[Solved] UPC Compal Connect Box Router Spontaneously Restarts: User Experiences and Solutions
Igor_Krk 13176 19
How can I stop my UPC Compal router from rebooting and causing TV and internet outages?
The practical fix is to isolate whether the fault is caused by the Compal, the line, or one connected device: unplug everything except one device, test each one separately, and check the modem’s signal levels, active DS/US channels, and any return-channel/T3 errors while also saving speed-test evidence for a written complaint [#18960429] Some Compal units are said to have a hardware defect in the Intel processor section that no firmware update can solve, so a common workaround is to put the UPC device into modem mode and use your own router behind it [#18960057] If the operator does not resolve it, you should file formal complaints in writing and then escalate to the consumer ombudsman; one user eventually got UPC to admit the problem was likely in the connection and they offered to replace the cable or end the contract at no cost [#18960429] [#19003527]
  • #1 18960024
    Igor_Krk
    I did not think that the new services at UPC (which I have used three times in the past) would give me so much blood and I would have to look for help here, but one by one ...
    Internet and tv set up about 3 weeks ago under a new contract. After 2 days from setting up, the problem with buffering when watching TV begins - after buffering and information about low bandwidth, the TV turns off. I check the ethernet connection, reset the decoder, resets the router - for a while it is about a few hours, the same again. Then I repeat the action replacing the ethernet cable. The situation repeats - contact with UPC - after exhausting all topics they send a technician - it came in 2 days. After checking the signals and confirming that it is ok, he said not to reset anything because they assume a 3-day observation. Of course, the situation repeats itself, I call the hotline and say that they see some errors - they upload soft, reset, etc. It works a few hours and then the same as before. They send a technician who replaced the router - he stood with the router turned on, who logged in for 2 minutes and said that everything was working - he came out and in half an hour the situation was restarted.
    My hands are dropping already. I will only add that I had Netia before, with a slower speed and some router that did not have such a problem. Continuous router resets cause a break in work (online lesson that I give my wife and my online work where I have to log in from foreign bank servers).
    What to do in this situation ? In the event of a lack of effective action on the part of UPC, I threatened that I would be forced to terminate the contract because they did not provide the services I had decided on correctly, the person on the other side replied during the telephone conversation that I had a contract for 2 years and I could not do it ...
    Interesant
    Help: 204
    Rate: 249
    Compals have a hardware defect at the level of the Intel Processor Structure, no internal soft will fix it.
    It gets overloaded and reboots - that's what this type is.
    The test already wanted to fly with the printer around the sites, because the printer printed halfway and then returned the blank page.
    The only option that comes into play is switching Compal to modem operation and placing your router behind it ...
  • #4 18960077
    Igor_Krk
    Overloads with normal browsing while using a laptop? I noticed that this does not occur only when 2 laptops + tv are turned on, but also during ordinary TV watching or classic web browsing.
    I cannot imagine investing in my own equipment because it is the service provider that should provide everything I need ... although if I have no choice, it will probably be the only solution
  • #5 18960108
  • #6 18960145
    Interesant
    Help: 204
    Rate: 249
    There is no TV at my in-laws, but a laptop worked and two passive phones, after adding a second computer to WiFi, Compal restarted ...
    I prefer to have my own Edge router, which manages my home network and does not paralyze my work at home during a breakdown, and when I change the operator or the operator's equipment, I do not waste half a day configuring the network from scratch.
  • #7 18960177
    Igor_Krk
    _cheetah_ wrote:
    Igor_Krk wrote:
    but also during ordinary TV viewing or classic web browsing.
    Browsing pages with TV on or just browsing, no other internet users?
    How do you get it all connected - what with cables, what wifi?
    Even a device with wifi can paralyze the system, and one that is only logged into the router at the moment, but not using the net. These things happen, for example with telephones.
    The router restarted in a few cases - only watching TV (both computers turned off), TV announcement + both computers turned on, or e.g. only one computer turned on ...
    TV connection - set-top box - router with cable, the rest WiFi.
    Added after 5 [minutes]:
    I understand it, but the question is why there was no such problem on the old, october equipment from Netia during the same activities? Is the newer (better) enemy of the good?
  • #8 18960429
    KOCUREK1970
    Help: 3860
    Rate: 5488
    If the modemorouter has a hardware defect and after switching to the modem mode, it is still the same device with the same processor, how can it help?
    And this person is right.
    14 days have passed, you have a problem, you have to submit a few complaints in writing, then go to the RK (Consumer Ombudsman) - otherwise you will not terminate such a contract due to the fault of the company (because you say it is their fault).
    Disconnect everything and leave only one device using the Internet, test it. Then join the next ones and test etc - at one it will crash and you will know which one.
    The problem may also be the signal level, errors in the KZ (Return Channel) in the modem as T3, etc.
    What software in Compal, how many DS / US channels are fastened, what signal levels, how do you have your cable installation done?
  • #9 18960616
    Igor_Krk
    Now the router has not logged off for 3 hours because I turned everything off. I have just turned on the decoder and it does not see the ethernet connection - it does not see the cable even though nothing was moved - I could not connect to the network via wifi (although wifi was available) - only after the reset it helped - but still does not see the ethernet cable even though is the same cable and the connection on the back of the router is green.
    As I mentioned before, 3 weeks ago the fitter connected UPC to the already existing connection for Netia. I did not carry out any configuration. Will this edge router be the only solution? I don't want to waste any time trying to figure it out, because it's not my plot at all - a complaint was sent to UPC, so I'm waiting for now.
  • #10 18960633
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Igor_Krk wrote:
    I have just turned on the decoder and it does not see the ethernet connection - it does not see the cable even though nothing has been touched
    Why do you need a decoder connected to the net?
    It can only be an AP, but the wifi network must first be enabled in the decoder.
    That's why I ask how it was done, no one remotely knows what they did there.
    Igor_Krk wrote:
    Will this edge router be the only solution? I don't want to waste any time trying to figure it out because it's not my job at all
    And if it turns out that it is not the fault of UPC equipment?
    Your equipment, your problem - the installer will come after the complaint, he will hook up your computer, it works and you have PLN 50 added to the invoice for the unjustified call of the technician.
    Igor_Krk wrote:
    The complaint went to UPC, so I'm waiting for now.
    The complaint is effective if you prove that it is the fault of the operator.
    First we try to figure out what is causing the error and you haven't even answered my questions.
  • #11 18960658
    Igor_Krk
    It may be different - the decoder is connected to the power supply and the Ethernet cable goes from the power supply to the router (Ethernet connection as recommended by the technician) Ethernet is also set in the network connection options (after 2 resets it was set as before)
    I also have no idea what was done - the worst was that the connection to the net was in the basement / garage and the fitter was alone there, and the house only installed everything, turned it on, checked that it was ok and that's it. If I knew how to check it, it wouldn't be a problem :)
    Igor_Krk wrote:
    Will this edge router be the only solution? I don't want to waste any time trying to figure it out, because it's not my job at all
    Yes I agree. Therefore, being a total layman in the subject, I would not like to limit myself to 'it doesn't work and I don't know why', but I check on my own how much I can. Ultimately, I am inclined to the suggested statement that these continuous router restarts result from using too many devices at the same time (I will just mention that the max speed is 500 mb / s download and 30 mb / s upload).
    I try to answer whatever I am able to answer.
  • #12 18961032
  • #13 18961064
    KOCUREK1970
    Help: 3860
    Rate: 5488
    _cheetah_ wrote:
    To the power supply?
    So you have an Apollo decoder.
    After LAN, it takes from 18Mb to 25Mb of bandwidth (depending on what material we are watching).
    But you can check the signal level in the modemorouter, how many active DS / US channels are there, what soft channels, etc. - that will also tell a lot.
    Do you have IPv6 active there?
    Check here:
    https://test-ipv6.com/
    Additionally, I will ask, what version of the software does the Apollo decoder have?
  • #14 18961312
    Interesant
    Help: 204
    Rate: 249
    Eg. Modem work requires less computation and the processor is less loaded or does not use the space damaged during production ??
  • #15 18961356
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Interesant wrote:
    Modem work requires less calculations and the processor is less loaded or does not use the space damaged during production ??
    You think op has launched a new decoder that only uses the internet and hasn't tested it?
  • #16 18961688
    Interesant
    Help: 204
    Rate: 249
    Costs count, and certainly no one has tested how the equipment works, someone estimated that despite the complaints, it would still be profitable for them.
    Only if it is compatible with DOCIS 3.0 -> they bought a few Compali containers in the promotion.
  • #17 18961918
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @client
    You made me laugh, and solemnly - with this I will end our interesting conversation.
  • #18 18962365
    Interesant
    Help: 204
    Rate: 249
    KOCUREK1970 wrote:
    @client
    I understand that there were no arguments ...
  • #19 18962431
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @client
    No, only you have no idea what you're talking about.
  • #20 19003527
    Igor_Krk
    After over a month of continuous interruptions in the Internet supply, after reported cases and visits from technicians, UPC admitted that it was probably the fault in the connection and wanted to replace the cable by pulling it to the corridor throughout the apartment (now the cable is connected in the wall), which I did not agree to and they suggested amicable termination of the contract at no cost to which I agreed. Subject to be closed, thank you.
    I resigned
The discussion revolves around issues experienced with the UPC Compal Connect Box router, which spontaneously restarts, causing buffering and connectivity problems during TV viewing and internet browsing. Users report that the router's Intel processor may have a hardware defect leading to overloads and reboots. Suggestions include switching the Compal to modem mode and using a separate router to manage the home network. Users also discuss the importance of conducting speed tests, checking signal levels, and ensuring proper cable connections. After a month of troubleshooting, one user reported that UPC acknowledged a fault in the connection and offered to terminate the contract amicably.
TL;DR: Experiencing UPC Compal Connect Box restarts and TV buffering? "After LAN, it takes from 18–25 Mb/s," so streaming plus devices can starve resources; stabilize by using bridge mode, isolating culprits, and logging certified tests for complaints. [Elektroda, KOCUREK1970, post #18961064]
Why it matters: This FAQ helps UPC/Liberty Global users with Compal Connect Box and UPC TV (Apollo) fix spontaneous reboots that disrupt work, lessons, and streaming.
Why does my UPC Compal Connect Box keep restarting?
Restarts often point to signal issues on the return channel, device conflicts, or software/channel configuration. Check signal levels, DS/US channel counts, and T3 errors in the modem. Test with only one device, then add devices gradually to spot a trigger. Gather this data before complaints. [Elektroda, KOCUREK1970, post #18960429]
How do I isolate which device is triggering restarts?
Try this:
  1. Disconnect all devices and confirm stability.
  2. Connect one device (wired or Wi‑Fi) and monitor.
  3. Add devices one by one until a restart occurs; note the culprit. This simple method can quickly expose problematic clients. [Elektroda, KOCUREK1970, post #18960429]
Can an idle phone or Wi‑Fi gadget crash the network?
Yes. "Even a device with wifi can paralyze the system," including one only logged into the router and not actively using data. Phones are common culprits. If restarts stop after disconnecting a specific device, investigate its firmware and network settings. [Elektroda, Anonymous, post #18960108]
Should I use bridge mode with my own router to stabilize things?
Many users improve stability by switching the Compal to modem/bridge mode and placing a separate router behind it. "The only option... is switching Compal to modem operation and placing your router behind it." Configure Wi‑Fi on your own router and disable it on the Compal. [Elektroda, Interesant, post #18960057]
Does the UPC Apollo set‑top box affect my bandwidth or stability?
Yes. "After LAN, it takes from 18Mb to 25Mb of bandwidth" while streaming. That reduces headroom for other devices. If your TV is on and several laptops are active, congestion can rise, increasing the chance of buffering or instability. Consider wired connections and QoS on your own router. [Elektroda, KOCUREK1970, post #18961064]
My decoder shows no Ethernet even with a green port LED—what now?
Power‑cycle the decoder and router, reseat the cable, and try a different router port. Verify the decoder’s network setting is Ethernet, not Wi‑Fi. If Wi‑Fi connects but Ethernet does not, swap the cable to rule out a bad lead. Persistent behavior suggests router or decoder port issues. [Elektroda, Igor_Krk, post #18960616]
How do I check signal levels, channels, and errors on the Compal?
Open the modem status pages and note downstream/upstream channel counts, power/SNR, software version, and any T3 errors. Capture screenshots before contacting support. These details help determine if line quality or headend configuration contributes to restarts. Provide them when filing a complaint. [Elektroda, KOCUREK1970, post #18960429]
Do I need IPv6 enabled, and how can I test it?
Check whether IPv6 works using a quick browser test. "Check here: https://test-ipv6.com/." If sites or apps prefer IPv6, misconfiguration can cause slowdowns or odd failures. You can toggle IPv6 with support if testing indicates issues. Keep test results for diagnostics. [Elektroda, KOCUREK1970, post #18961064]
What if UPC says I can’t cancel my 2‑year contract?
Log every fault and submit written complaints. If unresolved, escalate to the Consumer Ombudsman. Without this paper trail, cancellation for operator fault is unlikely. Provide modem stats and test evidence to strengthen your case. Keep all technician visit reports. [Elektroda, KOCUREK1970, post #18960429]
How should I document problems for a strong complaint?
Run the regulator’s certified speed tests at the exact times issues occur. Save results and timestamps. Follow the portal’s instructions for properly filing a claim. This documentation helps prove service nonconformity during investigations or mediation. [Elektroda, Anonymous, post #18960066]
Can too many devices cause Compal reboots?
Yes. A user observed restarts after adding a second computer to Wi‑Fi, even with minimal other activity. This suggests load or compatibility issues on the gateway. Bridge mode with a robust router can help isolate and manage client traffic. [Elektroda, Interesant, post #18960145]
What was the final resolution in this thread’s case?
After over a month of interruptions, UPC acknowledged a likely connection fault. They proposed pulling a new cable. The user declined, and both sides agreed to terminate the contract without cost. Outcome: amicable termination. [Elektroda, Igor_Krk, post #19003527]
Should my decoder be online, and can it act as a Wi‑Fi access point?
You don’t always need it online. It can act as an access point, but you must enable its Wi‑Fi first. If you use a separate router, keep the decoder’s networking simple to reduce conflicts. [Elektroda, KOCUREK1970, post #18960633]
Is the Compal Connect Box defective by design?
One viewpoint claims a hardware flaw: "Compals have a hardware defect at the level of the Intel Processor Structure; no internal soft will fix it." The suggested workaround is bridge mode with your own router. Treat this as a reported user opinion. [Elektroda, Interesant, post #18960057]
Will a 500/30 Mb/s plan handle streaming and online lessons?
Yes, on bandwidth, but stability matters more. The case in-thread had 500/30 Mb/s and still suffered reboots disrupting lessons and work. Focus on fixing restarts and line quality first, not just speed tests. Document everything while troubleshooting. [Elektroda, Igor_Krk, post #18960658]
