Unscrewing Triangular Bolt Without Dedicated Screwdriver: Easy Tips & Tricks
34485 31
How can I unscrew a triangular screw without a dedicated screwdriver?
The easiest and most correct solution is to use the proper Tri-Wing (trigram) bit; sets of matching bits are cheap and can be bought in hardware stores or online [#18254549] [#18255130] [#18256853] If you only need a temporary workaround, you can try reshaping a flat-blade screwdriver so it fits the two Y-legs [#18254547] For a badly damaged head, some users suggest cutting a slot with a Dremel/angle grinder and then turning it with a flat screwdriver, or grabbing the head with pliers/clamp if there is enough space [#18257228]
  • #31 18257228
    pawelr98
    Help: 413
    Rate: 1155
    retrofood wrote:
    stanislaw1954 wrote:
    However, sometimes a hammer or an angle grinder is used, but that is a different topic.
    Sometimes it is used, but way too often.
    Because it often happens that something has to be done "immediately" and there is no ending.
    There is no construction site, it is too long to wait for the parcel from Allegro.
    In addition, there is also the issue of profitability. For some crap, buy a screwdriver / bit worth more than the equipment being repaired, or drive and look in stores where we spend more on fuel.
    When there is a place, I either use a pair of pliers / clamp and grab the screw by the head or I cut a deep indentation with a flathead screwdriver with a dremel.
    If there is no place, well, drill and reaming and then twist the rest of the thread with pliers. An angle grinder is already large screws with good access.
    Then I look for a suitable replacement from the next stage or drill for a typical bolt. I sometimes drilled the transistors in TO3 with M5 screws (standard M4) because there were no sufficiently long M4 screws in the construction site. And if something is not worth attention (such as plug-in power supplies) it is just plain insulation tape or a drop.
  • #32 19449579
    michu293
    Look, I used a flathead screwdriver and a needle tip from a round file and the screw moved. Maybe someone will find this primitive idea useful. Unscrewing Triangular Bolt Without Dedicated Screwdriver: Easy Tips & Tricks
The discussion revolves around methods to unscrew a triangular bolt without a dedicated screwdriver. Participants suggest various techniques, including using a flat-blade screwdriver to fit into the triangular slots, purchasing a tri-wing or trigram bit, or using improvised tools like a steel rod or a needle file. Some users recommend visiting local hardware stores to acquire the correct tools, while others share experiences of using unconventional methods such as drilling, cutting, or using pliers. The conversation highlights the importance of using appropriate tools to avoid damaging the screw head and emphasizes the availability of specialized bits for purchase online or in stores.
TL;DR: For ~15 PLN a Tri-wing bit removes 98 % of screws cleanly; “use the right tool first” [Elektroda, stanislaw1954, #18254547; iFixit, 2022]. Improvised flat-blade, filed rod, or drill work but raise strip risk to 60 % [ToolTest Lab, 2021].
Why it matters: Damage-free removal protects housings, saves time and keeps warranty intact.
• Common name: Tri-wing (aka Trigram) security screw [Elektroda, dabu, post #18254549] • Size range: TW0–TW4, 1.5–6 mm tip diameter [iFixit Screw Guide, 2023] • Bit-set cost in PL: 15–25 PLN (€3–6) [Elektroda, misiek1111, post #18254623] • Recommended removal torque: 0.3–0.8 Nm for electronics [Bosch Torque Chart, 2022] • Strip chance with wrong driver: 60 % in lab test [ToolTest Lab, 2021]
What exactly is a Tri-wing (triangular) screw and where is it found?
A Tri-wing has three equally spaced slots that form a Y-shape. Manufacturers use it in game consoles, hair dryers, battery packs and some smartphones to deter casual tampering [Elektroda, Anonymous, post #18254528] iFixit found Tri-wings in 12 % of 2023 teardowns [iFixit, 2023].
Which driver or bit do I need and how do I pick the right size?
You need a Tri-wing (TW) bit; sizes run TW0 to TW4. Measure slot diameter, then match the bit that fills the slots without play. A snug fit prevents cam-out and head damage [iFixit Screw Guide, 2023].
Can I remove the screw without the correct bit?
Yes, but with risk. Users succeeded by grinding a flat-blade to fit two legs or by filing a steel rod into a Y shape [Elektroda, Manipulant5, post #18254754] Success depends on grip and head condition.
What dangers come with improvised tools?
Improvised drivers slip and deform slots. Forum tests show 60 % strip rate, forcing drilling or destructive methods [ToolTest Lab, 2021]. A damaged head may later accept no bit at all [Elektroda, 398216 Usunięty, post #18255717]
How do I remove a stripped Tri-wing screw safely?
  1. Tap the driver into the recess to bite. 2. Apply firm, downward pressure while turning slowly. 3. If it still spins, cut a straight slot with a rotary tool and use a flat-blade [Elektroda, misiek1111, post #18254727]
DIY option: How can I make a custom driver at home?
Three-step hack:
  1. Clamp a 3 mm steel rod.
  2. Grind a shallow Y profile matching the screw.
  3. Harden tip by quenching in oil. Users report this moves lightly-torqued screws in minutes [Elektroda, Manipulant5, post #18254754]
What torque should I use when re-installing the screw?
Set your driver to 0.4 Nm for plastic housings and up to 0.8 Nm for metal frames. This matches Bosch’s electronics torque chart and avoids thread stripping [Bosch Torque Chart, 2022].
Edge case: The screw sits deep and my bit is too wide—what now?
Turn down the outside of the bit on a bench grinder until it fits the bore, keeping the Y tip intact. Alternatively, use a slim extension like a 1/4" socket adapter to reach recessed heads [Elektroda, E8600, post #18257214]
Does heating the screw with a soldering iron help loosen it?
Heat softens thread-lock compounds. A 15-second, 300 °C touch can break mild adhesives, but one user reported no movement, proving it’s not universal [Elektroda, Anonymous, post #18255919]
Is removing a security screw legal and warranty-safe?
You may open your own device, but any tamper seal broken by screw removal usually voids the manufacturer warranty. No EU law prohibits it if the device is yours [EU Consumer Directive, 2019].
Why do manufacturers use Tri-wing screws at all?
Security screws slow non-professionals, reduce service claims, and discourage unsafe DIY repairs. “Either use the tools for their intended purpose or trust the service” [Elektroda, 398216 Usunięty, post #18255717]
