Estimating the Cost of Wiring a 110 kV Line - Configuration Details Included
Bodziokr 17289 26
How much does it cost to lay an underground 110 kV cable line in this configuration?
The cost cannot be estimated precisely from the description alone, because the cable itself is a major expense and the total depends heavily on the laying conditions, cable type, and cross-section [#18350903] [#18351800] For this kind of project, one reply estimated that the cost would exceed 1 million net, assuming a single-circuit line [#18352045] The practical first step is not to ask for a price estimate online, but to apply to the local utility (Tauron Dystrybucja was mentioned) for reconstruction conditions for the 110 kV line; only then can the case be assessed, including relocation of the existing 110 kV cable pole and any required permits or environmental decisions [#18354267]
  • #1 18350863
    Bodziokr
    I would like to wire a 110 kV line in the following configuration:
    Does anyone know what the approximate cost of this operation is?
  • #2 18350903
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    No one will tell you exactly how much it may cost, the cable itself is a considerable expense, and the conditions in which it is to be laid, field, buildings, etc.
  • #3 18350920
    Bodziokr
    There are no buildings, a lawn, only two drillings will have to be made under the street. And the route will be longer after wiring, because as it now has 230, so ultimately it will have 270 m
  • #4 18350958
    retrofood
    Help: 1140
    Rate: 4797
    Will 110 kV cables have to be connected there?
  • #5 18350977
    Bodziokr
    Yes, current mileage is blue, new mileage is red
  • #6 18350980
    retrofood
    Help: 1140
    Rate: 4797
    That is an additional cost.
  • #7 18351763
    CYRUS2
    Help: 1241
    Rate: 3530
    Bodziokr wrote:
    you will only need to do two drillings under the street.
    Only two passes..........
    Who will allow my colleague to do this - what distributor?
    This is how "se" will drill and run a cable for 110 kV.
    Just that - and not much else.
    The colleague must pay as much as the company indicated by the distributor wants.
    A large amount will come out.
  • #8 18351800
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    Check the price of the cables first, you didn't specify what kind of cable it should be and what cross-section, 110 kV itself doesn't say anything.
  • #9 18351834
    retrofood
    Help: 1140
    Rate: 4797
    This wired line near me has a separate cable for each phase, two drills will be small ...
  • #10 18351869
    opornik7
    Electrician specialist
    Help: 316
    Rate: 1568
    Exactly. Six drills for the line plus two for the fiber. In addition, a new HV cable pole.
    I will not mention all the technical and legal documentation.
    In my opinion, the author is taking a hoe to the moon.
  • #11 18352045
    marwis00
    Help: 10
    Rate: 39
    The cost will exceed 1 million (net) - assuming it's a single-track.
    But you probably don't seriously think about it when looking for an investment valuation on an electrode.
  • #12 18353456
    Bodziokr
    I'm not serious at the moment, just wanted to know the very estimated cost. I wanted to buy a plot of land that this line runs through and I'm wondering if it's worth it. I expected the cost to be around 1 million...
  • #13 18353516
    retrofood
    Help: 1140
    Rate: 4797
    How important is this plot? Take it easy. Wiring doesn't mean the end of trouble. The land above the cables and with strips of several meters on both sides cannot be used, the area must be fenced off and fenced off, nothing but trouble. It is pointless to place any hopes on such a plot.
  • #14 18353638
    Bodziokr
    It's not important to me emotionally :lol: it's just business, so you take it easy :D
    Fenced area? Nonsense... The same line is still wired and is located at a maximum distance of 5 m from the buildings, i.e. if I located it on the border with a road plot, I could build in the designated building line, I have to move away from the overhead line at least 15 m, which causes that 2/3 of the attractive 0.5 ha plot in Krakow is excluded from development. Now do you understand? :lol:
  • #15 18353674
    retrofood
    Help: 1140
    Rate: 4797
    I suspected something like that, but you need to know that it is one thing when the power comes to built-up plots, and another thing when someone wants to build next to the line. In "Murator" a situation was described when the power industry released wires over a newly built house. Placed in accordance with all permits. 220 kV line. And the owners did not manage to get rid of these wires from above the roof, it turned out that the power industry has building permits from the province governor, and that the line runs over the house... The culprits were not found and the situation became a stalemate.
    But you would try to build a house ... Ba! Try to plant a tree under such a line on your own plot!
    Therefore, be careful with the conviction that if there is something, it can also be the same for me. It's strangely not symmetrical.
    But go ahead, good luck!
  • #16 18353750
    Bodziokr
    retrofood wrote:
    I suspected something like that, but you must know that the situation when the power comes to built-up plots is different than when someone wants to build next to the line. In "Murator" a situation was described when the power industry released wires over a newly built house. Placed in accordance with all permits. 220 kV line. And the owners did not manage to get rid of these wires from above the roof, it turned out that the power industry has building permits from the province governor, and that the line runs over the house ... The culprits were not found and the situation became a stalemate.
    Of course, I know very well that such situations happen ... I know it from my own experience, I bought a plot of land with a historic wooden building, where a few years ago my neighbor somehow got permission to build a new wooden building 5 m from mine, and it should be 16 . .. The situation is not an absolute stalemate, everything depends on a properly conducted procedure and determination. If the voivode issued a permit for a private plot without the consent of its owner, i.e. without the right to dispose of it for construction purposes and contrary to the issued decision of the National Bank of Poland for a single-family house, it means that he did so in violation of the law. An application for resumption of the proceedings, annulment of the decision and departure from the plot ... it will take a while but it will be dealt with
  • #17 18353759
    retrofood
    Help: 1140
    Rate: 4797
    The point is that it is over the plot and not on the plot. :D The line is standing and who will now decide to change its route?
    The subject is thoroughly described, the appeals are several volumes of files, the lawyers have dealt with it and nothing ... Should I find a link?
    link
    However, it is a 110 kV line.
  • #18 18353811
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Bodziokr wrote:
    I have to move away from the overhead line at least 15 m, which means that 2/3 of the attractive 0.5 ha plot in Krakow is excluded from development.
    Is it in Krakow or in the vicinity, are you building it yourself? This is to be done as soon as it is calculated.
  • #20 18354267
    jozgo
    Help: 1023
    Rate: 1344
    You have to start not with Elektroda, but with applying to Tauron Dystrybucja for the conditions for the reconstruction of the 110 kV line.
    I understand that this is the Tauron line, not PSE.
    The case can be considered positively as it is an extension of an already existing 110 kV cable line. It would be difficult to get approval for an "insert".
    The existing HV 110 kV cable pole (not LV or LV) to be relocated.
    It is only on the basis of the obtained redevelopment conditions that the case can be examined.
    Location decision (if necessary). A decision on environmental conditions (whether it is necessary) for a 110 kV line may or may not be required. etc., etc.
  • #21 18354425
    vodiczka
    Help: 1185
    Rate: 4311
    retrofood wrote:
    the area must be fenced and cordoned off
    Is it the area around the pole from which the cable goes underground? I understand the lanes excluded from use, but I have not heard of fencing the area through which the cable runs.
    In connection with the reconstruction of the Łódź-Fabryczna station (actually the construction of a new one), the 110 kV overhead line was shortened by several hundred meters and led to the transformer station by an underground cable. The area is open and accessible.
  • #22 18354433
    retrofood
    Help: 1140
    Rate: 4797
    vodiczka wrote:
    Is it the area around the pole from which the cable goes underground? I understand the lanes excluded from use, but I have not heard of fencing the area.
    The cable near me (the whole lane) is fenced and there are only designated pedestrian crossings. The fence is so symbolic, something similar to posts and a chain separating the pavement from the road at some intersections. But there is why I don't know.
  • #23 18354501
    zbich70
    Help: 1171
    Rate: 6666
    So it's a mega-curiosity. Maybe there is some other infrastructure besides this cable? I know the exact routes of many 110kV cable lines with a cross-section of 1000 or even 2x2000mm² per phase, multi-circuit, in extreme cases six-circuit. And there are no fences, apart from the station grounds, of course. As far as I know, the only route of the HVDC 450kV cable near Słupsk in Poland is also not fenced.
  • #24 18354583
    retrofood
    Help: 1140
    Rate: 4797
    Maybe because it was one of the first cabled lines (sections) in Poland? And the designers sinned with excessive caution? Its length is approx. 2.5 km, industrial areas. Oh, and along the entire length, there are (were) warning signs every few dozen meters. Most were stolen "as souvenirs".
  • #25 18355034
    jozgo
    Help: 1023
    Rate: 1344
    Tauron does not require fences.
    • 2018-04-24_Standard 30-2018 bud linii kablowych WN z kablami i osprztem.pdf (2.8 MB) You must be logged in to download this attachment.
  • #26 18355333
    marwis00
    Help: 10
    Rate: 39
    Industrial in what sense? Because, for example, in Anwil, in their area, HV cables are to be separated with barriers. But in normal terrain, I've never heard of such a requirement.
  • #27 18355388
    retrofood
    Help: 1140
    Rate: 4797
    In the fact that it is an industrial area, there are several companies there. Nevertheless, the roads between them are generally accessible.
The discussion revolves around estimating the cost of wiring a 110 kV line in a specified configuration. Participants highlight that the cost can vary significantly based on factors such as cable type, installation conditions, and necessary permits. The author clarifies that the installation will involve drilling under a street and extending the line from 230 m to 270 m. Responses indicate that the cost could exceed 1 million (net) and emphasize the complexities involved, including the need for multiple drills, legal documentation, and potential restrictions on land use above the cables. The conversation also touches on the implications of building near existing power lines and the importance of consulting with local distributors for approval and conditions.
TL;DR: Underground 110 kV cable construction averages €3–5 million per kilometre, and “six drills for the line plus two for fibre is realistic” [ABB, 2020; Elektroda, opornik7, #18351869]. Total project cost for 270 m typically lands between €0.9 – 1.5 million. Why it matters: knowing the real price range prevents buying land that cannot support profitable development.
• Cable price: €140–€220 per metre for 1 × 1000 mm² XLPE 110 kV cable [Nexans, 2021]. • Horizontal Directional Drilling (HDD): €250–€400 per metre, Ø200 mm bore [European HDD Report, 2019]. • Permitting time: 9–18 months in Poland for HV relocation [Tauron Guide, 2020]. • Minimum building clearance: 7 m from cable axis, 15 m from overhead conductors [Inżynier Budownictwa, 2016]. • Typical failure rate after installation: 0.3 faults per 100 km-year [CIGRE TB725, 2018].
What drives the cost of rerouting a 110 kV line?
Main drivers are cable price, drilling length/diameter, jointing pits, terminations, new poles, design studies and compulsory utility permissions [Elektroda, nuszek, post #18351800]
How much does the cable itself cost per metre?
For a 1000 mm² XLPE 110 kV cable the factory price is approximately €140–€220 per metre, depending on copper price and fire sheath options [Nexans, 2021].
Is a €1 million budget realistic for a 270 m relocation?
Yes. Cable (€38 000–€60 000) plus accessories, drilling, design, supervision and taxes usually push the bill above €0.9 million net for single-circuit projects [Elektroda, marwis00, post #18352045]
How many boreholes are usually required?
A single-circuit line needs three separate ducts for the phases and one for fibre, so six drills plus two fibre holes match the forum remark [Elektroda, opornik7, post #18351869]
Who grants permission to alter a high-voltage line?
The distribution system operator (e.g., Tauron Dystrybucja) issues relocation conditions; municipal and voivodeship offices approve environmental and location decisions [Elektroda, jozgo, post #18354267]
What clearance is required for building near a 110 kV line?
Regulations demand at least 7 m from the cable axis and 15 m from overhead conductors to any building wall [Inżynier Budownictwa, 2016].
Which documents are needed before work starts?
  1. Relocation conditions from DSO. 2. Environmental decision (if cable >1 km). 3. Building permit. 4. Traffic and drilling plans. 5. Land-owner easements [Tauron Guide, 2020].
What happens if the cable fails after relocation?
Fault repairs average €80 000 per joint; outages can last 8–24 hours. Edge-case: water ingress during drilling caused multiple failures on a Swedish 130 kV line within one year [CIGRE TB725, 2018].
How long does permitting typically take?
Standard timeline is 9–18 months, including 30 days for each public-notice phase and 3–6 months for environmental study review [Tauron Guide, 2020].
3-step guide: requesting relocation conditions from the distributor
  1. Submit a written application with cadastral map and ownership proof. 2. Attend on-site meeting for preliminary route survey. 3. Receive formal technical and financial terms within 90 days, then decide to proceed or abandon [Elektroda, jozgo, post #18354267]
