Vectra Technicolor cga2121 router / bridge + connecting a second router = troubl
MichalP2020 12804 6
  • Second router or bridge mode cuts speed to 25–50 Mbps
    #1 18446448
    MichalP2020
    I am asking for help because, unfortunately, no one can advise me.
    I am connected to a 100Mbps network from vectra using the white Technicolor cga2121.
    I tested the speed in router or bridge mode and it is normal. Speedtest shows me the right one
    speed is ok. What I know is unfortunately there is no access or login to the Technicolor cga2121 device to change the settings.
    I don't know the root password, so I decided to connect a regular router and change the cga2121 operation mode to bridge.
    After connecting, my speed drops to 25-50 Mb / s. The speed drops regardless of whether the computer is on
    connected with a LAN cable or using the wifi of the second router. I have the same effect when I present
    cga2121 to standard router mode. I don't know why this is happening. I have tested a lot of devices and I'm not going to
    buy an expensive router because I'm not sure if the quality will improve with the normal speed in the range of 100 Mb / s.
    Where could the error be? Bad cables? The cga2121 router is normally connected to the wan of the second router. Something specific
    setting? I really don't know. I haven't experimented with settings like MTU. I can't even introduce a lot.
    I don't know where to look for a bug.
  • #2 18446584
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Without providing the name of the second router, we also do not know if it is the fault of this equipment or something else.
  • #3 18446596
    MichalP2020
    The last one was Netgear WNR 2000 v5. But I have the same thing with others, e.g. linksys WRT610N v2. I tested 3-5 from this category. I know that these are old devices and they are old, but it should work. Only works under IPv4. I don't know if it matters. Quality Of Service is off.
  • #4 18446619
    KOCUREK1970
    Help: 3860
    Rate: 5488
    These are grandfathers, weak processors, a ridiculous amount of RAM - it won't squeeze any more.
    Either a new router with a 100Mb LAN / WAN port, or look for something with 1Gb ports.
  • #5 18446621
    MichalP2020
    But what exactly is braking speed? 100Mbit / s wan. Some are even 1000Mbit / s.
  • #6 18446646
    KOCUREK1970
    Help: 3860
    Rate: 5488
    @ MichalP2020
    The ports do not matter here, since the hardware router is too weak to send 100 Mb.
    There used to be a TPLink 1043NDv1 router, it had 1Gb LAN / WAN ports - so what, when the max max was possible, only 120Mb could be pushed through it.
  • #7 18455432
    MichalP2020
    I do not know how such speeds could be achieved in 2014. The device from vectra also belongs to the old models and somehow gives advice. What router is suitable for me to guarantee adequate data flow? Raspberry Pi 3B + or 4 is enough?
The discussion revolves around issues faced when connecting a second router to a Vectra Technicolor CGA2121 modem. The user reports a significant drop in internet speed from 100 Mbps to 25-50 Mbps after attempting to set the CGA2121 to bridge mode and connect a Netgear WNR 2000 v5 router. Other older routers, including Linksys WRT610N v2, were also tested with similar results. Responses suggest that the older routers may have insufficient processing power and RAM to handle higher speeds, recommending either a new router with 1Gb LAN/WAN ports or considering alternatives like Raspberry Pi for better performance. The user seeks advice on suitable routers to ensure adequate data flow.
