Xiaomi Mi True Wireless Earbuds Basic 2 - the right earbud does not work
Puszek2137 121317 5
  • #1 19335613
    Puszek2137
    Yesterday, while using the headphones, the right earpiece started to interrupt and after 5 seconds it seemed to have died and still does not work, does not respond to clicks, hard resets and inserting into the cassette. Someone has an idea how to fix it or have it serviced (I will only add that they have 3 days of headphones)
  • #2 19342652
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    As new headphones, there is no need to even think about it - a guarantee. Whether it's a hardware or software problem, it doesn't matter - you paid for working headphones, not for those that, for some reason, may suddenly stop working.
  • #3 19413241
    orgen1
    Rate: 26
    I put both in the charging base. I connected the charger One diode did not burn at all, nothing helped me when I pressed it and kept it pressed for some time. After a few attempts, it failed and it's ok
  • Right earbud shows charging but stays unresponsive
    #4 19529706
    MiloszGajda
    Rate: 80
    I also have a problem with one (right) earpiece. It does not react to any pressings, resets etc., it does not play. After inserting it into the charging station, the station's diode shows as if it is charging and the handset's diode flashes at a steady pace, but the brightness is minimal, you can only see it in a large shade. The left one responds elegantly to everything, plays, and the LED gives a very strong light. Anyone met with something like this?
    Unfortunately, this is a company gift and I do not have a receipt to use the warranty and I will say that I liked it ..
  • #5 19587153
    HubertSosnowski
    Rate: 34
    Put 2 headphones into the box and connect the charger. Hold the handset that is not working for a few seconds as if you wanted to press it against the box. After a few repetitions, it worked. If it does not work, press for at least 30 seconds. Just be careful not to push too hard so as not to spoil anything.
  • #6 19832678
    agaspa1976
    Rate: 14
    I had a similar problem with the right handset did not react to anything reset and charging in the base did not help. It only set off when the second one was discharged, and I brought both of them into the landing base. Then, surprisingly, the law also begins to load. For now, both work.
