Seeking Recommendations: Best Welding Machine for Car Bodywork Under $500
Zenon007 28599 6
  • #1 16491876
    Zenon007
    Hello. I wanted to ask for a welder to buy up to
  • #2 16491890
    nikusert
    Help: 699
    Rate: 1755
    Hello .
    If anything, buy a Migomat, not an electrode welder.
    Greetings.
  • #3 16492746
    ELSPAW_
    Rate: 9
    Definitely only MIG / MAG as a colleague wrote.
    for a good Chinese, that should be enough.
  • #4 16492796
    sanfran
    Help: 963
    Rate: 3004
    If you do not weld much, buy MIG with a non-gas wire. A lot cheaper, the bottle is falling off and storage.
    It's a bit worse (a bit, as some say), but it does. I slept on the doorsteps in the Nissan Micra car, the broken bumper in UAZ (only the holes were burnt at the electrode), small things home and it's OK.
    I bought the welding machine with a half-wire spool of wire (it is much more expensive than usual) and for a year, even half of it did not come out.
  • #5 16492812
    kortyleski
    Help: 957
    Rate: 3860
    That's what I once did to save on the cylinder and reducer. he flew this wire out of the garage faster than it was purchased. Unique g ****
  • #6 16492834
    sanfran
    Help: 963
    Rate: 3004
    Welding does not sell, so I do not care what you buy.
    In any case, it works with me.
  • #7 16493003
    WędkarzStoLica
    Help: 146
    Rate: 300
    The self-shielding wire can be given to the welder as punishment.
    Never in life consciously by choice.
    I recently bought a Chinese inverter for PLN 850 and I will tell you that it works beautifully.
    The question when it breaks down remains unanswered :D
    If you want to have weaker welding comfort but absolute reliability, then buy a heavy transformer.
The discussion centers around recommendations for welding machines suitable for car bodywork under $500. Participants emphasize the preference for MIG/MAG welders over electrode welders, highlighting the advantages of using MIG with non-gas wire for cost-effectiveness and ease of use. A user shares their experience with a Chinese inverter welder, noting its reliability despite concerns about longevity. The conversation also touches on the practicality of self-shielding wire and the benefits of heavier transformer welders for consistent performance.
