6430
    The cable itself costs PLN 5/m and the switchboards cost approximately PLN 800 + labor.
  • #11 18243246
  • #12 18243265
    opornik7
    Help: 316
    Rate: 1571
    TomaszNZM wrote:
    And who should I contact? For example, "ENEA" will perform such an installation for me?
    NO. You need to look for an electrician with the appropriate papers and talk to him.
  • #13 18244933
The discussion revolves around the cost and requirements for installing a 400V electrical system in a 75m2 workshop to accommodate two 350A welding machines. The user currently has a 230V installation and is considering whether to connect the new system to the house or have a separate meter. Key considerations include the need for a three-phase power supply, legal compliance for business use, and the estimated costs for materials and labor. Responses suggest contacting a qualified electrician rather than the electricity supplier for installation. Estimated costs include PLN 5/m for cable and approximately PLN 800 for switchboards, with labor costs additional.
TL;DR: For two 350A welders in a 75 m² workshop, plan ~20 kW; "Estimated about 20kW." Budget for cabling, a switchboard, and verify your power allocation before buying gear. [Elektroda, Strumien swiadomosci swia, post #18241155]
Why it matters: This FAQ helps workshop owners planning 400V for welders understand realistic costs, power allocation, and who to hire to stay compliant.
How much will a 400V installation cost for my 75 mb2 workshop?
Expect budget items, not a final price. Cable runs are about PLN 5 per meter. A simple workshop switchboard is around PLN 800. Labor and protection selection add significantly. The final price depends on distance, ground works, and socket count. Get a site quote from a licensed electrician. [Elektroda, Strumien swiadomosci swia, post #18243220]
Do I need to apply to ENEA to increase power before adding 400V?
Start by confirming required load and your current allocation. "First, you need to find out what power you need." If your allocation is too low, submit an application to the utility for new supply conditions. Do this before buying equipment. It prevents delays and redesigns. [Elektroda, brofran, post #18241118]
Will ENEA install the sockets and wiring, or do I hire someone?
The utility does not install internal workshop wiring. Hire an electrician with the appropriate qualifications and insurance. Discuss scope, load, socket types, and documentation. Ask for a written quote and completion date. The electrician will also handle tests and as-built diagrams. [Elektroda, opornik7, post #18243265]
Is 20 kW enough to weld with two 350A machines?
One forum assessment puts the requirement at about 20 kW for your scenario. Actual need depends on duty cycle, simultaneous welding, and other tools. Oversize slightly to avoid nuisance trips. Confirm the allocation with your supplier and electrician. Adjust plans if the allocation is below this figure. [Elektroda, Strumien swiadomosci swia, post #18241155]
Should I install a separate meter now, or can I feed the workshop from my house?
For private, non-business use, feeding from the house is acceptable. If the workshop becomes a legal business, install a separate meter and move to tariff C. Tariff C is more expensive than tariff G. Plan this change if you expect to register a business later. [Elektroda, vodiczka, post #18241236]
Is it cheaper to run power from my house to the workshop with YAKY cable?
Yes, running a YAKY cable from the house is often economical. This holds even if you must increase your allocated power. Place the cable appropriately and size it for the load. Your electrician will specify the cross-section and route. This was described as profitable versus a separate connection. [Elektroda, Strumien swiadomosci swia, post #18241269]
My workshop is 15 m from the house. What would the cable and board cost?
At PLN 5 per meter, a 15 m run costs about PLN 75 for the cable. A basic workshop switchboard is around PLN 800. Labor, trenching, and protection selection are extra. Ask for an all-in quote to avoid surprises. Keep a contingency for unforeseen groundwork issues. [Elektroda, Strumien swiadomosci swia, post #18243220]
Can a 230V-only setup handle a 350A MIG welder?
Your current 230V setup did not meet your welding needs. That is why you plan a 400V welder. Choose equipment that matches your planned 400V installation. Share the welder plate with your electrician for sizing. [Elektroda, TomaszNZM, post #18241105]
My house already has three-phase. Does that help?
Yes. In this case, the house already has a three-phase installation. That supports adding 400V circuits in the workshop. Confirm details with your electrician. Extend from the main board to the workshop as designed. [Elektroda, TomaszNZM, post #18243200]
Who sizes the sockets, wire, and protection for welders?
Your licensed electrician does. They will select socket ratings, protection devices, and cable cross-sections. Provide welder specifications and planned simultaneous use. Request documentation and test results after installation. Keep these for future inspections or upgrades. [Elektroda, opornik7, post #18243265]
What are the first steps to get 400V into my workshop?
Follow this simple path:
  1. Define your load and confirm your current allocation with the supplier.
  2. Hire a licensed electrician to design and quote the job.
  3. Install, test, and document the switchboard, cable, and sockets. "You need to look for an electrician with the appropriate papers and talk to him." [Elektroda, opornik7, post #18243265]
What happens if I try to run two welders on too little power?
Insufficient allocation can halt work and disrupt welding. If available power is too low, submit an application for new supply conditions. Do this before installing expensive gear. It prevents rework and protects your tools. Plan headroom for other workshop loads too. [Elektroda, brofran, post #18241118]
How many 400V sockets should I plan for?
The thread scenario needs three or four 400V sockets. Match socket ratings to your welders and other tools. Group sockets on appropriate circuits as designed by your electrician. Extra spare capacity often pays off later. [Elektroda, TomaszNZM, post #18241105]
