[Solved] Bosch SMV68TX04E Dishwasher: Blurred Floor Display Issue - Possible Solutions & Alternatives
pszemas 67239 30
Why is the Bosch dishwasher floor display blurred or overexposed, and can it be fixed without replacing the whole module?
The thread points to a damaged optical/display element rather than dirt, so cleaning the lens or mirror usually does not solve it [#18419973][#19113036] In one case, replacing the projector did nothing, but replacing the mirror fixed the blurry floor image; the old mirror was scratched [#19543858] Another user opened the module and found the liquid-crystal display layer damaged, concluding that the repair is impossible without a new liquid-crystal element or a complete new module [#19660243][#19190159] If you do replace it, the job can be done without removing the dishwasher from the built-in: remove the inner door front panel and the plinth, then swap the module; one user said the service replacement took only about 10–15 minutes [#18905547][#19543858]
  • Built-in dishwasher with salt warning indicator recommended
    #31 19695230
    Piotr2608
    Help: 851
    Rate: 4487
    SuliX wrote:
    The Elektroda forum is a place for people looking for a possibility of rational repair at a minimum cost.
    This is your statement that sounds like:
    SuliX wrote:
    Your post doesn't add anything positive, except that you have grown tremendously. Out of frustration, I recommend enrolling in a beginner's boxing course.
    Emptiness pours out of your mouth, if you have a problem, write to the manufacturer, maybe he will listen to you.
    When you buy any good that serves humanity, you should first realize if you can afford it in the future
    for its maintenance, calculating, for example, the costs of depreciation or repair.
    Maybe you haven't grown up to the new times and some things are too much for you.
    SuliX wrote:
    If the displayed data regarding e.g. the lack of salt are needed like a hole in the bridge, I suppose that you recommend the use of a grater for washing because it is equipment without unnecessary gimmicks and exceptionally ecological.
    No, I recommend a built-in dishwasher with a front panel or a top panel, where the lack of salt is signaled by an appropriate message, most often in the form of a glowing LED diode.
    ZimTech Piotr Zimny
The Bosch SMV68TX04E dishwasher is experiencing a blurred floor display issue, with users reporting that the display becomes overexposed and unclear. Suggested solutions include cleaning the lens and mirror, but many users have found that this does not resolve the problem. Replacing the display module (Bosch part number 10008674) is often recommended, with costs ranging from PLN 200 to PLN 350. Some users have successfully replaced the module themselves, while others have noted that the issue may stem from a damaged liquid crystal diaphragm. There are discussions about the ease of replacement and the potential for ongoing issues with the display quality over time. Overall, the consensus is that while cleaning may provide temporary relief, replacement is typically necessary for a permanent fix.
TL;DR: PLN 240 average replacement price and "Cleaning will not do anything" [Elektroda, tombalt, post #19113036] show that blurred Bosch TimeLight most often needs a new 10008674 module. DIY swap takes 15 min [Elektroda, swietopel, post #19543858] Why it matters: Quick diagnosis avoids a PLN 1000 main-board swap.
• Bosch 10008674 TimeLight module: PLN 210–240 online [Elektroda, logpxx, post #18962277] • Service visit fee: PLN 163, parts extra [Elektroda, logpxx, post #18962277] • DIY replacement time: 10–15 min, eight screws total [Elektroda, swietopel, post #19543858] • Mirror-only spare (00625410): ~PLN 100 [Elektroda, swietopel, post #19543858] • Main control board failure: ≈PLN 1000 risk [Elektroda, Monikaaa335, post #18541068]
Will cleaning the lens and mirror restore sharpness?
No. Multiple owners tried and failed. One expert stated, “Cleaning will not do anything” after inspection [Elektroda, tombalt, post #19113036]
Which part usually fails inside module 10008674?
The internal LCD element delaminates. Photos show cracked liquid-crystal layers even when electronics stay intact [Elektroda, spallony, post #19660243]
How much does a new TimeLight module cost in 2024?
Online shops list PLN 210–240, while Bosch service quotes the same part at PLN 240 plus labour [Elektroda, logpxx, post #18962277]
Can I replace only the mirror instead of the full module?
Yes. A scratched mirror (part 00625410) costs ~PLN 100 and restores focus when the LCD remains healthy [Elektroda, swietopel, post #19543858]
How do I swap the module myself?
  1. Remove six Torx screws holding the decorative door panel. 2. Pull the plinth, then undo two side screws to free the U-shaped bracket. 3. Detach the old projector, clip in the new one, reassemble [Elektroda, swietopel, post #19543858]
Do I need to pull the dishwasher out of the cabinet?
No. Users and technicians replaced the module with the machine in place by only removing the door panel and plinth [Elektroda, Monikaaa335, post #18905547]
Edge case: The projection disappeared entirely—what now?
A dead LED or disconnected ribbon can kill the image. Verify module power and cable seating before ordering parts [Elektroda, pszemas, post #18419171]
