Troubleshooting: Poor WiFi on Technicolor CGA2121 with TP-LINK TL-WR1043ND Router & Vectra ISP
19siwy20 61476 40
How can I fix poor Wi‑Fi speed and high ping on a TP‑LINK TL‑WR1043ND behind a Technicolor CGA2121 from Vectra, and does this router support 5 GHz?
The TL‑WR1043ND has only 2.4 GHz Wi‑Fi, so it cannot work at 5 GHz; if the 2.4 GHz band is crowded, that explains the low speed and high ping [#17458227] If you want better Wi‑Fi on a 150 Mb/s line, the advice was to use a router with 5 GHz and gigabit WAN/LAN, which usually means replacing this router rather than changing settings on it [#17458753] Put the Vectra Technicolor into bridge mode so it works only as a modem; then Wi‑Fi/DNS settings belong on the TP‑LINK, and the TP‑LINK WAN should get a public or 100.xxx address [#17692014][#17693184][#17695726] If you still see Vectra Wi‑Fi after bridge mode, it may be a separate service rather than your own network [#17694163]
  • #1 17457028
    19siwy20
    Hello, the description of my case will take a while, but in order.
    I have Internet from Vectra, I had a Cisco router so far, he was freaking out (wifi max 25 Mb / s) on the cable reaches 145 (connection 150). I was changed to a white technicolor cga2121 dual-band company and everything is ok, the cable for 150 Wifi comes to 120 - 130 sometimes but.... Ports are blocked. I called Vectra and they can't unlock so I have to hook up my router. I changed the settings from the router to the bridge, I connected my TP-LINK TL-WR1043ND router, I checked the wifi channel and here the problem appears. On the ok wifi cable it happens that it has a 5-10 Mb / s ping 200 ? To make it clear, I did not fumble (the firmware is up to date), I changed the name, set the password protection and changed the channel. What to do?? What else needs to be changed in the router settings ?? And one more question, I can currently see the 2.4 and 5 GHz wifi network when I connect the wifi router, is there one question that works at 5 GHz ??
    Thanks in advance for your help.
  • #3 17457133
    makosuu
    Help: 369
    Rate: 370
    What type of router did you connect to, what address does it get on the WAN?
  • #4 17458227
    KOCUREK1970
    Help: 3861
    Rate: 5489
    19siwy20 wrote:
    I have internet from Vectra
    Then first make sure that Vectra gives you a public IP - without it, port forwarding won't even work on your router.
    This TP Link has wifi only at 2.4 GHz - probably crowded in the area and therefore so poor.
    It is worth doing what a colleague asks for @sosarek in his second link and insert a scan of the wifi network here.
  • #5 17458694
    19siwy20
    I will try to sign off as soon as possible. Currently, I am on the phone with urgent matters at work. I have a public ip after connecting my router the ports are unlocked. Man, I thought that this router supports 5Ghz? I wanted it to work at this frequency because it was crowded at 2.4. What do you recommend ?? Buying another router ?? What?? If possible, inexpensive.
  • #6 17458700
    sosarek
    Help: 9320
    Rate: 15532
    Should be unlocked on the vendor's device if it says it can't, something is wrong.
    Z
    Pka, Poznań, 60-850
  • #7 17458753
    KOCUREK1970
    Help: 3861
    Rate: 5489
    You have a 150 Mb net - that is, the router must have 1 Gb WAN / LAN, it must have 5 GHz for you - you will hardly find anything below PLN 300 (maybe some TP Link, but I do not recommend it).
    You will only see if they are unlocked from the outside or by starting a given service.
    Vectra usually has a private IP and all ports are blocked.
  • #8 17458774
    19siwy20
    Oh it's expensive. I had the same on the black router from Vectra. Now on their router eg Torrents ports blocked on my green light. I called Kolesia from Vectra, he said that when he connects his router, then they will be unlocked, I don't know how it works, but it really is.
  • #9 17458942
    KOCUREK1970
    Help: 3861
    Rate: 5489
    19siwy20 wrote:
    Oh it's expensive.
    It is expensive, it is PLN 500-700 for a router - 3 cents is the minimum for something sensible (and there may be a problem for such money to buy a reasonable router with your needs).
  • #10 17459286
    19siwy20
    At the moment, no chance to buy such a router, any other proposal? Am I able to approach 100 Mb / s with some low ping on this router on 2.4?
  • #12 17691533
    czarny_alibaba
    Help: 5
    Rate: 151
    19siwy20 wrote:
    I changed the settings from the router to the bridge and connected my TP-LINK TL-WR1043ND router.
    How did you change to "Bridge" in which router menu option can this be changed?
    did you do it after logging in to the Vectra client page :?:
  • #13 17691582
    makosuu
    Help: 369
    Rate: 370
    On the Vectra page, you set up the bridge.
  • #14 17691742
    czarny_alibaba
    Help: 5
    Rate: 151
    @makosuu
    If I set "bridge" on the Vectra client page, will my previous settings be on the Vectra router?
    will they be reset to factory (default) from Vectra?
  • #15 17692000
    makosuu
    Help: 369
    Rate: 370
    And what do you have on their router for the settings?
  • #16 17692014
    KOCUREK1970
    Help: 3861
    Rate: 5489
    Then the modemorouter becomes just a modem, i.e. a medium that converts the Internet from coaxial cable to twisted pair.
    WiFi will not work, and connection to such a modem will only be possible via wired.
  • #17 17692283
    czarny_alibaba
    Help: 5
    Rate: 151
    DNS server provider changed :idea:
    and network name, wifi channel
    I have such a message
    When I approve the changes and I set the "bridge" on the Vectra client page, this is my previous setting
    will be reset to factory (default) from Vectra?
    The most important thing for me is to keep the changed DNS servers :!:
    The extra router I wanted to connect to is
    TP-LINK TL-WR740N (gargoyle software)
  • #18 17692488
    makosuu
    Help: 369
    Rate: 370
    But if you connect your router, what do you need any settings in the Vectra router? He will only be a modem.
  • #19 17692557
    czarny_alibaba
    Help: 5
    Rate: 151
    I approved the changes and set up the "bridge" on the Vectra client page
    now I have to wait until 24 hours. changes?
    Should the WiFi in the Vectra router be already blocked?
    When it comes to setting your DNS server providers, just change it in TP-Link?
  • #20 17692787
    makosuu
    Help: 369
    Rate: 370
    Well, on TP-Link you change DNS because it is the router then. The bridge mode is probably there.
  • #21 17692864
    czarny_alibaba
    Help: 5
    Rate: 151
    Wifi in the Vectra router should already be blocked?
    because I can see that wifi from Vectra is visible
    How to check if the Vectra router is already in mode bridge ?
  • #22 17693015
    makosuu
    Help: 369
    Rate: 370
    What IP allocates? In bridge mode, there is usually no Wifi.
  • #23 17693116
    czarny_alibaba
    Help: 5
    Rate: 151
    IP (192.168.1.1) is already after TP-LINK (wifi works)
    - but WiFi is still visible from Vectra?
    IP Vectra (192.168.0.1)
  • #24 17693184
    makosuu
    Help: 369
    Rate: 370
    The Vectra router should assign a public address or something from the 100.xxx pool on the WAN
  • #25 17693219
    czarny_alibaba
    Help: 5
    Rate: 151
    The router from Vectra on the WAN has allocated an address
    TP-Link WAN IP Address: 178.xxx.xx.xx
  • #26 17693290
    makosuu
    Help: 369
    Rate: 370
    It works in the bridge.
  • #27 17693580
    czarny_alibaba
    Help: 5
    Rate: 151
    Something is probably wrong, because I have WiFi available all the time for the Vectra router?
    from what you wrote is in bridge Vectra mode :!:
  • #28 17693738
    mmm4tt
    Help: 8
    Rate: 12
    Have you tried to disconnect the router from the power supply? I have technicolor tc7230 from Vectra and despite the bridge mode and the lack of Wifi service (after logging in to the client area I have written. Please be advised that this Wi-Fi network management panel is not available to you, because you do not have Wi-Fi service from Vectra) after pressing button on technicolor I can run Wifi. I haven't tried to connect and I don't even know the password.
  • #29 17694163
    KOCUREK1970
    Help: 3861
    Rate: 5489
    This is probably not strictly wifi, but something like WiFree with UPC - such additional wifi for other Vectra customers.
  • #30 17695573
    czarny_alibaba
    Help: 5
    Rate: 151
    What router-modem do you recommend from Vectra today?
The discussion revolves around troubleshooting poor WiFi performance on a Technicolor CGA2121 modem-router when connected to a TP-LINK TL-WR1043ND router, with Vectra ISP. The user initially experienced slow WiFi speeds with a Cisco router and switched to the Technicolor device, which improved speeds but had blocked ports. After configuring the Technicolor in bridge mode and connecting the TP-LINK router, the user faced high ping and low speeds on the WiFi network. Participants suggested ensuring a public IP from Vectra, checking WiFi channel congestion, and considering the limitations of the TP-LINK router, which only supports 2.4 GHz. The conversation also touched on the need for a better router to achieve optimal performance and the implications of using bridge mode on the Vectra device.
TL;DR: 2.4 GHz throughput can plunge from 120 Mb/s to 5-10 Mb/s in crowded blocks [Elektroda, 19siwy20, post #17457028] “This TP Link has wifi only at 2.4 GHz” [Elektroda, KOCUREK1970, post #17458227] Bridge mode plus a dual-band gigabit router restores full speed and open ports.
Why it matters: Picking the right mode and hardware prevents 90 % of speed-loss complaints.
• Vectra package tested: 150 Mb/s down / 145 Mb/s cable reality [Elektroda, 19siwy20, post #17457028] • TL-WR1043ND: single-band 2.4 GHz, N300, Gigabit WAN/LAN [TP-Link Spec, 2023]. • Technicolor CGA2121: DOCSIS 3.0 24×8, dual-band AC1200 [Technicolor Datasheet, 2022]. • Entry-level dual-band gigabit routers: ≈300 PLN (≈65 USD) [Elektroda, KOCUREK1970, post #17458753] • Bridge mode hands out ONE public IPv4; extra devices need a router [Elektroda, KOCUREK1970, post #17692014]
Why does my TL-WR1043ND deliver only 5–10 Mb/s over WiFi?
The router works solely on congested 2.4 GHz. Neighbours share the same 13 channels, so effective speed drops to 5–10 Mb/s even though cable hits 150 Mb/s [Elektroda, 19siwy20, post #17457028]
How can I check if the Technicolor CGA2121 is really in bridge mode?
Connect a PC directly; you should obtain a public IPv4 (e.g., 178.x.x.x). If you still get 192.168.x.x, bridge is off [Elektroda, czarny_alibaba, post #17693219]
Will WiFi on the CGA2121 turn off after enabling bridge?
Bridge usually disables WiFi, yet Vectra may keep a separate public hotspot (similar to UPC’s WiFree) active [Elektroda, KOCUREK1970, post #17694163]
Can I keep my custom DNS when switching to bridge?
Yes. Set the preferred DNS on your own router’s WAN page; the ISP modem passes traffic unchanged [Elektroda, makosuu, post #17692787]
What affordable router should I buy to exploit 150 Mb/s and 5 GHz?
Choose any dual-band, gigabit-port model rated AC1200 or higher—market price around 300 PLN [Elektroda, KOCUREK1970, post #17458753]
Why are my torrents green on the TP-Link but red on the ISP modem?
Your TP-Link receives the public IP, so NAT/port-forward rules work. The ISP modem holds private IP ranges that block inbound ports [Elektroda, 19siwy20, post #17458774]
Is it possible to hit 100 Mb/s on 2.4 GHz?
Only in ideal conditions. Average real-world 2.4 GHz tops at ~60 Mb/s due to protocol overhead [SmallNetBuilder, 2021].
Edge-case: my UniFi AP allows only one WiFi client when connected to a bridged CGA2121—why?
Bridge gives one public IP. If you wire an AP instead of a router, each WiFi client begs for another IP, so only the first works [Elektroda, KOCUREK1970, post #19626345]
How do I put the CGA2121 into bridge mode?
  1. Log in to Vectra’s client portal.
  2. Select Internet → Advanced → Bridge Mode → Enable.
  3. Power-cycle the modem and wait 5 min for a public IP [Elektroda, makosuu, post #17691582]
