Zgemma H9.2S CCcam Stuttering Issue After Moving from Poland to Germany
Ariel N. 10944 14
  • #1 18301488
    Ariel N.
    Rate: 62
    I have a Zgemma H9.2S on CCcam in Poland, it worked without any problems. After leaving for Germany, I have a problem, it stutters every now and then.
    I tried to share the net from the phone and the same. What could be the reason? Installing on another card decoder worked earlier.
    Moderated By simhak:
    3.1.1. Do not share illegal material or other information that violates the law.
  • #2 18301512
    kameleon11116
    Help: 72
    Rate: 129
    You have checked the quality and strength of the signal :!: :?: The problem doesn't have to be the cam and the internet.
    Regards
  • #3 18301527
    Ariel N.
    Rate: 62
    Quality and strength 61% and 78%, the previous decoder was ok. TVPinfo not encoded, no cuts.
  • #4 18301531
  • #5 18301539
    kameleon11116
    Help: 72
    Rate: 129
    These percentages are not too much, and the fact that TVPinfo is not pruned is not a determinant :idea: it's government TV :D :D :D and has great puncture power.
    Regards
    DiZMar
    Help: 2894
    Rate: 6658
    ucy7400 wrote:
    Why are you asking here and not at the key provider.
    For similar advice I got an indefinite warning that will hang on my account until the end of the world and one day longer.
  • #7 18301549
    Ariel N.
    Rate: 62
    kameleon11116 wrote:
    These percentages are not too much, and the fact that TVPinfo is not pruned is not a determinant :idea: it's government TV :D :D :D .
    Regards
    I know not too much. However, the previous decoder with the card flickered.
  • #8 18301552
    kameleon11116
    Help: 72
    Rate: 129
    Regards
    Check on another decoder from cam.
  • #10 18301556
    DiZMar
    Help: 2894
    Rate: 6658
    ucy7400 wrote:
    It's piracy. where he bought, let him ask.
    The whole topic should end up in the trash.
    To view the material on this forum you must be logged in.
  • #11 18301557
    Ariel N.
    Rate: 62
    on your farm you can share the card from what I know
  • #12 18301569
  • #13 18301589
    Ariel N.
    Rate: 62
    Yes, it works and that's why I assumed the topic that it cuts.
  • #14 18302105
    LeDy
    Help: 1992
    Rate: 2942
    Ariel N. wrote:
    I have a Zgemma H9.2S on CCcam in Poland it worked without any problems.
    I also received a warning for something like that, but maybe it's not piracy anymore? Maybe only the donor is a pirate or the rules have changed on the electrode?
  • #15 18302232
The user reports issues with their Zgemma H9.2S satellite receiver running on CCcam in Germany, experiencing stuttering every minute for about 10 seconds. Despite previously functioning well in Poland, the user has tried sharing internet from their phone without improvement. Responses suggest checking signal quality and strength, which are reported at 61% and 78%, respectively. Some participants question the legality of the setup and recommend consulting the key provider or testing with another decoder. The discussion highlights concerns about potential piracy and the reliability of the current setup.
TL;DR: Zgemma H9.2S stutter after moving? Reported 61% quality/78% strength and “TVPinfo not encoded, no cuts.” Use the checks below to isolate the cause. [Elektroda, Ariel N., post #18301527]
Why it matters: This helps Zgemma users quickly pinpoint stutter causes after relocation without chasing the wrong fix.
Why did my Zgemma H9.2S start stuttering after moving from Poland to Germany?
Relocation can change dish alignment, LNB skew, and cable runs, reducing margin. A helper noted, “The problem doesn’t have to be the cam and the internet.” Start by checking signal quality and strength on problem channels before changing software. [Elektroda, kameleon11116, post #18301512]
What do 61% quality and 78% strength tell me about stability?
One user measured 61% quality and 78% strength and reported stuttering. Those readings suggest limited headroom on some transponders. Treat them as a diagnostic clue to improve alignment or connections before suspecting softcam issues. [Elektroda, Ariel N., post #18301527]
Does using a phone hotspot rule out ISP problems?
Not entirely, but it’s a strong clue. The user tried sharing internet from a phone and saw identical stutter. That tends to shift focus away from the ISP and toward satellite signal or hardware. [Elektroda, Ariel N., post #18301488]
Why do free‑to‑air channels like TVP Info play fine while others stutter?
Edge case: the user reported TVP Info (FTA) had no cuts while others did. That observation narrows the issue to channels other than TVP Info and suggests you should recheck signal margin on affected transponders. [Elektroda, Ariel N., post #18301527]
Should I ask my CCcam/key provider or the forum when it stutters?
A participant suggested asking the key provider. If your access depends on a donor, they can verify their side. Always comply with local law and your service terms when contacting any provider. [Elektroda, Anonymous, post #18301531]
Is card sharing legal to discuss here?
A moderator note states not to share illegal material or information that violates the law. Keep discussion within legal bounds and avoid sharing keys or illicit access details. [Elektroda, Ariel N., post #18301488]
Will switching to another receiver help diagnose the issue?
Yes. A helper advised checking on another decoder. Swapping to a known‑good box helps you isolate whether the receiver or the installation is responsible for stutter. [Elektroda, kameleon11116, post #18301555]
My cameleon card still works—why am I still getting stutter?
The user confirmed the card still works, yet stutter persists. That points away from the card itself. Revisit alignment, LNB skew, cabling, and connectors to restore signal headroom. [Elektroda, Ariel N., post #18301589]
How do I quickly isolate signal versus receiver problems?
Use this 3‑step check:
  1. Open the signal meter on problem channels and note quality/strength.
  2. Slightly adjust dish and LNB skew to maximize readings.
  3. Inspect and reseat connectors and coax, then recheck metrics. “You have checked the quality and strength of the signal?” [Elektroda, kameleon11116, post #18301512]
Are my signal percentages too low for stable viewing?
A helper replied, “These percentages are not too much.” That implies your margin is weak. Improving dish alignment and fixing any cable or connector loss can stabilize playback. [Elektroda, kameleon11116, post #18301539]
Another decoder with a card worked before—what changed after the move?
The user noted another card decoder worked earlier. After moving, the dish pointing, run length, or environment may differ. Reassess the antenna system first to restore stability. [Elektroda, Ariel N., post #18301488]
Do users really get moderation warnings for CCcam mentions?
Yes. One member reported receiving a warning for similar mentions. Follow forum rules and keep any troubleshooting within legal and ethical guidelines. [Elektroda, LeDy, post #18302105]
