[Solved] Lenovo Y700 Laptop Issue: EFI Network 0 for IPv4 Boot Failed after Graphics Card Settings Change
Brry 28299 5
  • Switch graphics setting likely changed boot order
    #1 18303061
    Brry
    Rate: 20
    Hello, I immediately say that I do not know computers, so please explain everything in turn
    The problem is as follows:
    I had a problem with the lenovo Y700 laptop did not see my graphics card and I was running on the integrated one all the time so I wanted to do something about it. I read on the forum to enter the BIOS and set the graphics settings from switchtable grapchics to the latter. I did this and then turned on the computer again. After I turn on the computer, I get EFI Network 0 for IPv4 boot failed. I don't know what to do next, I don't know anything about it ..
    • Lenovo Y700 Laptop Issue: EFI Network 0 for IPv4 Boot Failed after Graphics Card Settings Change 983DFE5D-C25A-4B78-BC3B-10FC44ED04A3.jpeg (479.01 KB) You must be logged in to download this attachment.
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    In EFI, I would rather look for "Windows Boot Manager" in sequence, but I suspect it would start the same if it existed. I have the impression that the author has changed not only the switchable graphics option. Legacy Support (CSM) may have been disabled. It is not known what Windows and in what mode the Author is installed.
  • #4 18303161
    Brry
    Rate: 20
    Windows 10 Pro
  • #6 18303190
    Brry
    Rate: 20
    dt1 thanks for your help :)
    You can close
