Cheapest Methods and Schematics for Remote Reading of Energy in Norax 3 Meter
robo1973 19665 8
  • #1 18860116
    robo1973
    Rate: 59
    Hello !!!
    How to remotely read the amount of consumed and produced energy in the Norax 3 meter in the simplest and cheapest way
    Maybe a schematic of the device. There are optical heads, but a bit expensive. Maybe someone has a diagram of such a head.
    Regards !!
  • #2 18862330
    bartekfigura
    Level 30  
    Help: 112
    Rate: 523
    This meter has no remote protocol. Only the optical head or an external sub-counter remains.
  • #3 18867940
    robo1973
    Rate: 59
    Apparently they have remote reading via GSM? It hurt my ears so much.
    I read that you can go to a certain operator's website and, after logging in to your account, gain access to information about the electricity consumed and produced
  • #4 18868655
    bartekfigura
    Level 30  
    Help: 112
    Rate: 523
    remote reading via GSM is Otus meters, not Norax
  • #5 18868847
    robo1973
    Rate: 59
    I don't know why at PGE they told me that the collector would no longer be walking, they would only remotely read the energy consumption and production
  • #6 20139112
    mistrzipan
    I also have Norax 3 in Wrocław and the Zael company (zael.pl) reads these meters somehow remotely via GSM. Maybe Norax 3 has some cumulative module that allows you to read from many meters at once. I don't see it in the meter cupboard, so maybe it's hidden somewhere.
  • #7 20139181
    zbich70
    Help: 1171
    Rate: 6664
    But you gave advice. It's hidden somewhere... ;)
  • #8 20139218
    mistrzipan
    I only suggested that it could be a separate module, so you can ask the supplier, the manufacturer. I tell you where to look. Does every post have to be a 100% answer to the given problem?
  • #9 20139231
    zbich70
    Help: 1171
    Rate: 6664
    Especially when the query was two years ago...
The discussion revolves around the remote reading of energy consumption and production using the Norax 3 meter. Users highlight that the Norax 3 does not support a remote protocol, leaving options limited to optical heads or external sub-counters. Some participants mention that remote reading via GSM is associated with Otus meters, not Norax. However, one user notes that the Zael company can read Norax 3 meters remotely, suggesting the possibility of a hidden cumulative module for multiple meter readings. The conversation also touches on the confusion regarding the availability of remote reading services and the role of energy suppliers.
