Cost for Car Bodywork Services: Welding Thresholds and Stringers
Spawacz 139 fmb 27999 5
  • #1 18461158
    Spawacz 139 fmb
    Hello everyone.
    Maybe someone will tell me in the field of car bodywork how much you pay now for, for example, inserting whole thresholds, partial threshold elements, flying the floor and flying the stringer. A friend who has a second-hand car dealership brings me some old stuff for tinsmith corrections and that's what we had a bit of a fight about the price for these services 3 years ago and I stopped this work because he considered that for welding, let's say, the threshold, not only the whole part, but only the parts around the wheel front and rear, for such an el from his repair, he wanted to count me 25 - 30 zlotys for the insert and not much more for large fragments of the stringer. Recently, I again agreed to weld another car for him, but I didn't agree on the price again, and as usual, it turned out that the work was twice as much as it was supposed to be and now I'm afraid again that for so much money he will charge me a hundred. And now I welded the thresholds, not only the edges as usual, but also from the bottom, it is probably also a threshold and again in a few places the stringers and the floor. I blurred the whole bottom with bitekcem and inside I secured it with paint, outside it is supposed to be painted in color, I did not paint anything there. I'm going to try to post some pics soon, so I'd love to get a quote for my work.
    Cost for Car Bodywork Services: Welding Thresholds and Stringers Cost for Car Bodywork Services: Welding Thresholds and Stringers Cost for Car Bodywork Services: Welding Thresholds and Stringers
  • #2 18461574
    OPservator
    Help: 557
    Rate: 1247
    For the insert in the threshold + painting I gave 350 and it was already at the expense of a friend :)
  • #3 18465665
    genek1000
    Help: 289
    Rate: 1057
    For me, this kind of work takes hours. A hole, not equal to a hole.
    If anyone has any objections to your honesty (you'll be slacking, not working), go elsewhere.
    If you run your own workshop, the rate of PLN 50 / h is the minimum of the minimum.
  • #4 18467964
    Spawacz 139 fmb
    I don't run a plant or I'm not a varnisher, I'm just a welder and I do various jobs after work in my own garage, only that now the prices are changing so much that you can't keep up if you don't do it every day, and for me it's different, everything is done to make them pay. 😄😀 Thanks for greetings.
  • #5 18468216
    mazi0000
    Help: 32
    Rate: 109
    Count on PLN 60 per hour, if he doesn't like it, let him look for someone else.
  • #6 18468223
    karolark
    Help: 702
    Rate: 2518
    I think $60/hr is the minimum
