[Solved] NZXT Kraken X62 v.2 Water Cooling Compatible Cases: MSI X370, Ryzen 2700, GTX 1080 Ti/RTX 2080
igor111q 4554 4
  • #1 17399839
    igor111q
    Motherboard: MSI X370 GAMING PLUS
    Processor: AMD Ryzen 2700
    RAM: HyperX Predator DDR4 3200Mhz
    Graphic Card: MSI GTX 1080 Ti GAMING X TRIO or RTX 2080 (not yet purchased)
    Water cooling: https://www.morele.net/chloszenia-wodne-nzxt-kraken-x62-v-2-rl-krx62-02-977446/
    Hello, it so happened that I am assembling the computer and I need a housing, I pasted a link for water cooling because it is a problem, it does not fit into the old housing. I am looking for a housing in which I could mount this cooling from the top, preferably if it was equipped with she's in a "window" or something like that due to the presence of a lot of backlight that I would like to see. Of course, within reason when it comes to money, I need something that will fit it all, so that the housing for PLN 700-800 is not an option ... I would be very grateful for any help !!
  • #4 17399988
    Myrasz
    Help: 10
    Rate: 82
    Yes, the Kraken x62 cooling system will come into this case to the front and top.
    I recommend FILMIK to this case - you'll find out everything.
    BUT :!:
    If you don't mind the white color, I recommend a case with a window on HINGES . Unfortunately, the price of the black color jumped up quite significantly - I was buying for PLN 380 (currently black is the cost PLN 466 ). The hinged window is very comfortable. For my part, I recommend this housing. Unfortunately, but the plexiglass window, however, it is not so easy to scratch. Of course, the door can be completely removed to install components.
    As for the Kraken (regardless of the housing), I suggest mounting on the front and using the push & pull method (you need to buy two additional 140mm fans, e.g. THESE ). Or:
    front-> fans-> cooler-> fans.
    Tests (mine and general on the Internet) show that:
    - Kraken on the front = very low CPU and GPU temperatures unchanged or +1/2 degrees (depending on the housing and fans installed in it);
    - Kraken on top = low CPU temperatures (but even 10 degrees higher than AIO on the front), but not much different from air cooling, GPU unchanged or -1/3 (depending on the housing and fans installed in it);
    As you know, Kraken is bought to get a low CPU temperature, so it's a shame to mount it on the top of the case, because warm air flows from the case through the coolers, and the fans only push it out faster. On the other hand, mounting the Kraken on the front means sucking in cool air from the outside and pushing it further onto the casing (and if the push & pull method - it is faster and more efficient, and thus - we have a low temperature of the CPU). The fans on the back and on top will do the rest.
    Added after 17 [minutes]:
    Check if the Kraken pump wires are covering your first bank of RAM. Unfortunately, probably in all MSI z370 this is the case, and then you either mount a pump with wires at the top / bottom / left, or low-profile RAM.
  • #5 17400079
    igor111q
    Thank you very much for your help, I will take all these advice to heart and try to put everything together so that it is the best. Honestly, this is my first liquid cooling and knowing it is worth its weight in gold for me. Thank you very much again, the topic can be closed !! :D
