Tchibo Cafissimo Compact - flashing red light and a sound signal
MarcinMRW 254211 17
Why does a Tchibo Cafissimo Compact flash red and beep instead of starting, and what should I check?
The machine usually indicates that it does not detect water, so check the water tank float/magnet and the internal sensor first. In this model the tank has a float with a permanent magnet, and inside the machine a sensor detects it; if the magnetic field is too weak or the sensor is out of position, the machine thinks the tank is empty and only flashes red with a sound signal [#20926878][#20794806] A quick test is to move an external magnet up the left rear side of the housing with the tank filled; if the machine starts, the tank magnet/float or sensor is the problem [#20926878] One user fixed it by opening the back and lowering the black sensor about 1 mm so it again detected the tank magnet [#21100582] If the issue remains, another reported cause was a dirty/blocked flow meter from sediment, which can be removed and washed after taking off the back cover [#19385329] If the machine is just being primed after setup, press a coffee brew button with no capsule so it can fill with water [#18655499]
  • #1 18329614
    MarcinMRW
    Rate: 10
    My sister gave me a Tchibo Cafissimo Compact coffee machine (which she’d used previously).
    The problem with it is that, after I’ve poured in the water and switched it on, the machine does nothing apart from flashing a red light and beeping.
    There’s the right amount of water in it, but I still get this ‘message’ and I can’t seem to stop it.
    Does anyone have any idea what the problem might be? What should I check?
  • #3 18330477
    MarcinMRW
    Rate: 10
    No, nothing is floating in the water tank.
  • #4 18421598
    myszka.24
    Rate: 56
    Hey, I have the same problem, maybe you got it right now? I would be grateful for help.
  • #5 18655499
    Majnka
    Rate: 177
    Press any coffee brewing button - no capsule. The system must fill with water. When it is finished filling, the light will stop flashing and the audible alarm will stop.
  • #6 19328651
    novek82
    Rate: 122
    It is similar with me, the float is up, the red light is flashing, no button responds. Can you advise whether to the garbage can?
  • Dirty flow meter blocked water supply signal
    #7 19385329
    Paweł59
    Rate: 79
    On my Tchibo Cafissimo Compact, the right red light was flashing. The cause was a dirty flow meter. Sediment in the water caused the impeller to stop spinning. After removing the back cover, the flow meter is easy to access, it can be dismantled and washed. The blocked flow meter causes that the processor has no signal about the water supply to the heater and does not turn it on - it signals an error.
  • #8 19665465
    TomasBax
    Rate: 41
    Hey, who knows how to remove the back cover without breaking it? Even after unscrewing the bottom screws, the whole thing will not budge, so how do you get to the flow meter to take it apart and wash it?
  • #9 19665622
    Paweł59
    Rate: 79
    I don't remember anymore, but I didn't have any major problems. There was no philosophy there. Look carefully, maybe some screws on the inside. I was definitely taking off the metal headband. I had easy access to all electrical components, which I also checked, they were ok. Only the flow meter did not rotate.
  • #10 20121067
    redwater
    Rate: 13
    For me, the same, disassembled, the flow meter is spinning, the lamp continues to flash, I need to check if the signal gives, is there a Hall sensor?
  • #11 20121404
    Paweł59
    Rate: 79
    I will not give my head, but there is probably an output from the open collector flowmeter. That is, power the flow meter, connect the pull-up resistor and see if it switches when turning.
  • #12 20740423
    egzekutor62
    >>18655499
    The machine does not respond to any button. The water does not flow, the heater heats dry because the thermal fuse has burned out. After replacing the fuse, there is still no reaction. Save.
  • #13 20770726
    vintermut
    I have the same machine (second hand) and after turning it on, I just got a white light on the power button flashing for more than 1.5 hours and nothing happens. It does not respond to any button. Does anyone have a clue what is going on with it? Thank you.
  • Weak float magnet likely causing false empty-tank alarm
    #14 20794806
    Krzycho2005
    Rate: 12
    Hey, I have the same problem. Over time, the float magnet probably loses its properties. I found a video on YouTube where a guy disassembles the tank and adds a magnet, and it works for him. I dryly took another magnet and by moving it around the housing with the tank removed, the coffee machine starts to see water, so this is clearly the cause. The only thing that worries me is that to get to the float, you basically have to break the tank because it is welded. Maybe there's a way to get it out without it. I'll think about it some more. If I come up with something, I'll let you know.
  • Magnetic float sensor can be bypassed with external magnet
    #15 20926878
    helgafleischer30
    Rate: 11
    I experimented with this too. It is this: In the freshwater chamber, there is a float with a permanent magnet. If I pour water in, the float goes up and with it the magnetic field. Inside the machine, there is a coil that serves as a sensor. When the magnetic field moves upwards, the sensor detects this and signals the machine that there is enough water in the tank, and it switches on. If for some reason the magnetic field is no longer strong enough, the machine will no longer be able to detect the water level and will no longer turn on - only the red light will flash. Take a permanent magnet from an old hard drive or a magnetized screwdriver, fill the tank with water beforehand and move it from bottom to top at the back left of the outer casing - and hey presto - it tricks you into thinking something and goes again. But don't forget to fill in water, otherwise, it will break if you use it manually. I have this mini, the float may also be located somewhere else.
  • #16 21025507
    stieflchn42
    Rate: 9
    @Majnka
    Thanks for the tip! After a week I was able to consume the delicious nectar of the gods again!
  • #17 21100582
    aleks-1967
    Rate: 41
    I found a way to fix the Tassimo Mini. I removed the back panel. There is a sensor there in black plastic. I filleted it about 1 mm from the bottom. The sensor went down and now detects the magnet in the water tank. If anyone is interested in this, I can help in more detail.
  • #18 21185581
    jerzyzygmunt13
    In my case, there was a kinked hose. I put in a profile on the housing and the problem disappeared.
The Tchibo Cafissimo Compact coffee machine is experiencing a malfunction indicated by a flashing red light and an audible alarm, despite having sufficient water. Users suggest several troubleshooting steps, including checking the float in the water tank, which may not be functioning properly. A common issue identified is a dirty flow meter, which can be accessed by removing the back cover for cleaning. Some users have also noted that the float magnet may lose its properties over time, leading to detection issues. Solutions include using a permanent magnet to trick the sensor or adjusting the sensor's position to improve detection. Other potential causes include a kinked hose or a burned thermal fuse, which may require replacement.
TL;DR: For Tchibo Cafissimo Compact owners seeing flashing/beeping, users report "flashing for more than 1.5 hours" with no response; most fixes restore water detection/flow (prime, float magnet, flow meter). [Elektroda, vintermut, post #20770726]
Why it matters: Quick checks can prevent heater damage from dry-run and save you from unnecessary part swaps.
What does a flashing red/white light on a Cafissimo Compact usually mean?
It indicates the controller isn’t seeing water flow, so it blocks heating and signals error. Sediment can stall the flow‑meter impeller, stopping pulses to the board. “The blocked flow meter causes that the processor has no signal about the water supply to the heater and does not turn it on – it signals an error.” Clean the flow meter to restore detection. [Elektroda, Paweł59, post #19385329]
How do I prime the Cafissimo Compact after refilling or first use?
Use this 3‑step priming:
  1. Fill the tank and seat it.
  2. Power on; insert no capsule.
  3. Press any coffee button to run water until the light and alarm stop. This fills the hydraulic circuit and clears the alert. Repeat once if it draws only air. [Elektroda, Majnka, post #18655499]
The float rises but the red light still flashes and no buttons work—what next?
If the float moves, check the flow meter. A stalled impeller won’t generate flow pulses, so the machine stays locked. Unplug, open the rear, access the flow meter, and wash out sediment. Reassemble and test flow again. This resolves the “light flashing, no response” state when the tank level is okay. [Elektroda, Paweł59, post #19385329]
How do I clean the flow meter on a Cafissimo Compact?
Unplug the machine. Remove the back cover for access. Detach the flow meter, rinse the housing and impeller to remove mineral debris, and ensure the rotor spins freely. Reinstall with correct hose orientation and test. Cleaning restores the pulse signal the controller needs to enable heating. [Elektroda, Paweł59, post #19385329]
How do I remove the back cover without breaking it?
Unplug first. Remove the bottom screws, then take off the metal headband. Inspect for hidden interior screws and tabs before prying. With the band off, access to electrical parts, including the flow meter, becomes straightforward. Work slowly to avoid snapping clips. [Elektroda, Paweł59, post #19665622]
The light keeps flashing for hours and the machine is unresponsive—is that normal?
No. That symptom shows it’s stuck waiting for water detection or flow. Start with the priming procedure, then check level sensing and flow meter. Users reported continuous flashing for more than 1.5 hours without action, which indicates a fault state. [Elektroda, vintermut, post #20770726]
My heater blew the thermal fuse after running dry—what should I check before replacing it?
Fix water delivery and detection first. A dry‑run means no water reached the heater, so it overheated. Prime the pump, verify the tank level is detected, and confirm the flow meter outputs pulses. Replace the fuse only after the root cause is resolved to avoid another failure. [Elektroda, egzekutor62, post #20740423]
How can I test whether the flow meter is actually generating pulses?
It typically has an open‑collector output. Power the sensor, add a pull‑up resistor, and rotate the impeller; the output should toggle. If it doesn’t switch, the sensor or wiring is faulty even if the impeller spins. Replace or repair the sensor path. [Elektroda, Paweł59, post #20121404]
Can a magnet trick confirm a bad water‑level reading?
Yes. Fill the tank. Move a strong magnet (e.g., HDD magnet) from bottom to top along the back‑left case where the level sensor sits. If the machine then “sees” water, the float magnet or sensor alignment is at fault. Never run it dry after this test. [Elektroda, helgafleischer30, post #20926878]
Is there a non‑destructive way to improve level detection if the float magnet is weak?
One user lowered the internal level sensor about 1 mm to better detect the tank magnet. This minor repositioning restored reliable detection. Perform only if you’re comfortable opening the rear panel and accept the risks. “The sensor went down and now detects the magnet.” [Elektroda, aleks-1967, post #21100582]
Could a kinked hose be the reason water doesn’t reach the system?
Yes. A collapsed hose can block intake and mimic an empty‑tank fault. Straightening the hose and adding a support profile to the housing prevented future kinks and cleared the flashing‑light issue for one user. Inspect all silicone lines while the back is open. [Elektroda, jerzyzygmunt13, post #21185581]
My flow meter spins freely, but the lamp still flashes—what else should I check?
The impeller can spin while the sensor output fails. Verify the pulse output with a pull‑up test, inspect the connector, and trace the signal to the control board. Replace the sensor or repair the harness if no switching occurs during rotation. [Elektroda, Paweł59, post #20121404]
Is my machine scrap if no buttons respond and it just flashes?
Not necessarily. Units often recover after priming, cleaning the flow meter, or restoring level detection. Users reported successful return to service after applying these fixes, celebrating normal operation afterward. Try the non‑invasive steps before considering replacement. [Elektroda, stieflchn42, post #21025507]
Where is the water‑level sensor relative to the tank?
It sits inside the machine near the tank’s back‑left area and senses the float magnet’s movement. To locate it, slide a strong magnet upward along the back‑left exterior; when the light changes, you’ve found the sensor zone. Ensure the tank is filled before testing. [Elektroda, helgafleischer30, post #20926878]
