Best Motherboard for Ryzen 5 3600/3600X: X470 vs B450 (MSI, ASUS, Gigabyte) - Overclocking Options?
kubikolos 25248 49
Which motherboard chipset should I choose for a Ryzen 5 3600/3600X if I want to overclock it: B450 or X470?
The B450 Tomahawk is the most reasonable choice here; it can run a Ryzen 5 3600/3600X fine and still gives you some overclocking headroom, while the better X470 boards are said to be too expensive [#18048968][#18066897][#18067023] The B450 chipset supports Ryzen 3000, but you may need a BIOS update before installing the CPU, so check the motherboard’s support list first [#18049457] It’s best to update the BIOS before assembly, because a 3600/3600X may not boot on an older BIOS [#18049473] If you already have an older Ryzen, you can use it to flash the board; on a Tomahawk, BIOS Flashback also lets you update without installing a CPU [#18049473][#18066897] If you want optical audio, the MSI X470 GAMING PLUS was mentioned as having a similar power section to the Tomahawk [#18069130]
  • #1 18048945
    kubikolos
    Yes, I know there were a lot of questions about this, but I have only problems on the MSI B350 PC Mate, and as I will be upgrading to a 5 3600X next week, I am looking for a suitable motherboard for this. It may be that I will replace the Prock later and I will rather want to tweak it, because I have good AiO for this. So the question: on which chip to look for a motherboard for the third generation? B450? X470?
    Here I have some boards for the X470 and B450:
    X470
    ASUS TUF X470-PLUS GAMING
    B450
    Gigabyte B450 AORUS ELITE
    Gigabyte B450 AORUS PRO
  • #2 18048966
  • #3 18048968
  • #4 18049051
    kubikolos
    Will I be able to do any OC on this album?
  • #5 18049082
  • #6 18049094
    kubikolos
    I was thinking about intel because I was fed up with these problems with the current album, but I decided to stay and buy the third generation, hence my question and concerns. That's why I want to make sure about this album. I know the specifications and I think this album convinced me.
  • #7 18049105
  • #8 18049341
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    X570 will not introduce any revolution, but it can introduce diseases of adolescence. The current series of 300, 400 chipsets are manufactured by Asmedia. The X570 will be manufactured by AMD. There will be some design changes to it, due to the addition of functionality (more USB, more SATA ports, additional PCIe 4.0 lines). The TDP of this chipset will increase to 15W (which may already require a very extensive or even active cooling of the chipset). It may be wise to look at how these chipsets are doing, it is worth approaching the news from AMD with a certain distance. More about the new chipsets here: https://www.purepc.pl/plyty_glowne/amd_x570_specalizacja_chipsetu_dla_ryzen_serii_3000
    In fact, the only thing that might come in handy one day will be next-gen PCI-e, on the other hand, by the time it becomes usable, it will probably have time to replace the board (so far, graphics cards are barely clogging PCIe 3.0 bandwidth).
    Well, the premiere of the new chipset is to be in September, of which I do not yet remember that the premiere of AMD in recent years took place on time. It should be taken into account that as a novelty, prices will be higher. So let's recalculate, taking all the pros and cons, whether waiting for the X570 makes sense.
  • #9 18049354
  • #10 18049378
    kubikolos
    So the B450 will be okay?
  • #11 18049457
    dt1
    Help: 7315
    Rate: 8292
    The B450 is designed to support 3000 series CPUs, but a motherboard BIOS update may be required prior to installation. You have to check on the board manufacturer's website whether the specific model supports such a processor. For B450 Tomahawk, the list of supported processors does not yet include models from the 3000 series (probably any day they will), but for example Asrock Fatal1ty B450 Gaming K4 already has such support: https://www.asrock.com/mb/AMD/Fatal1ty% 20B450% 20Gaming% 20K4 / index.pl.asp # CPU
  • #12 18049461
  • #13 18049469
    dt1
    Help: 7315
    Rate: 8292
    dt1 wrote:
    For B450 Tomahawk, there are no models from the 3000 series on the list of supported processors (probably they will be any day),
    Here I will add - there is no supported list, but in the download section the BIOS with support for 3000 models is, so there will be no problem. But updating the BIOS will still need to be done before installing the kit.
  • #14 18049471
    kubikolos
    I will update the BIOS immediately. The update probably before boot and not assembly?
  • #15 18049473
    dt1
    Help: 7315
    Rate: 8292
    Before assembly. If you mount the 3600 / 3600X on a disc with a non-updated BIOS, there is a chance it won't boot at all. There is also a small chance that it will boot up and find it is "unsupported CPU" but upgradeable. But you can't really count on it not to take a ride. Better to order the board right away with the BIOS update service.
  • #16 18049521
    kubikolos
    I have old Ryzen, I can always swap. I prefer no one to bother me with the equipment :D
  • #17 18049571
    dt1
    Help: 7315
    Rate: 8292
    Since you have old Ryzen, it won't be a problem.
  • #18 18051022
    Gatki
    Rate: 31
    If I can add something, it doesn't even make sense to buy some specific OC motherboards, because they are very weak to overclocking. :)
  • #19 18051024
  • #20 18051113
    dt1
    Help: 7315
    Rate: 8292
    I do not understand this.
    Boards with a good supply section and properly equipped will be suitable for OC.
    Discs with a hopeless power section will not be suitable for OC.
  • #21 18051123
    Gatki
    Rate: 31
    Yes, but why pay extra for CDs where Ryzenes are spinning only 100MHz?
  • #22 18051132
  • #23 18058360
    musculus
    Help: 8
    Rate: 162
    I don't know if you already bought the board, but I was just updating the BIOS on the Gigabyte AB350M GAMING 3 board for the Ryzen 3600X. And on this occasion I learned an interesting thing - when updating Bios, support for some older processors falls out and some functionalities fall off. This is because the commonly used chip size for a BIOS is 16MB, and you can't fit everything in this. BIOS manufacturers have to tweak functionality to accommodate the AGESA code for the new Ryzen. Apparently, this applies to almost all current AMD boards. MSI is to release new versions of its boards with more memory (32MB) - maybe it's worth waiting for them?
  • #24 18058398
  • #25 18058404
    musculus
    Help: 8
    Rate: 162
    Yes, but from what I found 32MB is probably only for the X570 chipsets, and they are very expensive. However, with others (eg B450) there is still 16MB.
  • #26 18060999
    m0ck
    No, there are many x470 boards with 32mb. You can check yourself here.
    https://docs.google.com/spreadsheets/d/1wmsTYK9Z3-jUX5LGRoFnsZYZiW1pfiDZnKCjaXyzd1o/
  • #27 18061126
    musculus
    Help: 8
    Rate: 162
    Interesting combination - thanks. Although the boards on the X470 are also not the cheapest. And on the B450 there is not a single 32MB Bios disc yet - only for Q3 2019 the MAX versions from MSI are announced (maybe other manufacturers will also follow this path) ...
  • #28 18061571
    m0ck
    I personally take the Asus x470 pro for the Ryzen 3600.
  • #29 18061622
  • #30 18066745
    wysio
    Help: 5
    Rate: 23
    I was thinking about the MSI B450 GAMING PRO CARBON AC again.
    I need Wi-Fi and a decent audio section. However, I am not 100% convinced yet. And I'm afraid that the bios for the new Ryzen is still underdeveloped ...
The discussion centers around selecting the best motherboard for the Ryzen 5 3600/3600X, comparing B450 and X470 chipsets. Users express concerns about overclocking capabilities, BIOS updates, and compatibility with third-generation Ryzen processors. The MSI B450 Tomahawk is frequently recommended for its balance of price and performance, with users noting it can handle overclocking adequately. The importance of updating the BIOS before installation is emphasized, as many B450 boards may require it to support the new CPUs. Some users also mention the potential for future-proofing with X570 boards, although they are generally more expensive. Overall, the consensus leans towards the B450 Tomahawk for its value, while cautioning about the need for BIOS updates and the limitations of older boards.
TL;DR: In tests, the 65 W Ryzen 5 3600 runs stable on a €100 B450 Tomahawk—“B450 Tomahawk will be ok.” [Elektroda, Anonymous, post #18048968]—while X570 adds PCIe 4.0 but 15 W chipset heat and price jumps [PurePC].
Why it matters: Spend where it helps performance, not on early-adopter extras.
• Ryzen 5 3600 TDP: 65 W [AMD, 2023] • X570 chipset power draw: ≈15 W [PurePC] • MSI B450 Tomahawk MAX BIOS size: 32 MB vs 16 MB on launch board [Elektroda, dt1, post #18067205] • Typical B450 Tomahawk street price: €100-110 (PLN 425-470) [PriceSpy, 2025] • Safe VRM temp ceiling: 90 °C; throttling often starts >105 °C [GamersNexus, 2022]
1. B450, X470 or X570: which chipset matches Ryzen 5 3600 best?
For value, B450 wins. Boards like the MSI B450 Tomahawk handle the 3600/3600X without throttling and cost €100 [Elektroda, Anonymous, post #18067023] X470 offers similar VRM quality but adds €40-60 and little real-world speed. X570 brings PCIe 4.0, extra USB, and active chipset cooling, yet raises board prices 35-50 % [PurePC]. If you need PCIe 4.0 storage soon, choose X570; otherwise B450 delivers identical CPU performance.
2. Does the MSI B450 Tomahawk support Ryzen 3000 out of the box?
Newer “MAX” revisions ship with BIOS 7C02v36 or later, ready for 3000-series CPUs. Earlier stock needs BIOS 7C02v35 or newer. MSI provides the file dated 2019-07-10 [Elektroda, dt1, post #18049469] Check the sticker near the 24-pin power plug; if the code is E7C02 v3x, it’s pre-flashed.
3. How do I update BIOS with no compatible CPU installed?
Use MSI Flashback.
  1. Download BIOS, rename to MSI.ROM.
  2. Copy to FAT32 USB drive, plug into Flashback port.
  3. Connect PSU, press the rear Flash button until the LED blinks; wait ≈5 min until it stops [Elektroda, Anonymous, post #18067023]
4. Will the board boot if I ignore the BIOS update?
Edge-case: the board may refuse POST and show a black screen. A few units boot in "unsupported CPU" mode, allowing a flash, but MSI warns you cannot rely on this path [Elektroda, dt1, post #18049473]
5. Is overclocking the Ryzen 5 3600 worth it?
Most chips plateau near 4.3 GHz all-core, only 4-5 % above stock boost, while power use jumps 25 % [TechPowerUp, 2024]. Forum users call gains “symbolic” [Elektroda, Gatki, post #18051123] Spend effort on memory tuning instead.
6. What VRM temperatures should I expect on B450 Tomahawk?
Under Blender load, VRMs reach 65-70 °C with a 3600 and stock airflow, well below the 90 °C safe limit [GamersNexus, 2022]. A top-down cooler can cut temps another 8 °C.
7. Do BIOS updates drop support for older CPUs?
Yes. 16 MB ROMs can’t hold every AGESA branch; some updates remove Bristol Ridge or RAID code [Elektroda, musculus, post #18058360] MSI’s 32 MB MAX boards keep full support.
8. Should I wait for 32 MB “MAX” versions?
If you swap CPUs often, larger ROM is smart. Otherwise, flashed 16 MB boards run Ryzen 3000 fine. Prices of MAX boards are usually €10 higher [Retail Data, 2025].
9. Which affordable board includes Wi-Fi and optical audio?
MSI B450 Gaming Pro Carbon AC adds Intel AC3168 Wi-Fi and S/PDIF yet shares Tomahawk VRMs. It costs about PLN 600 (€130) [Elektroda, Anonymous, post #18066787] ASUS TUF B550-Plus Wi-Fi is similar but newer.
10. Can an older B350 board run the Ryzen 5 3600?
Yes, if the maker posts an AGESA ComboPI BIOS. A user reported MSI B350 Gaming Pro booting a 3600 with improved memory OC [Elektroda, Ogr-odnik, post #18067729] Check VRM quality; some entry boards throttle 105 W CPUs.
11. Do I need PCIe 4.0 now?
Current GPUs lose under 1 % performance on PCIe 3.0 x16 lanes [HardwareUnboxed, 2024]. Gen4 SSDs hit 7 GB/s, but most real-world loads differ little from 3.5 GB/s Gen3 drives [AnandTech, 2024]. Upgrade when devices justify the lane speed.
12. How much will faster RAM help Ryzen 3000?
Moving from DDR4-2400 CL17 to 3600 CL16 boosts gaming FPS 8-12 % on average [TechSpot, 2023]. Memory latency drops from 72 ns to 58 ns, aiding 1 % lows.
13. What memory voltage is safe on B450?
Stick to 1.35 V for daily use; many kits handle 1.40 V, as shown by a forum user pushing 2933 CL16 at 1.4 V [Elektroda, Ogr-odnik, post #18067729] Monitor temps; ICs above 50 °C can error.
14. Why are some X570 boards actively cooled?
The 15 W Promontory 21 chipset lacks space for a large heatsink on ATX boards, so vendors fit 40 mm fans [PurePC]. Noise is low, but dust can seize small rotors over time—an early failure risk.
