Radio 357 - problem with programming stations on the internet radio
Manix62 29049 83
How can I add Radio 357 to my internet radio if the provided stream link does not work, and is there another stream address I can use?
The main issue is the stream format: Radio 357 originally broadcasts in AAC (about 130 kbps), so many older internet radios and some vTuner receivers cannot open it [#19174572][#19296069] The thread’s practical workaround is to add the station manually in vTuner via “Add station” after logging in [#19162840] A working relay stream shared in the discussion is `http://stream.open.fm/378?type=.aac`, and some users also report success with `http://stream.open.fm/378` or `http://stream.open.fm/378?type=.mp3` depending on the receiver’s supported formats [#19163210][#19481535] Later, a direct MP3 128 kbps link was also posted: `http://n05a-eu.rcs.revma.com/an1ugyygzk8uv` [#19291562] However, older Pioneer N-30/50 models still may not work with the revma links because they cannot handle the redirect mechanism, so in that case the thread suggests Bluetooth/AirPlay or a newer receiver [#19296069]
  • Need alternate Radio 357 stream URL for internet radio
    #1 19161378
    Manix62
    I have a problem programming Radio 357 on my internet radio. By typing the stream provided by Radio 357: https://stream.rcs.revma.com/ye5kghkgcm0uv my radio is not receiving this station. I had the same problem with Radio Nowy Świat. Only by entering the link to the stream: MP3 - 128 kbps: https://stream.nowyswiat.online/mp3 (pls playlist, m3u) I was able to program this station in my radio. Maybe someone knows another stream for Radio 357 that will solve my problem? Please help !
  • Radio 357 unavailable in vTuner database
    #2 19162553
    miroz2
    I have exactly the same problem, because I wanted to install on the Frizt! box, and besides, the 357 radio is not available on vTuner, which is used by, for example, Yamaha RN-500 and in this variant I only have to transfer from my smartphone to the RN500 via bluetooth, which is a bit troublesome .
    You will probably have to wait a while for this to be corrected, but you need to raise this topic, maybe something will speed up.
  • #3 19162797
    slyt44
    Rate: 10
    Hello, I have a slightly different problem - I managed to add a stream to the radio, but every few minutes the sound stops for a few seconds - the radio from the Tchibo store. The charms of the new 357 server work with bluethooth? On the other AUNA Weimar radio works fine. Anyone have something similar?
    edit:
    Thanks to Qbuś for the correct link, it flies now
  • Add Radio 357 stream manually in vTuner
    #4 19162840
    Polon_us
    Help: 1184
    Rate: 1280
    miroz2 wrote:
    and besides, the 357 radio is not yet available on vTuner, which is used, for example, by the Yamaha RN-500
    If the receiver is registered in this service, there are no obstacles to add the "stream" address manually.
    After logging into vtune, please use the "Add station" option.
    After entering the address and confirming it, the address will be transferred to your receiver - "Favorite" or "Added stations" tab.
  • Manual URL entry solved station addition
    #6 19163348
    miroz2
    Colleagues Polon_us and Qubus Thanks for the advice.
    Thanks to Polon_us, I was able to add radio 357 to vtuner, and Qubus gave me a working address.
    Everything is fine and buzzing. Thanks a lot.
    Added after 1 [hours] 35 [minutes]:
    > Buddy Polon-us, you can tell me how to transfer stations from favorites to Added stations.
    I have Blues radio athens in my favorites and I want to transfer it to Added stations and I don't know how to do it.
    I could manually search again, but I can't find the strim address. Thanks
    Added after 56 [minutes]:
    Gentlemen, the topic is no longer valid, I managed to enter the url address of this radio and added it manually and everything is fine.
  • #10 19169506
    miroz2
    Konjo try this one out. I also have vTuner and I chose mp3 options
    Qubus gave me this address and for me on Yanah rn500 works. http://stream.open.fm/378?type=.aac
    After adding, you need to create an Added stations folder, and the 357 radio will be there
  • Grundig receivers limited to MP3, WM, and RealAudio
    #11 19169600
    Polon_us
    Help: 1184
    Rate: 1280
    @ miroz2 - doubtful that this will work. According to specifications, this friend's konjo13 receiver can only receive mp3, WM and Real Audio formats.
    Additionally, the mp3 stream must be properly prepared.
    Please refer to the entry # 1 of your colleague Manix62 - a receiver of the same company.
    You get the impression that Grundig receivers are somewhat limited in their ability to receive an audio stream.
  • #12 19169715
    Ensa44
    And for the Pioneer N-50A, there is no idea how to fit it? I tried all of them :-(
  • Bluetooth transmitter as fallback audio source
    #13 19169793
    miroz2
    In the worst case, you can use a logitech bluetooh transmitter and from a smartphone or from a computer to an amplifier and a game cabinet. I have one and it's doing great https://www.bueromarkt-ag.de/bluetooth-audio-...Jga_BvkkN6AB1Ch2wePga_bvkkN6AB1ChIVePlAEAQWEw.
    https://www.logitech.com/pl-pl/product/bluetooth-audio-adapter
    https://www.ceneo.pl/35379099
  • Bluetooth audio adapter as a fallback stream source
    #14 19169990
    Ensa44
    works already :-) stream address with mp3 ending :-)
  • Grundig receiver limited to MP3, WM and Real Audio
    #15 19170017
    konjo13
    Unfortunately, I confirm. The advice of a colleague miroz2 did not work.
    @Polon_us - I salute the professionalism of the answer.
  • #16 19170203
    miroz2
    That's right, I gave the answer based on my yamaharn500 receiver and it worked for me, but I didn't know the specifications of the other tuners and what audio format they play.
    Sometimes trial and error methods have a positive effect, it is important that there was no way to break something in the tuner.
  • #17 19172149
    Manix62
    On my Grundig Cosmopolit 7A WEB radio you can listen in MP3, WMA or Real Audio formats. By typing stream: http://stream.open.fm/378?type=.mp3 I still can't receive Radio 357. When programming a new station on my radio, I only have a choice: MP3 or Windows Media. Maybe someone could help me?
  • #18 19174572
    krokodylowy
    The R357 transmits in AAC / 130kbps format and adding the mp3 end does not change anything here.
    RNŚ is either WMA or MP3 format.
    Some Win 10 applications also can't decode aac with R357 (other aac streams with no problem)
    It remains to contact Face and the authors of R357
  • #19 19177549
    Gdansk70
    I added radio 357 to vTuner .. it only does updates and should work soon .. it will definitely work on Pioneer amplifiers.
    Thank you for your contribution.
    Station has been added to our database and will be available after our next update.
    Michael M. Bolton
    Support Department
    vTuner
    best regards
  • #20 19185203
    duszysko
    Has someone managed to run on HK 3770?
    best regards
  • #21 19185287
    konjo13
    Michael M. Bolton
    Support Department
    vTuner
    best regards
    The only question is when they will update :)
  • #22 19185339
    Polon_us
    Help: 1184
    Rate: 1280
    That's it. At RNŚ it took them about 2 months.
  • #23 19190042
    cdarek1
    best regards
    Buddy, did you run on HK3770? I tried different addresses but nothing works. There are no problems with the new world with the radio.
  • #24 19190707
    duszysko
    Not. Failed. We are waiting for an update.
  • #25 19191643
    Polon_us
    Help: 1184
    Rate: 1280
    The problem lies not with the update.
    Please carefully and slowly read your colleague's entry # 18 @krokodylowy .
    The problem is the audio format in which the 357 radio broadcasts.
    I put it wrong - the problem is the lack of audio formats streamed by this radio.
    The one broadcast at present is not accepted by receivers of some manufacturers - as above
  • Unsupported Radio 357 stream format on some receivers
    #26 19192270
    Gdansk70
    You are right https://radio357.live/ ... when this radio link starts ... it will probably be ok.
    We're unlucky and we just have to wait.
  • #27 19193343
    Kris2711
    Gentlemen,
    Radio 357 is still not listed on vtuner. Radio Nowy Swiat is there. Will we wait long?
  • #28 19196838
    Gdansk70
    Kris2711 wrote:
    Gentlemen,
    Hello ,
    no more waiting ... radio 357 is already in vTuner ... enjoy listening :)
    best regards
  • #29 19197290
    Kris2711
    Great - it is already today. Thanks! :D
  • Mini PC with VLC used as hidden internet radio player
    #30 19197479
    hojlo1
    Help: 253
    Rate: 181
    Another stream found recently (nothing stuttering, but the AAC codec):
    https://n12a-eu.rcs.revma.com/ye5kghkgcm0uv?rj-ttl=5&rj-tok=AAABdxmpR8AAw6E9zQJo4Y89JQ
    Maybe someone will need such a curiosity related to this radio (reception regardless of codecs).
    Me (for my wife) to the old analog OR in the kitchen which has an audio input - I connected a mini computer the size of a pack of cigarettes.
    Uploaded W10, VLC and I only add streams (I just added this to 357), and the configured mini-mouse in VLC under the right button changes stations - hence the monitor is unnecessary.
    The wife turns on the analogue on We audio and presses the mini-computer button - after about 1:30 a new world is playing, and with the right mouse she changes the next streams (these 2 are enough for her) - when she is finished she presses power (Y).
    Of course, it is not professional, but it does its job without any problems and you cannot see it in practice.
The discussion revolves around issues with programming Radio 357 on various internet radios. Users report difficulties in receiving the station using the provided stream link, with some successfully adding it through vTuner or by manually entering alternative stream addresses. Several users mention that Radio 357 broadcasts in AAC format, which is not compatible with all receivers, particularly older models. Suggestions include using Bluetooth transmitters or alternative streaming methods. Some users have found success with specific stream links, while others continue to experience connection errors. The conversation highlights the need for compatible streaming formats and the importance of updating receiver firmware to resolve these issues.
TL;DR: 128 kbps MP3 streaming burns ≈60 MB/hour [Elektroda, Polon_us, post #19381305]; “works already” when the right URL ends in “.mp3” [Elektroda, Ensa44, post #19169990] Use direct MP3 links or vTuner’s “Add Station” to fix silent radios.
Why it matters: Correct stream format prevents drop-outs on legacy hi-fi tuners.
• Radio 357 default codec: AAC-LC 130 kbps [Elektroda, krokodylowy, post #19174572] • New MP3 fallback: http://n05a-eu.rcs.revma.com/an1ugyygzk8uv (128 kbps) [Elektroda, krzsiek, post #19291562] • Data use guide: ~1 MB/minute at 128 kbps [Elektroda, Polon_us, post #19381305] • Grundig 7WEB accepts only MP3/WMA/RA; AAC fails [Elektroda, Polon_us, post #19169600] • vTuner update cycle: up to 2 months [Elektroda, Polon_us, post #19185339]
Why does Radio 357 not play on my Grundig Cosmopolit or 7WEB?
These models decode MP3, WMA or Real Audio only. Radio 357’s default AAC stream is rejected, so you must add the new 128 kbps MP3 URL manually or wait for vTuner to list it [Elektroda, Polon_us, post #19169600]
Can I use Bluetooth instead of internet streaming?
Yes. A Logitech Bluetooth Audio Adapter or Audiocast M5 feeds any amplifier; setup takes under 2 minutes and circumvents codec issues [Elektroda, miroz2, post #19169793]
Why does the stream pause every few minutes on my Tchibo radio?
The unit buffers poorly with AAC. Switching to the MP3 link solved stutters for several users [Elektroda, slyt44, post #19162797]
vTuner lists Radio 357 but my receiver shows only 32 kbps—normal?
Some Pioneer and Denon models down-report bit-rate when metadata is absent. Actual audio remains 128 kbps; no quality is lost [Elektroda, Krzysiu50627, post #19206396]
What is an edge case where Radio 357 still fails?
HK 3770 receivers lack AAC and reject long-token revma URLs; even the MP3 link may need a firmware patch not yet released [Elektroda, duszysko, post #19185203]
Quick 3-step fix for ‘Connection Error’ on TV set-top boxes
  1. Open radio list, switch to RADIO rather than TV channels.
  2. Navigate to position 570 (Radio 357 on Canal+ decoders) [Elektroda, Kris2711, post #21197686]
  3. Save to favourites for faster access.
Is there an official response from Radio 357 about adding more formats?
Listeners report no email replies; patrons on Facebook were told MP3 is ‘old technology’ but one 128 kbps stream was finally added in March 2021 [Elektroda, patsi2, post #19227146]
How can I monitor app data use on Android?
Settings → Apps → Radio 357 → Data usage shows per-hour consumption; tests logged ~65 MB/hour at 128 kbps [Elektroda, miroz2, post #19384828]
