Setting Up Network Availability Time Control on UPC Compal Connect Box Router
Piottr242 7800 3
  • #1 18364801
    Piottr242
    Help: 36
    Rate: 300
    The riddle I have to solve - how to set parental control of network availability time on the router indicated in the topic?
    The idea is that the router at 22:00 fires all clients connected other than hard (i.e. via Wi-Fi).
    I was rummaging around in the settings page, but there I can only do global filtering by MAC addresses, and this does not solve the problem of the Internet cutoff time at home.
    KOCUREK1970
    Help: 3862
    Rate: 5490
    MAC Filtering - I want to restrict access only at certain times - Same time, every day - Different times of the day on different days of the week.
    You won't find anything else there.
  • #3 18365857
    Piottr242
    Help: 36
    Rate: 300
    I've set up MAC address filtering from 10pm, but it doesn't seem to be working as it should. It still shows me the devices subject to filtering in the list of connected to the network.
    KOCUREK1970
    Help: 3862
    Rate: 5490
    But they can use the network or are they only visible in the GUI of the modem?
    Also, remember that this is simple operator equipment and a lot of things work the way it works.
    Try to restart Compal by current restart.
