Will the screws for mounting the motherboard be included with the sharkoon tg5 r
barthogacz 15675 5
  • #1 18363164
    barthogacz
    I'm going to put together a computer that includes a Sharkoon TG5 RGB case and an ASRock Fatal1ty B450 Gaming K4 motherboard. I do not know if I will find all the screws needed for assembly in the set. As far as I know, the set with the board includes only screws for mounting M.2 disks, and the set with the housing includes distance screws, but I am not sure if there are also screws for mounting the motherboard. If not, can someone provide a link where I can buy screws online or in Olsztyn?
  • #2 18363211
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    On the allegro au gray, ask on the websites, maybe you will get a few for free.
    Added after 4 [minutes]:
    He writes that he has an "accessory set", but what exactly is it, contact the seller or the manufacturer.
  • #3 18363221
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    You will find as long as the housing is new. On YT you have a lot of videos about this case and you can see that all screws are sold together with the case, which is probably standard.
    Anyway, you should write when you check for yourself if everything is there, and not now.
  • #4 18363222
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    I was buying a Corsair Obsidian and all the screws were there. Enclosures should be in this class.
  • #5 18363887
  • #6 18364095
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Virtually every case (new) comes with a set of screws for mounting the board, disks, power supply, etc.
