Hello, what application do you recommend for the Huawei inverter.
Glesko6 47217 19
Which app should I use to monitor a Huawei inverter?
Use Huawei’s FusionSolar app, including the Android version, and first make sure the inverter is configured and connected to the service [#18539448] If you want an app that connects directly to the inverter, the thread also mentions SUN2000, and Fusion Home does the same thing as SUN2000 [#19392498]
  • #1 18533718
    Glesko6
    Rate: 24
    What application do you recommend for the Huawei inverter?
  • #2 18533854
    MichałS
    Level 36  
    Help: 259
    Rate: 689
    Which application should you use?
    If the monitoring is a PV monitor.
  • #3 18533860
    Glesko6
    Rate: 24
    For previewing daily performance work.
  • #5 19392371
    black6666
    Rate: 23
    Only FusionSolar has been crashing all the time and unable to login.
    He's not very good.
    And there is nothing better?
    Even in the inverter, they did not give any display.
    An inverter for thousands of dollars, and savings on the display for a few zlotys!
  • #6 19392498
    rokbok
    Level 40  
    Help: 654
    Rate: 1037
    I do not need a display there, there is the Fusion Solar app, they are currently changing the server because of problems with using it, by the end of April it should be ok.
    There's a Sun 2000 app that logs directly to the inverter, there's a Fusion Home app that does the same thing as SUN 2000.
  • #7 19392617
    black6666
    Rate: 23
    I do not need the display either, but it could be for that crazy money what it costs.
    But the app sucks from the start, and I've had solar farm for over a year.
    So when will it finally work properly?
  • Huawei server switch should fix FusionSolar issues
    #8 19392893
    rokbok
    Level 40  
    Help: 654
    Rate: 1037
    After all, I wrote above that by the end of April, Huawei will switch to a new server and the troubles should end, then the Fusion Solar app should be updated to a completely new one, we will see how it will look in practice.
    Without exaggeration, they are more expensive, they are worse and basically when it does its job it is ok, the matter of the application is a separate topic, but it goes better, I am optimistic and I advise you to be one too, life is then easier, more pleasant, more sunny ;) .
  • #9 19392906
    black6666
    Rate: 23
    Ok, if I have been waiting so long, I will wait until the beginning of May. Nothing will happen to me.
    So when there is a new application in the download store, it will be known that it is already peppered?
  • #10 19392942
    rokbok
    Level 40  
    Help: 654
    Rate: 1037
    Probably yes, but you can download from the attachment below, after download change the extension from * rar to * apk.
    • com.huawei.smartpvms.2103051446.rar (92.69 MB) You must be logged in to download this attachment.
  • #11 19396315
    mis_dj
    Rate: 22
    Today (4/23/2021) I installed. I do not know about you, but I have a message saying that I should connect my phone to the Internet (I will add that I am still connected to the Internet). It is not possible to log in on both WIFI and data transmission.
  • #12 19396335
    black6666
    Rate: 23
    I have the same for a few days as I installed it.
  • Change Huawei inverter server to intlobt.fusionsolar.huawei.com
    #13 19396572
    rokbok
    Level 40  
    Help: 654
    Rate: 1037
    mis_dj wrote:
    I do not know about you, but I have a message that I should connect my phone to the Internet
    You would have to change the server on the inverter from "intl.fusionsolar.huawei.com" to "intlobt.fusionsolar.huawei.com", then the app will work, for how long I do not know because until 28-04-2021 Huawei changes the server to which it is not known.
  • #14 19400131
    black6666
    Rate: 23
    I changed this server address in this blue app and it still doesn't work and can't connect.
    I will see how it will be tomorrow.
    Anything else that needs to be done?
  • Huawei system update blocks FusionSolar login
    #15 19400170
    rokbok
    Level 40  
    Help: 654
    Rate: 1037
    And it won't work, for a simple reason, Huawei performs a system update, below info from them.
    "For a better user and service experience, we are updating the system from 6:00 PM April 23, 2021 to 8:00 AM April 26, 2021. During this period, you will not be able to log into the system. You must update your FusionSolar application after the upgrade is complete. We are sorry for any associated inconvenience. "
  • #16 19400228
    black6666
    Rate: 23
    Okay, we'll see how it works tomorrow.
    I think it will be fine in the end.
    So this orange application will be outdated, only the blue one?
  • #17 19403010
    Pulpet90
    "Rokbok"
    Thanks for the app file, it helped me how good there are such people.
    Huawei continues to update servers until 4/27/21 at 8.00
  • #18 19403388
    black6666
    Rate: 23
    Still won't connect. The user or password is invalid.
    As I enter the login in the e-mail address format, because I was logging in all the time, it is impossible.
    What's in this situation?
  • #19 19403642
    donpablo
    Please try again with the intl.fusionsolar.huawei.com server. I log in, although the data is downloaded with a delay.
  • Blue app may replace the outdated orange app
    #20 19406934
    pined
    Ok, we'll see how it works tomorrow.
    Hello, it is rather worse at the moment, it is still slow - or it does not work.
    In addition, I do not know if you can believe in the truth of the current gain, because the value minus the inverter current consumption (about 4%) and the maximum possible current production by the inverter (in my case with the inverter 5 max it is 5.5 and it shows as much as the panels do).
The discussion centers around recommended applications for monitoring Huawei inverters, specifically the FusionSolar app. Users express frustration with the app's performance, including frequent crashes and login issues. Huawei's official recommendation is to use the FusionSolar app, which requires proper configuration and connection to the inverter. Users mention alternative apps like Sun 2000 and Fusion Home, which also interface with the inverter. There are ongoing server updates by Huawei aimed at improving app functionality, with users hopeful for better performance post-update. Some users report issues with server connections and login credentials, indicating a need for troubleshooting during the transition period.
TL;DR: Use Huawei FusionSolar for monitoring; during 18:00 Apr 23–08:00 Apr 26 maintenance, logins failed; "You must update your FusionSolar application after the upgrade is complete." [Elektroda, rokbok, post #19400170]
Why it matters: This FAQ helps Huawei SUN2000 owners choose the right app and fix login/monitoring issues fast.
How do I preview daily production and performance?
Configure the inverter and connect it to the FusionSolar service. Then sign in to FusionSolar (web or app) to monitor your plant. Daily performance becomes available after successful commissioning and binding. [Elektroda, noogi, post #18539448]
Which app connects directly to the inverter (no cloud)?
Use the SUN2000 app to log directly to the inverter. FusionHome offers the same local functionality. “There’s a Sun 2000 app that logs directly to the inverter.” [Elektroda, rokbok, post #19392498]
FusionSolar keeps crashing or won’t log in—are there better options?
For local checks, use SUN2000 or FusionHome to bypass the cloud. For cloud monitoring, stay with FusionSolar while Huawei completes server changes. “By the end of April it should be ok.” [Elektroda, rokbok, post #19392498]
Why do I get “Connect your phone to the Internet” although I am online?
Huawei performed a system update that temporarily blocked logins. The window ran from 18:00 Apr 23 to 08:00 Apr 26. “During this period, you will not be able to log into the system.” Update the app after the upgrade. [Elektroda, rokbok, post #19400170]
How do I change the FusionSolar server URL on my Huawei inverter?
During the migration, switching servers restored access for some users.
  1. Connect to the inverter with the installer app.
  2. Change server from “intl.fusionsolar.huawei.com” to “intlobt.fusionsolar.huawei.com”.
  3. Save, reconnect, and retry the app. [Elektroda, rokbok, post #19396572]
After the upgrade, which server URL should I use?
Use intl.fusionsolar.huawei.com. Logins work, but data may refresh slowly. “I log in, although the data is downloaded with a delay.” [Elektroda, donpablo, post #19403642]
I see “User or password is invalid” right after the upgrade—what should I do?
Wait until the maintenance window ends and update the FusionSolar app. Huawei stated an app update was required after the upgrade. This resolved post-migration access for many. “You must update your FusionSolar application after the upgrade is complete.” [Elektroda, rokbok, post #19400170]
Will a new app version in the store mean the backend is ready?
A store release was used as a readiness signal during the cutover. You can also sideload the provided file by renaming .rar to .apk. “After download change the extension from .rar to .apk.” [Elektroda, rokbok, post #19392942]
Why can reported power exceed my inverter’s rating or seem too low?
Displayed gains can exclude inverter self-consumption, about 4% in one user’s case. Brief peaks (for example, 5.5 kW on a 5 kW inverter) may appear due to array-side readings. Treat live figures cautiously during platform issues. [Elektroda, pined, post #19406934]
When will the FusionSolar platform work properly again?
Huawei planned a server switch by the end of April with an app refresh. “By the end of April, Huawei will switch to a new server and the troubles should end.” [Elektroda, rokbok, post #19392893]
My data updates slowly after logging in—is that expected now?
Yes, shortly after logins resumed, users observed delayed data. This typically stabilizes after the backend cutover completes. “I log in, although the data is downloaded with a delay.” [Elektroda, donpablo, post #19403642]
Do Huawei inverters have a built-in display, or is the app the display?
Many installations rely on the app instead of an onboard display. One user noted they don’t need a display thanks to FusionSolar and SUN2000. Local access substitutes for a screen. [Elektroda, rokbok, post #19392498]
Is the orange FusionHome app obsolete, or is only the blue app supported?
FusionHome remains usable and serves the same role as the SUN2000 app. Both connect directly to the inverter for local checks and setup. [Elektroda, rokbok, post #19392498]
