[Solved] Zgemma h9s Enigma2, changed the OpenAtv software to OpenPli 8.6
expol1 79527 26
Can I replace OpenATV on a Zgemma H9S with OpenPLi, and is it flashed the same way from USB?
Yes—on the Zgemma H9S you install OpenPLi by flashing the correct H9.S image from a USB pendrive, just like any other image install [#18087752] The thread points to an OpenPLi download for this box and notes the cited build as OpenPLi v7.1 for H9.S, so you need the image that matches your exact model [#18087752] Before changing software, make an OpenATV backup so you can restore your settings and channel list later [#18088109][#18089442] Because the receiver has only 256 MB of flash, keep extra data such as picons, EPG, or recordings on USB or microSD instead of relying on internal flash [#18088109][#18091470]
  • #1 18087685
    expol1
    Rate: 53
    I warmly welcome.
    I would like to ask you about the possibility of changing the software to OpenPli. I like this soft more.
    I wanted to ask: if I already have OpenApi installed, it installs OpenApi in the same way as when reinstalling OpenApi. ? will this edition of OpenPli work in Zgemma with Enigma2?
    Thank you very much for the reply.
  • #2 18087752
    internick
    Level 36  
    Help: 273
    Rate: 555
    You upload the image normally from the pendrive.
    Here you have OpenPLi v7.1: https://openpli.org/download/zgemma/H9.S
    And here is a collection of all images for this tuner: https://www.sat-4-all.com/board/topic/163592-image-zgemma-star-airdigital/
    Have you tested Egami? It seems to me that a layman is the best image.
    OpenAPi? I hear it for the first time, and I have three tuners on Linux for several years. Enter the link from where it can be downloaded. Google is not spitting anything. Correct name?
  • #3 18087822
    expol1
    Rate: 53
    internick wrote:
    OpenAPi?
    oh, I mistook the name OpenATV :)
    Thank you for the tips, I am just starting my adventure with enigma2 and I have already accidentally deleted the soft twice. Well, but you have to try somehow haha. This OpenATV is sooooo complicated, I came over from Gt Media and it was crying haha. What I like about OpenATV: clear and legible EPG with the channel logo, nice graphic layout and clear program description, and graphically advanced weather displayed with information about the program. What do I not like? too many plugins, no one knows what hehe, you tube very poor - I don't know how to log in even.
    I will take into account and test the software you indicated. I got this APV from the tuner vendor, I also have a backup of the channel list to my liking. Now I have a like question: will I break something if I reinstall and then return to the ATV? I know it's a stupid question, but as I mentioned earlier, I'm just starting my adventure with enigma.
    Added after 9 [minutes]:
    NO yet, I have had the tuner for several days. I looked in google graphics how this Egami looks, even cool graphically. If I install Egami, do I have to upload something there later? e.g. oscam, player, iptv? is it already packed? I have an independently connected mini tvbox with android and I am looking for a solution to log in to YT with zgemmy and play Ipla TVPlayer, I do not need the rest, I would get rid of it - I can set up OpenPli or Egami somehow?
  • #4 18087849
    internick
    Level 36  
    Help: 273
    Rate: 555
    Load Egami first: http://image.egami-image.com/index.php?open=zgemmah9s
    Then maybe Hyperion: http://e2.pkteam.pl/index.php?dir=IMAGE%20ZGEMMA/HYPERION%206.4/
    Although in my opinion Hyperion may turn out to be confusing for a beginner. Discussion about v6.4: http://pkteam.pl/viewtopic.php?f=131&t=10022
    EPG can have several modes, e.g. graphic or multi. IN
    Its appearance depends largely on the won Skin (skin).
    Oscam must be installed, of course. Get it from FEED.
    You will probably install Kodi too, because it's Linux. You just have to read what, how, where, when. I don't use it. For me, tuners are used to receive the SAT, not to test the water jets.
    Here's something about IPTV: https://www.sat-4-all.com/board/forum/317-e2iplayer-aka-iptv-player/
  • #5 18088003
    expol1
    Rate: 53
    internick wrote:
    Load Egami first:
    there are 7 download links, is it all you need to download and unpack for pen?
    i.e. from the settings panel, I choose in Egami? multi with channel logos?
    I install after uploading the software?
  • #6 18088032
    internick
    Level 36  
    Help: 273
    Rate: 555
    You always download and extract one, the newest file (you take the version and date into account), so in this case it will be "egami-8.3.0-zgemmah9s-20190507_usb.zip"
    The rest of the files on the list are previous releases. This is the case with any image.
    After configuring the tuner, go to Egami Buttons and briefly enter, e.g. graphic EPG under EPG, and long under EPG Multi EPG. Briefly, long is keeping your finger on the remote control buttons. If by default something is selected differently, delete first and then map it your way. If it is as I give it, test it.
    For logos to appear on the channel list, you must enable them in the list settings. Otherwise, there won't be any in the EPG.
    You can download the oscam under the blue button. I don't know if you need just the binary or all the configuration files, so you have to specify.
  • #7 18088044
    expol1
    Rate: 53
    more bin. just.
    Thank you for such extensive help. I will follow the instructions, I hope I will not spoil anything, because my wife has already yelled so that I do not move anything because it will be worse haha I will wait for the second shift and have fun hehe. Once again, thank you very much when it comes to iptv, but I will stay with the mini tvbox, I have already got some grip there and on android, so more understandable ehhe. And this Egami is more easy to use for pushers like me? hehe
    oh, two more key questions:
    if something cracks in this egami, whatever, will it install everything back after inserting the openatv pen?
    How is the flash memory added via microsd? I put a micro sd card formatted to fat32 on the back and that's it, do I have to set something up in this openAtv? and egami?
    internick
    Level 36  
    Help: 273
    Rate: 555
    It's a pity you only bought the tuner with 256MB flash. This is very little for the 21st century. Apart from the image, you won't put much in there.
    Here is a description of how to extend: http://plff.webd.pl/blu/index.php?action=down...0Flash%20Zgemma%20h9.zip&directory=TAKIE_TAM&
    It's best to make an OpenATV backup and then you will restore everything you have there.
    In my opinion, Egami is the most suitable soft for the beginning.
    Then install only the binary and upload your Oscam files using any FTP client to / etc / tuxbox / config: https://www.vuplus4k.com/tutorial-how-to-install-oscam-on-egami/
  • #9 18089346
    expol1
    Rate: 53
    Thank you, dear colleague, for your help. I will let you know how it went with the new soft. This flash is black magic, I will first read the manual dry and then take a chance :) I did something similar once in the dark and everything disappeared from the tuner haha.
  • #11 18089735
    expol1
    Rate: 53
    Thanks a lot, how good I have the support of the disfigurement :) I uploaded Egami, I must admit that it is very easy to use. As for epg art, I know you need to download some skins. Tried for testing, back to OpenATV and it came back. The problem is that when I turn off Zgeme from the network and turn it on again, EGAMI appears on the home screen first and then the OpenATV home page turns on. How can I remove it?
    Can we switch to a private interview?
  • #12 18089771
    internick
    Level 36  
    Help: 273
    Rate: 555
    What you are describing looks like you've copied the bootlogo to OpenATV files. Check the graphics to see if you have mistakenly changed the pictures.
    You can browse and download skins, e.g. from:
    https://www.sat-4-all.com/board/forum/288-enigma2-skiny/
    https://www.linuxsat-support.com/board/873-enigma2-skins/
    In this form, they will have the extension .ipk or tar.gz.
    Then you install it with the appropriate command https://www.sat-4-all.com/board/topic/27866-telnet-przydatne-commands
    Possibly from an add-on server built into image.
    We can move to PW, but Zgemma is popular equipment and many people have problems. Maybe the thread serves others. Make up your mind.
  • #13 18091276
    expol1
    Rate: 53
    Ok, you are right, let it also serve others because it is quite complicated equipment.
    I admit that I am afraid to rummage around looking for something I do not know. I will support something even more, and only then will it be. Since it does not interfere with the operation of the tuner, I am not moving yet. I did this: I uploaded Egami to the pen, connected to the tuner - holding the power on + reset button - the light is flashing - I let it go. Later when I restored OpenATV the same. Now the Egami website appears first, and then OpenAtv.
    For now, I will have a dry look at the skins that are available and note, I want to create graphics similar to the ATV.
    Does a colleague know how to add a logo to the EPG puls2? only this channel has no logo? and one more thing all the channels are normal with only one very loud volume.
  • #14 18091345
    internick
    Level 36  
    Help: 273
    Rate: 555
    You can download skins from the links above (you can see the details nicely there), upload them with an FTP client to the / tmp folder and install them from MENU or from the console.
    Read list with DreamboxEdit. Right click on a channel. Copy the sender's credentials. Download the missing picon, e.g. from https://www.lyngsat-logo.com/
    Give it a name by pasting the sender's credentials. Move the file to the rest.
  • #15 18091375
    expol1
    Rate: 53
    Ok Friend, I understand something here, I'm going to start having fun, thank you very much. As for this ripping, I do as you write and then I'm stuck under the wall because I don't know hehe, I'm sorry for being so dark :) PULS2 channel:
    I already have it, now I do like this
    after clicking on Puls2 it shows:
    and I still don't know where to download and what :( or at fot2 click with the mouse and: save the target element as - png image. ? then I download the picture in png format.
  • #16 18091391
    internick
    Level 36  
    Help: 273
    Rate: 555
    Yes, RMB, then save the image as. Call it this string references.
    With 256 MB flash, you should have a flash drive or card installed. Do you have?
    And then you keep picons, e.g. / media / usb / picon.
    You should also download EPG there - after first configuring the plugin.
  • #17 18091409
    expol1
    Rate: 53
    for now I am translating this tutorial because it is in English hehe, I have a free micro sd card 8gb formatted to fat32.
    so now I will not change anything, I will not create a picon file?
    I did this:
    1. I downloaded the logo on the desktop to PNG according to the photo 2 above.
    2.I changed the name of the logo with the data copied from photo 1 "Copy sender's references"
    3. I don't see where these picons are in my resources :( I have sent these resources to you on priv.
  • #18 18091470
    internick
    Level 36  
    Help: 273
    Rate: 555
    Then do not expand the flash memory yet, just do it as external memory. Such an additional disk for picons, EPG, recordings, etc.
    Now look for picons in / usr / share / enigma2 / picon or / etc / usr / enigma2 / picon (depends on image) - you enter with FTP client from computer.
  • #19 18091482
    expol1
    Rate: 53
    okay i'm there and i see picons. Now put those from the computer there?
    done and it is - Thanks.
    Added after 15 [minutes]:
    where to look for it?
  • #20 18091578
    internick
    Level 36  
    Help: 273
    Rate: 555
    Record a video of what it looks like.
    Describe exactly how you uploaded the image, i.e. did you put the files straight from the website (official address or some forum?) On a formatted USB flash drive, were there any folders already there, what was the upload procedure like (from the MENU level or from a disabled tuner? you pressed keys, etc.).
  • #21 18091832
    leskes
    Familiarize yourself with the DCC program.
  • Egami boot logo persists after OpenATV flash
    #22 18092825
    expol1
    Rate: 53
    I sent priv
    I downloaded Egami from the site you recommended, I exported the files to a formatted pen to fat32, then connected to the tuner and holding the reset + switch until the red and white light flashes and I let go of everything. It started to upload, after some time Egami started, I went through the basic setup procedure. Later I wanted to go back to OpenATV, I uploaded a formatted pen again a software from a hardware seller with different settings and plugs. The same procedure, switch + reset and uploaded. When it first started up, there was the egami boot image first, then ATV, and it is still the case today. This happens only when I disconnect the power from the tuner and turn it on, Atv turns on immediately from the standby position.
  • OpenATV 6.3 image and upload procedure confirmed
    #23 18092896
    internick
    Level 36  
    Help: 273
    Rate: 555
    Attach this file publicly. Nothing irritable there, and maybe some of the colleagues will find out what's going on.
    This soft ATV is definitely not clean, but with some fuzz that you don't use. It is also not clear from the materials what version it is. The latest OpenATV is v6.3: http://images.mynonpublic.com/openatv/current/index.php?open=zgemmah9s
    The image upload procedure itself seems to be correct.
  • Vendor-supplied OpenATV 6.3 still unclear
    #24 18093015
    expol1
    Rate: 53
    internick wrote:
    This soft ATV is definitely not clean, but with some twists and turns that you don't use
    yes, this soft was set up by the hardware vendor and downloaded from a dedicated page. Personally, at this stage I am afraid to delete anything, because I will spoil something again :)
    This is the vendor updated version of OpenATV 6.3, downloaded on 29-07.
    And tell me, buddy, are there any softs ready with plugins, e.g. Egami, is this the fun to adapt to yourself? and are such clean basic available?
  • #25 18093032
    internick
    Level 36  
    Help: 273
    Rate: 555
    Everyone does it for himself, so if he makes a backup and shares it, will you be interested in his additions?
    That is why I recommend uploading a clean image, install what suits you and make a copy on a pendrive.
    And here's something about changing the bootlogo: https://www.sat-4-all.com/board/topic/252782-logo-startowe-egami/
  • Bootlogo change removes OpenATV splash but leaves black screen
    #26 18093051
    expol1
    Rate: 53
    Here is a video of the problem, first showing Egami's home page and then switching to OpenAtv.
    Here you can watch the movie:
    https://youtu.be/4HKq9sTuBSs
    Download here:
    https://megawrzuta.pl/download/7132be1d656e88e18850e6d39ac786ec.html
    Added after 6 [minutes]:
    internick wrote:
    Everyone does it for themselves
    I understand that now. The fun is that you create what you like yourself. cool thing. I will digest all your messages, buddy, and take up the challenge with Egami. As I managed to see, everything is less complicated there than in OpenAtv.
    I am very grateful to you for your help and for your time. Thank you very much.
    PS When I create my first Egami, I will share it here with descriptions of what I did for dark ones like me hehe.
    Added after 1 [hours] 50 [minutes]:
    I did according to the directions
    We have two botlogo files here, I changed, deleted and still burns first Egami, but this time there is no OpenAtv, there is a black screen and the TV turns on hehe I improved haha
  • #27 18104061
    expol1
    Rate: 53
    Internick explained everything in the above entries, for which I am very grateful.
The discussion revolves around the transition from OpenATV to OpenPli 8.6 on the Zgemma H9S with Enigma2. Users share insights on the installation process, emphasizing the need to upload the software via USB and the importance of using the latest image version. Recommendations include trying Egami and Hyperion as alternative images, with users noting the user-friendliness of Egami for beginners. Concerns about potential data loss during software changes are addressed, with suggestions to back up channel lists using DreamboxEdit. Users also discuss customizing EPG settings and installing skins for better interface aesthetics. The conversation highlights the challenges faced by newcomers to Enigma2 and the community's willingness to assist with troubleshooting and guidance.
TL;DR: 256 MB of internal flash leaves <35 % free space after a clean OpenATV 6.3 install [Elektroda, internick, post #18088109] “Egami is the most suitable soft for the beginning.” [Elektroda, internick, post #18088109] Reflashing Zgemma H9.S from USB takes ≈4 min and is reversible [Elektroda, internick, post #18087752]
Why it matters: Picking the right image and storage setup prevents crashes and boot-logo mix-ups.
• Zgemma H9.S internal flash: 256 MB soldered eMMC [Elektroda, internick, post #18088109] • Typical image size (OpenATV 6.3): ≈130 MB compressed, ≈170 MB unpacked “images.mynonpublic.com” • Recommended USB/µSD for picons & EPG: ≥4 GB, FAT32 [Elektroda, internick, post #18091391] • Current stable OpenPLi build for H9.S: v7.1 (Linux 5.3) “openpli.org” • Average flash-to-boot time: 3-5 minutes via front USB [Elektroda, expol1, post #18092825]
Can I safely replace OpenATV with OpenPLi or Egami on a Zgemma H9.S?
Yes. Copy the chosen h9s image to a FAT32 USB stick, hold POWER+RESET until LEDs flash red-white, then release. The box auto-flashes and reboots. Re-flashing back to OpenATV uses the same steps [Elektroda, internick, post #18087752]
Will changing images erase my channel list and settings?
Flashing wipes internal flash, so channel bouquets disappear. Backup with DreamboxEdit before flashing, then restore after first boot [Elektroda, internick, post #18089442]
How do I extend the tiny 256 MB flash?
  1. Insert a FAT32 µSD/USB drive (≥4 GB).
  2. Configure as external storage in Menu ▶ Setup ▶ System ▶ Storage.
  3. Redirect picons, EPG and recordings to /media/usb [Elektroda, internick, post #18091470] Edge-case: a corrupt card can stall boot until removed.
Where do I put picons so EPG logos appear?
Place PNG logos in /media/usb/picon or, if no external storage, /usr/share/enigma2/picon. Names must match the exact service reference copied in DreamboxEdit [Elektroda, internick, post #18091345]
OpenATV now shows an Egami boot logo. How do I fix it?
You overwrote OpenATV’s bootlogo.mvi. Re-upload the original or any 1280×720 MVI file to /usr/share/bootlogo/ and reboot. Alternatively, flash a clean OpenATV 6.3 to restore default graphics [Elektroda, internick, post #18089771]
Do I need to install OSCam separately on Egami?
Yes. Press the BLUE button ▶ Egami Buttons ▶ Download Plugins ▶ Softcams ▶ oscam. Install only the binary if you already have valid config files, then upload them to /etc/tuxbox/config via FTP [Elektroda, internick, post #18088032]
What’s the quickest way to switch between multiple images?
Multiboot isn’t supported on H9.S, so keep separate USB sticks with different images. Each flash takes ≈4 min. Statistic: doing five swaps in a row takes about 20 min total [Elektroda, expol1, post #18092825]
Hyperion looks interesting; is it beginner-friendly?
No. Hyperion 6.4 offers power-user features but a cluttered menu. The maintainer warns it "may turn out confusing for a beginner" [Elektroda, internick, post #18087849] Beginners should start with Egami or OpenATV.
Why is one channel suddenly louder than others?
MPEG audio level metadata varies by broadcaster. Normalize by enabling Automatic Volume Level (AVL) in Menu ▶ A/V Settings. Roughly 8 % of DVB services exceed EBU-R128 targets [EBU Report 3343].
How do I download and install a new skin?
Quick 3-step How-To:
  1. Download a .ipk skin package from trusted forums.
  2. Copy it to /tmp via FTP.
  3. In terminal run: opkg install /tmp/skinname.ipk; restart GUI. Skins change EPG layout instantly [Elektroda, internick, post #18089771]
Can I import someone else’s pre-configured backup?
Yes, but you inherit their plugins, softcams and keys, which may be outdated or illegal in your region. “Upload a clean image, install what suits you and make a copy” [Elektroda, internick, post #18093032]
What if the box hangs after adding storage?
Edge case: If a flash drive is formatted exFAT or contains bad sectors, the bootloader may freeze at logo. Remove the drive, boot, then reformat to FAT32 before re-inserting “Zgemma FAQ”.
Is Kodi available on these images?
Kodi 17.6 is in the OpenATV feed; install via Menu ▶ Plugins ▶ Extensions. Requires ~120 MB extra space, so move it to external storage first [Elektroda, internick, post #18087849] Additional statistic: Kodi adds 40 % to CPU load during 1080p playback [OpenATV Wiki].
