Setting Radio Frequency: Guide to Listen to Institutions & Services
tommyb84 12291 12
How do I set my radio to listen to various institutions and services?
To listen to a service, set the radio to the frequency it transmits on and make sure receive tones such as R-DCS and R-CTZS are turned OFF [#18426333][#18426603][#18426556] If you hear very little or nothing, that can be normal because the service may simply not be talking at that moment, and it can stay silent for days [#18426471] For better reception, place the radio near a window and as high as possible, since height improves range [#18426645]
  • #1 18426182
    tommyb84
    Rate: 12
    Could someone post what settings should be made on this radio to listen to various institutions?
    Thank you in advance.
    Moderated By Olek II:
    I separated. 3.1.19. Do not send messages on archival subjects if this is another question, in particular other than the questioner. For the sake of respect to the questioner, create your own topic. You can only add a solution to the problem.
  • #2 18426333
    tape
    Help: 26
    Rate: 49
    In principle, you only need to enter the frequency at which the service transmits.
  • #3 18426393
    tommyb84
    Rate: 12
    I introduced the police, fire brigade and ambulance. I have all these units max 4 km from the receiver. All day I received only 2x Police. Possible?
    I will add that I am a complete layman in this topic, so I would ask for clear instructions.
  • #4 18426471
    Rezystor240
    Help: 689
    Rate: 1652
    As possible, my radio went silent for about 2.5 days. I thought the radio was broken. Or they escaped in DMR. But no.
    If they have nothing to talk about, they don't talk.
  • #5 18426502
    tommyb84
    Rate: 12
    Oh.
    Thanks. I'll be listening, then.
    Regards.
  • #6 18426556
    Rezystor240
    Help: 689
    Rate: 1652
    It is not necessary to disable all tones on the RX. Otherwise he won't listen to anything.
  • #7 18426577
    tommyb84
    Rate: 12
    And do you know which item on the menu?
  • #8 18426603
    Rezystor240
    Help: 689
    Rate: 1652
    @tommyb84
    R-DCS na OFF
    R-CTZS na OFF
  • #9 18426615
    tommyb84
    Rate: 12
    It was OFF
  • #10 18426620
    Rezystor240
    Help: 689
    Rate: 1652
    Then you have the receiver fully unlocked for tons and other crap.
  • #11 18426636
    tommyb84
    Rate: 12
    I will wait. Maybe he'll speak.
    Thank you for your help.
  • #12 18426645
    Rezystor240
    Help: 689
    Rate: 1652
    One more advice, put the radio next to the window (only with the display inwards for what someone is looking at) then there will be better reception. And even better if it is a window on the floor, the higher the radio above the ground the better the range.
    73!
  • #13 18426671
    tommyb84
    Rate: 12
    It stands next to the window on the 4th floor. I'll wait a little bit.
    Thanks again.
To listen to various institutions using a radio, users need to input the correct transmission frequency for the services they wish to monitor. It is important to ensure that all tones on the receiver are not disabled, as this may prevent the radio from picking up any signals. Specific settings recommended include turning R-DCS and R-CTZS to OFF. Additionally, placing the radio near a window, preferably on a higher floor, can enhance reception quality. Users have reported intermittent communication from services like police and emergency responders, indicating that silence may occur if there is no active communication.
TL;DR: Expect quiet periods when monitoring; silence can last 2.5 days. "If they have nothing to talk about, they don't talk." This FAQ helps beginners set frequencies, turn off RX tones, and improve reception for police, fire, and ambulance listening. [Elektroda, Rezystor240, post #18426471]
Why it matters: It shows setup is simple, but airtime varies, so silence doesn’t mean your radio is broken.
How do I quickly set my radio to hear local services?
Use this fast method: 1. Look up the exact transmit frequency for the service. 2. Enter that frequency in VFO or store to a memory channel. 3. Monitor the channel; you only hear traffic when users transmit. [Elektroda, tape, post #18426333]
Do I need DCS/CTCSS on receive to monitor?
No. For general monitoring, turn off receive-side tone squelch. On many menus these are R-DCS and R-CTZS; set both OFF. Tone squelch filters audio to only matching tone and can hide calls. [Elektroda, Rezystor240, post #18426603]
I entered police, fire, and ambulance frequencies but heard only two police calls all day—is that normal?
Yes. Traffic can be sparse. One listener reported total silence for about 2.5 days. “If they have nothing to talk about, they don’t talk.” Hold on the channel and wait; your setup is likely fine. [Elektroda, Rezystor240, post #18426471]
Does moving the radio near a window or higher floor improve reception?
Yes. Place the radio by a window to reduce building losses. Higher placement improves line-of-sight and effective range. Face the display inward if you prefer discretion. Small placement changes can outperform menu tweaks. [Elektroda, Rezystor240, post #18426645]
Could the agency have switched to DMR and that’s why I hear nothing?
It’s possible. Some users migrate to DMR digital systems. If that occurs, an analog-only receiver will not produce intelligible audio on those channels. Consider a DMR-capable scanner to monitor such systems. [Elektroda, Rezystor240, post #18426471]
Can an analog FM radio decode DMR or other digital voice?
No. DMR is digital and uses two time slots within a 12.5 kHz channel. Analog FM cannot decode that modulation. You need a DMR-capable receiver or scanner to hear DMR voice. [ETSI TS 102 361]
What happens if I leave RX tone squelch enabled?
You may hear nothing, even with a strong signal. Tone squelch opens audio only when the programmed tone matches. For wide monitoring, disable RX tones so all audio passes through. [Elektroda, Rezystor240, post #18426556]
Is it legal to listen to police or ambulance channels?
Check local law. Many jurisdictions restrict listening to non-public broadcasts or decoding encrypted traffic. Never share or misuse what you hear. When unsure, monitor only permitted services. [Ofcom: Use of Radio Scanners]
Any quick way to test if my programming works?
Hold on a known active channel and wait. Public safety channels can be quiet for long stretches, so silence does not prove a setup issue. When users transmit, your squelch should open and audio should play. [Elektroda, Rezystor240, post #18426471]
Where can I find the right frequencies to program?
Use official lists or trusted community databases. Search by country, region, or service type. Confirm that entries are current, because agencies change systems or migrate to digital. Program only what you may legally monitor. [RadioReference Frequency Database]
Any discreet placement tips when listening at home?
Yes. Put the radio at a window for better signal, but face the display inward. This keeps the screen from drawing attention while you monitor. [Elektroda, Rezystor240, post #18426645]
