Control of heat pump from control panel plus emergency switch
kod090 924 1
  • Bypass relay needed for emergency pump switch
    #1 18326159
    kod090
    Hello, I have a question, how to control the heat pump from the control panel, i.e. I have already connected the control panel to the relay 12V to 230V and it works well, e.g. every 2 hours it starts the pump for 20 minutes, and now I would like to make an emergency switch of the pump e.g. when the control panel is damaged? I understand that I have to use another relay, but I do not know how to draw it, should this emergency switch control 220 current separately, bypassing the relay from the control panel? Regards.
  • #2 18329743
    piracik
    Help: 557
    Rate: 1978
    If the pump is to operate in the event of a control panel failure, use a second relay with an NC contact, which is always operated from the control panel.
    If the control panel fails for any reason, it closes the contact for pump operation.
