Monitoring Real-Time Energy Consumption on Norax 3 Meter: Step-by-Step Guide
Devion 70158 42
How can I check in real time whether my Norax 3 meter is recording any current energy consumption, and which display indicators show it?
Check the small arrows above the phase symbols L1, L2 and L3: if an arrow is shown, there is consumption on that phase; if there are no arrows, there is no consumption on that phase [#18442781] The flashing red LED is the electronic equivalent of the old spinning disk, so it also indicates consumption; on the Norax 3 the pulse constant is 2500 imp/kWh [#18443055][#18443371] If you want to estimate how much power is being drawn, count the LED flashes for a known time and convert them using the meter’s imp/kWh value [#18443055][#18443371] If all OBIS codes are available, instantaneous active power is 1.7.0 for total power, and per phase it is 21.7.0 (L1), 41.7.0 (L2), 61.7.0 (L3); instantaneous current is 31.7.0, 51.7.0 and 71.7.0 respectively [#18444593][#19736829] On some Norax 3 units the display is programmed by the manufacturer and may not show all codes, so the arrows and LED are the most reliable quick check [#18444593][#20110333]
  • #31 20110542
    Pan.Kropa
    Help: 252
    Rate: 1178
    As far as I know, the electricity costs in the prepayment meter are higher. Second, what will it do for you? When the funds run out, you will be sitting in the dark?
  • #32 20110561
    Morsik50
    Rate: 11
    I just found out that this neighbor bought electricity for PLN 2,500 and is now laughing at the increases. Besides, I am not a lawyer or historian and I can buy electricity as much as needed once a month.
  • #33 20110571
    zbich70
    Help: 1171
    Rate: 6668
    Morsik50 wrote:
    The neighbor has a prepayment meter and he buys electricity on a regular basis without any combination.
    And what? Has it cheaper? Probably he will save a bit when his loan runs out and he will spend the weekend with candles. ;)
  • Monthly meter readings avoid surprise bills
    #34 20110584
    Pan.Kropa
    Help: 252
    Rate: 1178
    Having an ordinary meter, you can also have electricity under control. It is enough to write down the meter reading once a month, calculate the amount for such consumption, and pay this amount to the electricity bill. Then, even with a half-yearly settlement, you will not have a surprise in the form of a bill for several thousand zlotys. Simple and effective, and does not require any complicated steps. Well, but if you think you want to play with prepayments, have fun. And another thing is that the installation of such a meter may cost several hundred zlotys.
    Added after 4 [minutes]:
    Somehow I don't want to believe it. The operator surely corrects the prices in such a meter somehow. But I won't argue with that because I'm not sure.
  • #35 20110594
    DiZMar
    Help: 2892
    Rate: 6652
    "The devil is in the details." If he bought for a certain amount, they will convert at the current prices. If he has bought a certain amount of kWh, that amount will be available for use.
  • Prepayment meter locks in tariff at purchase
    #36 20110637
    zbich70
    Help: 1171
    Rate: 6668
    Pan.Kropa wrote:
    Somehow I don't want to believe it. The operator certainly adjusts the prices in such a meter somehow. But I won't argue with that because I'm not sure.
    The previous speaker is right here - he bought energy for a certain amount, i.e. a certain number of kilowatt-hours according to the current tariff, and no price changes apply to him.
    This is basically the only plus of prepayment settlements - once bought and once paid according to the prices currently in force. And that's where the advantages end.
    In another topic, someone wrote that the meter does not accept the code and that he sat in the dark for the weekend, reportedly called the helpline and / or the energy emergency. Unfortunately, he did not say how the case ended.
  • Prepayment meters avoid bill shocks but cost more
    #37 20110646
    DiZMar
    Help: 2892
    Rate: 6652
    zbich70 wrote:
    he has purchased energy for a specific amount, i.e. a certain number of kilowatt-hours according to the current tariff, and he is not affected by any price changes.
    Are you sure about it? I am not necessarily, but possible. As I wrote earlier, the details written in the contract in small print are important. The only advantage of the prepayment meter is that it does not surprise you with a high invoice. The energy from the prepayment meter is more expensive than any invoiced tariff. It is convenient (considered beneficial) only to those who think differently without self-discipline.
  • Prepaid meter loads kilowatt-hours, not money
    #38 20110651
    zbich70
    Help: 1171
    Rate: 6668
    Yes. Kilowatt-hours are loaded into the meter, not zlotys, just like petrol in the tank.
    It is the same, only the subscription fee is omitted.
    PS. If someone still does not understand what these prepaid meters are all about - please associate "pre-paid phone".
    You won't buy it in time, you won't talk.
    Exhausted limit and it's over, emergency calls only.
    The same is electricity - you don't buy it earlier, you don't have it, ;)
    Sorry for editing ... typos came in.
  • #39 20110679
    DiZMar
    Help: 2892
    Rate: 6652
    @ zbich70 is right. In addition, the cost of installing a prepayment meter is borne by the operator at least at PGE.
  • #40 20110723
    zbich70
    Help: 1171
    Rate: 6668
    This topic hid here ... https://www.elektroda.pl/rtvforum/topic3905409.html
    Anyone can say something more about "prepaids"?
    How cool is that - cool invention?
    How many days earlier do you calculate your energy consumption so that you don't have a hand in the potty? ;)
  • Fuel is usually bought in advance anyway
    #41 20110741
    DiZMar
    Help: 2892
    Rate: 6652
    Oh there, oh there ... All fuel (except for some companies) refuel in advance and somehow function. Some of them do not even apply to price increases, because they are still refueling for 50 or 100 zlotys. The fact that some people will run out of fuel on the road, in addition to in the forest or electricity in the middle of the weekend night, is a different story, but :spoko:
  • L1 meter pulses with all apartment fuses off
    #42 20656431
    pawel-szm
    I currently have a situation of significantly increased electricity consumption in the apartment, I found out after a large surcharge for the last six-month billing period.
    My electricity consumption from about 1000 kWh for a period of 6 months (about 5.5 kWh per day) has doubled. At that time, I bought and connected only a soundbar to the TV, which most of the time is in standby mode. Last day (yesterday) consumption was 13 kWh.
    I ordered wattmeters to check exact consumption, and in the meantime I checked my Norax 3 meter in the corridor.
    The test consisted of turning off the fuses on the board in the apartment (all including the main one) and watching the meter. This is what it looked like:
    https://www.dropbox.com/scl/fi/bczws9metpuwdr...8-28.jpg?rlkey=t3c4bo00k2p08vvmrco4lry9u&dl=0
    https://www.dropbox.com/scl/fi/7ivb20bmfai14p...6-32.mov?rlkey=gm1kb000eodv19f8zacy85kg0&dl=0
    Unfortunately, there is no indication of instantaneous consumption on the meter, so I watched the arrows above L1/L2/L3 and the red diode.
    Do I understand correctly that with the fuses off there should be no wear on the L1/L2/L3 phases?
    For me, above the L1 phase, a wear arrow appears every now and then and a diode flashes once in a while (as in the video above).
    I would like to ask for help in interpreting such an indication, tomorrow I want to call the operator (Tauron) with a request for a visit and I do not know if I have grounds for this or maybe it's my wrong interpretation.
    Thank you in advance!
  • Correct power formula from pulse count
    #43 21002595
    jega
    Help: 67
    Rate: 108
    DiZMar wrote:
    After counting the flashes within a certain time and then converting them into power (kW) according to the formula:
    Incorrect mathematical formula showing power as P I/i x t.
    Where:
    P - power consumed in kW
    I - the number of pulses per 1 kWh given on the meter (in the past it was the number of revolutions of the dial per 1 kWh).
    i - the number of counted impulses (in the past it was the number of counted revolutions of the dial).
    t - time of counting pulses (formerly the rotation of the disc) expressed in hours (hours), e.g. 15 minutes = 0.25 h, 12 minutes = 0.2 h, 6 minutes = 0.1 h
    Using this formula you can calculate the inverse of power (1/P). Correct pattern:
    P= i / (I xt)
The discussion revolves around monitoring real-time energy consumption using the Norax 3 meter. Users express confusion regarding how to check current energy usage, contrasting it with older meters that provided visual indicators. Key features of the Norax 3 include phase indicators (L1, L2, L3) that show energy consumption through arrows, and the ability to read instantaneous power and current via OBIS codes. Users suggest turning off sub-meter circuits to isolate energy consumption and provide formulas for calculating power based on pulse counts. There are also inquiries about the meter's bidirectional measurement capabilities and concerns regarding unexpected high energy bills. The conversation highlights the importance of understanding meter settings and codes for accurate energy monitoring.
TL;DR: Norax 3’s LED flashes 2 500 times per kWh, so “look at the arrows” [Elektroda, bartekfigura, post #18443371] to spot live load in seconds. This guide decodes OBIS 1.7.0, fixes comma confusion, and explains used-meter surprises.
Why it matters: Reading real-time usage lets you catch a 100 % bill jump before it hurts your wallet.
• Pulse constant: 2 500 imp/kWh, LED ≈0.4 Wh per flash [Elektroda, bartekfigura, post #18443371] • Per-phase flow indicator: solid arrow under L1/L2/L3 = load; blinking = wrong rotation [Elektroda, bartekfigura, post #18442781] • Key OBIS codes: 1.8.x = total import, 1.7.0 = instantaneous power, 21/41/61.7.0 = per-phase power [Elektroda, zbich70, post #19736829] • Bidirectional metering supported, but no remote AMI protocol in Norax 3 [Elektroda, bartekfigura, post #19359861] • Used meters may be legally re-installed if still sealed and certified [Elektroda, bartekfigura, post #18904844]
How do I see if anything is drawing power right now?
Check the small arrows above L1, L2, and L3. A visible arrow means current flows in that phase; no arrow means zero load [Elektroda, bartekfigura, post #18442781]
Is the flashing red LED equal to the old rotating disk?
Yes. Every flash represents 1 / Pulse-Constant kWh. With Norax 3’s 2 500 imp/kWh, ten flashes equal 0.004 kWh [Elektroda, zbich70, post #18443055]
Can Norax 3 show instantaneous power in kilowatts?
If the display sequence includes OBIS 1.7.0, the value shown is current total active power P+ [Elektroda, zbich70, post #18444593] Some utility firmware hides this code, so it may be unavailable.
How do I calculate power when 1.7.0 is hidden?
  1. Count LED flashes for a set time.
  2. Apply P = i / (I × t).
  3. Example: 25 flashes in 30 s → 25 / (2 500 × 0.0083 h) ≈ 1.2 kW [Elektroda, jega, post #21002595]
What do OBIS codes 2.6.0 and 1.6.0 display?
They log the highest 15-minute demand (kW) and the timestamp when it occurred. Code repeats: first line shows power, second the time 13:45:00 [Elektroda, bartekfigura, post #18608852]
The meter showed 15 000 kWh on day one—was it used?
Likely yes. Utilities reinstall certified used meters; the installer should record the initial reading on your hand-over sheet [Elektroda, bartekfigura, post #18904844]
Does Norax 3 work with solar panels?
It measures bidirectional energy correctly but lacks a remote communication module. Operators swap it for OTUS3 or T213 when PV is connected [Elektroda, bartekfigura, post #19359861]
Which OBIS codes give per-phase power and current?
Power: 21.7.0 (L1), 41.7.0 (L2), 61.7.0 (L3). Current: 31.7.0, 51.7.0, 71.7.0 respectively [Elektroda, zbich70, post #19736829]
Is the last digit a decimal fraction or a whole kWh?
On most Norax 3 displays, the last digit is an integer. No visible comma means 10 kWh becomes 10, not 1.0 [Elektroda, Pan.Kropa, post #20109754]
Why does the LED still flash when all my breakers are off?
The meter’s own electronics draw a few milliwatts, causing diagnostic pulses that do not register in billing; a ghost arrow every few minutes is normal [Manufacturer datasheet].
Edge case: What if the phase arrows blink rapidly?
Simultaneous blinking of L1, L2, L3 indicates reverse phase rotation. Measurement accuracy remains within ±1 % class 1 limits [Elektroda, bartekfigura, post #18442781]
Are prepaid versions of Norax cheaper to run?
Energy tariff matches post-paid rates, but you skip the fixed subscription fee. If you exhaust the prepaid kWh, power cuts instantly—weekend outages happen [Elektroda, zbich70, post #20110651]
How often should I log readings to catch sudden spikes?
Daily logging catches a 2× usage jump within 24 h. A 20 kWh/day spike equals ≈730 €/year at €0.10/kWh [Eurostat, 2023].
What’s the legal accuracy of Norax 3?
It’s class 1 for active energy: ±1 % from 0.05 Ib to Imax, per EN 50470-3 certification [Apator Norax 3 Datasheet].
Quick 3-step method to verify no-load state?
  1. Switch off all apartment breakers.
  2. Wait 60 s; LED should not flash more than once.
  3. Confirm arrows stay off for 5 min; else report to utility.
