Xiaomi Redmi Airdots: Right Headphone No Sound Despite Successful Connection
sandra.666 29448 6
  • #1 18484913
    sandra.666
    Today the awaited Redmi Airdots headphones came to me. Everything's cool until you try to connect to the phone. Namely - the left earphone sounds without any problems, while the right earphone does not make any sounds, even though it works. Only at first it worked after a few tries, but literally 3-5 seconds. I've done a reset several times, all according to the instructions and advice of other users.
  • #2 18485059
    bogdan2491
    Help: 52
    Rate: 97
    At the beginning, I suggest trying to pair the headphones with another phone, if the problem persists, the only reasonable solution is a complaint.
  • #3 18485133
    staś pytalski
    Help: 760
    Rate: 1436
    Make sure the headphones are worn correctly first. This is the biggest problem for them to find themselves together. You need to understand the messages that are sent to us.
    Remember to remove the pairing before each new attempt to connect them to the phone. And the rights are the "lead" handset you need to connect to.
    Link that directions
    Try, or ask someone to help you.
  • #4 18486827
    sandra.666
    I tried to connect to another phone - same.
    I know how to connect them correctly, I have done what in the video already dozens of times, they pair correctly with the phone, the problem is that the right one does not make any sound, while the left one plays normally. I think there is a complaint :(
  • #5 18486885
    staś pytalski
    Help: 760
    Rate: 1436
    You can try to pair only the right earbud with your phone, not the left earbud to be sure.
  • #6 18488009
    sandra.666
    I've done this many times
  • #7 18488133
    staś pytalski
    Help: 760
    Rate: 1436
    If the law itself does not play, there is a complaint.
The discussion revolves around a user experiencing sound issues with the right earbud of their Xiaomi Redmi Airdots, which connects successfully but does not produce sound. Despite attempts to reset the device and connect it to different phones, the problem persists. Suggestions from other users include ensuring correct pairing, removing previous connections, and testing the right earbud independently. Ultimately, the user considers filing a complaint due to the malfunction.
