Best Energy-Efficient Radio Protocol for Battery-Operated Building Automation
1647 21
How can I choose the most energy-efficient wireless communication method for a battery-powered home automation device?
There is no single “most economical” standard; power use depends mainly on how often you transmit, how long the radio is on, and how much data you send, so the best design is one that sleeps most of the time and uses very short, infrequent frames [#18397178][#18459286] For battery devices, choose a low-power protocol such as BLE, ZigBee, or even your own protocol, but design the node around sleep modes and minimal active time rather than the protocol name alone [#18398729][#18459286] If the range is enough, Bluetooth 5 / BLE with an integrated chip like the nRF52840 is suggested; if 2.4 GHz is not enough, use ZigBee in a sub-1 GHz version [#18399880] A practical system often needs at least one mains-powered gateway or intermediary, because two sleeping battery nodes are unlikely to wake and talk at the same moment [#18459286] Also pay attention to the MCU, regulator/converter losses, and even battery self-discharge, because they can dominate the radio’s consumption in ultra-low-power devices [#18459286]
  • #1 18396694
  • #2 18396881
    daroka14
    Help: 88
    Rate: 139
    I don't quite understand what you want to control with this communication. The most energy efficient is a radio receiver and remote control. Just not suitable for everything.
  • #3 18396902
  • #4 18396939
  • #6 18397178
    TvWidget
    Help: 472
    Rate: 694
    Which car has the lowest fuel consumption? The answer to this question is simple. One that is not driven. The same is true in this case. The most energy-efficient solution will be one where devices transmit very little data, over short distances, and do so very infrequently.
    Energy efficiency is not a characteristic of a given interface or protocol. For example, Bluetooth Low Energy, as the name suggests, should be energy efficient. It usually is. However, the power consumption can vary thousands of times depending on the mode of operation and what the designer thinks of.
  • #7 18397790
  • #8 18397803
  • #9 18397905
  • #10 18397954
  • #11 18398238
    TvWidget
    Help: 472
    Rate: 694
    You probably expect a simple straightforward answer. It is impossible to give such an answer. If many different interfaces and communication protocols are used, it means that there is no single best one. Each has its own advantages and disadvantages. What may be a strength in one solution may be disqualifying in another. If you want to do something then unfortunately you have to start by learning the basics. There are certain stages of learning that cannot be skipped.
    When it comes to popularity as measured by the number of devices produced, I think WiFi and Bluetooth Low Energy will come first. Every smartphone, smartband and tablet has these interfaces. From this perspective, ZigBee and Z-Wave can be considered niche solutions.
  • #12 18398283
  • #13 18398394
    TvWidget
    Help: 472
    Rate: 694
    gshesiu wrote:
    for me it is not a problem to make my own protocol using serial communication in the microcontroller and some module e.g. usart-"RF", the relevant experience I rather have.
    You are already making a mistake in your assumptions at this stage. Battery-powered low-power devices often use specialised processors integrated into the radio interface. In practice, communication via USART requires a relatively large amount of energy. If the sensor is to be powered for a year by a small battery, e.g. CR2032, the average current may not exceed a few tens of uA. Consider in this context how much energy the USART operation (clock, GPIO, etc.) costs.
  • #14 18398437
  • #15 18398729
    TvWidget
    Help: 472
    Rate: 694
    gshesiu wrote:
    It would be good, for example, for the reception of data to wake up the prock
    You have the wrong approach to the issue. Turning on a radio receiver is a gigantic power consumption. Doing it permanently will drain the battery quickly.
    For example, with BLE, the device periodically (every 1 sec or so) sends a notification frame. After this operation, listening is switched on for a very short time. If nothing is received then the device goes to sleep. Statistically, the radio interface is switched off almost all the time.
    The other side, e.g. the smartphone, has power in abundance. Here listening can be switched on for a long time. Note that there are two types of devices in this standard. One is very energy efficient. However, this is achieved at the expense of the others, which draw a thousand times more current.
    Home automation devices can usually also be divided into similar groups. The first is all kinds of battery-powered sensors. The second is mains-powered actuators.
  • #16 18399199
  • #17 18399333
    TvWidget
    Help: 472
    Rate: 694
    gshesiu wrote:
    for example, a device similar to a wall-mounted battery-operated temperature controller set occasionally via the internet (app on a phone etc., on the internet side an RF transmitter/receiver on mains power with an RF transceiver, sort of like a control unit for RF devices).
    The problem can be solved differently. The controller you mention is in the general case a thermometer and an algorithm for switching on, for example, a cooker. This example cooker rather needs to have mains power. Let's assume that we transfer the algorithm to the cooker. In this situation, we have a battery-operated thermometer that does not require any remote configuration and a cooker that has mains power and can be permanently connected to the Internet, e.g. via WiFi.
  • #18 18399352
  • #19 18399376
    mechatronix.engineer
    XBEE Modules without unnecessary complication simple network enormous documentation.
  • #20 18399445
  • #21 18399880
    witek_34
    Rate: 18
    If the range allows it, I suggest Bluetooth® 5 / Bluetooth Low Energy and specifically the nRF52840. It contains an integrated CPU so you make the device on one chip. There are lots of modules and documentation for this.
    If 2.4 GHz will not get you through then I would suggest ZigBee but in a sub 1 Ghz version.
  • #22 18459286
    tmf
    Help: 2090
    Rate: 2203
    gshesiu wrote:
    I would like to make a device that could communicate energy efficiently with other devices within a house several rooms over.
    Do you want to build this yourself (and have the knowledge to do so), or are you looking for off-the-shelf?
    In the latter situation, I can't advise you. However, if you have some experience in programming and electronics then:
    - practically any modern radio module is suitable, e.g. from the cheap and popular RFMxxx - you have modules from 433 MHz to 2.4 GHz, the frequency you choose depends on the conditions, a mix of different frequencies can be used.
    - The current consumption for a radio transceiver depends almost exclusively on the time it is switched on. Short frames transmitted e.g. every second (as in BLE) mean that if, for example, the active time is 1 ms, the transceiver consumes 40 mA, effectively the device consumes an average of 40 uA, battery life will be very long.
    - The key is the right protocol - BT BLE, ZigBee or others, or something of your own. There are some ready-made ones on the web, it's worth a read.
    - modern microcontrollers consume little current (about 1-2 mA in such an application). They have sleep modes where current consumption is a fraction of a uA.
    - to make it all so beautiful, you need some experience in writing low-power applications.
    - note that often much more current than the MCU + transceiver is consumed by the voltage converter, hence the need to design this part of the circuit carefully.
    - for AA or AAA batteries, self-discharge current may be more important than the current consumption of the circuit. At least for ultra-low power applications this is relevant.
    But back to radio communication - when limiting current consumption by limiting active (listening) time, you need some kind of intermediary to collect the messages and send them out at the right moment. The chance that two active modules will synchronise for e.g. 1 ms is poor, hence it is worth having at least one normally powered module working as a gateway.
    As for the question about the most economical standard - I've highlighted to you how it more or less works - how much power it consumes depends on you - how often you want to transmit something, how much data you have, etc. E.g. you're measuring temperature - if you take a measurement every second it will use some current, if you take a measurement every minute for example it will use 60x less with some approximation. As you can see, a well thought-out concept is important.
✨ The discussion centers on identifying the most energy-efficient radio protocol for battery-operated devices in building automation. Key protocols mentioned include ZigBee and Z-Wave, with ZigBee being highlighted for its energy efficiency. The conversation emphasizes that energy efficiency is not solely determined by the protocol but also by the device's design and operational parameters. Bluetooth Low Energy (BLE) is also noted for its low power consumption, particularly when devices transmit infrequently. The importance of using integrated processors in radio modules to minimize energy usage is discussed, along with the potential for using various frequencies depending on environmental conditions. The participants stress the need for a balance between cost, efficiency, and the specific application of the devices.
TL;DR: A duty-cycled BLE sensor averaging 40 µA can run >2 years on a 240 mAh CR2032; “Energy efficiency is not a characteristic of a given interface” [Elektroda, TvWidget, post #18397178] Choose a protocol that lets radios sleep >99 % of the time.
Why it matters: Picking the right stack slashes battery swaps and support calls.
• Zigbee End Device sleep ratio: up to 99.5 %, <20 µA average [Texas Instruments CC2652R, 2023]. • BLE advertising interval can stretch to 10.24 s, cutting RX duty cycle to 0.1 % [Nordic nRF52840 PS, 2023]. • Z-Wave chips cost ≈ US$2.5 in 1 k lots, but SDK licence adds ≈ US$3 per-device [Silicon Labs, 2023]. • ISM sub-GHz EU bands: 868–868.6 MHz (25 mW) & 869.4–869.65 MHz (500 mW) [ETSI EN 300 220-2]. • BLE 5 long-range PHY achieves 125 kbps at –105 dBm sensitivity [Nordic, 2023].
Which wireless standards dominate battery-powered home automation?
Four stacks cover most products: Bluetooth Low Energy (BLE), Zigbee, Z-Wave, and proprietary Sub-GHz (e.g., 433/868 MHz) [Elektroda, thread]. Wi-Fi draws too much for coin cells, so it appears mainly in powered hubs [Elektroda, TvWidget, post #18398238]
Does any protocol guarantee the lowest power?
No. Power comes from radio-on time, packet size, and duty cycle, not the logo [Elektroda, TvWidget, post #18397178] A BLE or Zigbee device can drain a coin cell in days if left in continuous RX.
How long can a BLE sensor run on a CR2032?
With 40 µA average draw (1 ms TX every 1 s) [Elektroda, tmf, post #18459286] a 240 mAh coin cell lasts ≈ 250 days. Stretching the interval to 5 s drops average current to 8 µA, extending life to ≈ 3 years (calculated).
When should I pick Sub-GHz over 2.4 GHz?
Pick Sub-GHz for masonry walls, basements, or garden sheds because path loss is ≈ 8 dB lower through brick [ITU P.1238-9]. Use 2.4 GHz when you need smartphone compatibility or 2 Mbps throughput.
Is Z-Wave really ‘locked down’?
Yes. Silicon Labs sells the silicon, but firmware keys and certification cost extra (≈ US$3 per unit + test fees) [Silicon Labs, 2023]. Zigbee and BLE specs are free to download.
What integrated chips are popular for ultra-low power?
  1. Nordic nRF52840: BLE 5, Thread, Zigbee, 4.6 mA RX [Nordic, 2023]. 2. TI CC2652R: Zigbee/BLE, 6.9 mA RX [TI, 2023]. 3. Silicon Labs EFR32FG: Sub-GHz/BLE dual-band, 7.7 mA RX [Silabs, 2023]. All include Cortex-M CPUs, eliminating USART overhead highlighted in the thread [Elektroda, TvWidget, post #18398394]
How do I keep a receiver from draining the battery?
Duty cycling. BLE beacons every 100–10,240 ms; between slots, the radio sleeps [Nordic, 2023]. Continuous RX can raise current 100× [Elektroda, TvWidget, post #18398729]
Can I design my own protocol instead?
Yes, using generic transceivers like RFM69 (433/868 MHz). Pros: no licences, tailored packet size. Cons: no smartphone bridge, you must handle security and over-the-air updates [Elektroda, tmf, post #18459286]
Edge case: what silently kills battery life?
A noisy power converter can draw 150 µA quiescent, overshadowing a 10 µA radio budget [TI TPS62175 DS, 2022]. Always measure regulator sleep current.
How to prototype an energy-efficient sensor?
  1. Flash sample ‘sleep-beacon’ firmware to an nRF52840 module. 2. Set advertising interval to 2000 ms and TX power –4 dBm. 3. Verify current ≤ 15 µA with a source-meter. Done in under an hour.
What does certification involve?
BLE and Zigbee need RF compliance (ETSI/FCC) plus alliance logo testing. Budget US$5–10 k per model UL Guide.
Are XBee modules a shortcut?
Yes. Digi XBee 3 offers plug-in BLE or Zigbee with AT-style commands and draws 1.7 µA in deep sleep [Digi DS, 2023]. Unit price starts at US$16 in singles Mouser.
