Huawei SUN2000-10KTL inverter or Fronius Symo 10.0-3-M which one to choose?
krissgut 80961 114
How should I choose between a Huawei SUN2000-10KTL inverter and a Fronius Symo 10.0-3-M for a 10 kW PV system?
Choose Fronius if the price difference is small; several users with hands-on experience said it is the safer and more reliable choice, with better service support and warranty that can be extended to 20 years, while Huawei is typically limited to 10 years and one installer reported reset/communication problems with Huawei units [#18838292] [#18901170] Huawei was not dismissed outright—some users said it works well, is cheaper, and has no fan—but even then they still leaned toward Fronius (or SMA) overall [#18643001] [#18847521] Another practical point from the thread is that PLN 40,000 for a 10 kW system sounded high, so ask for a detailed itemized quote and compare panels, inverter, mounting, cables, and labour separately before deciding [#17679754] [#17680723]
  • #1 17678158
    krissgut
    Rate: 43
    Hello - I have the opportunity to buy the entire 10 kW PV system in good money, i.e. about PLN 40,000. the company offered me a Huawei Sun 2000 10Ktl waveform
    I have always thought about Fronius - my question is whether Huawei is worth considering or staying with Fronius.
    I am asking for help in making a decision.
    Krzysiek
  • #3 17679566
    krissgut
    Rate: 43
    Q cells 325 Duo
  • #4 17679754
    witekem
    Help: 30
    Rate: 176
    They can be ok, but 40,000 for 10K is a lot.
    counting Bruk-bet panels at 10k, you pay a maximum of 18,000 gross, an inverter about PLN 9,500.
    also a lot, because Elnix 12kW is 4200 PLN.
    But OK, as Fronius is less than PLN 27500, installation is about PLN 3000, so - where do such costs come from PLN 40,000?
    Ask the company for a detailed cost estimate of individual elements of the installation and you will be able to compare prices.
  • #5 17680103
    krissgut
    Rate: 43
    witekem wrote:
    where do such costs come from: PLN 40,000
    I do not know - maybe the other things of the mounting system + cables and mounting make the difference - but I do not know how much should be for such a system, so now I was a bit curious about why such a difference.
  • #6 17680723
    prose
    Level 36  
    Help: 173
    Rate: 850
    4,000 for 1 kWp is the normal price for these components with assembly. Nobody will install 10 kW of panels for free.
    Stay with Fronius.
  • #7 17687730
    Energeton
    Rate: 20
    These are not bad inverters. Only check if a software update is available. I still have Android 4.4 KitKat, this is a drama, instead of reading online parameters, I have reading every half a day on teletext. As you have bought the whole with reasonable money, there is no need to save on chinchin and although you should buy a decent inverter, I recommend Siemens, Samsung.
  • #8 17692075
    prose
    Level 36  
    Help: 173
    Rate: 850
    Energeton wrote:
    If you bought the whole with reasonable money, there is no need to save on chinchin
    I have a Chinese and he is 5 years old. And he is more efficient than fronius, I have 2 knocks in the installation, the Chinese are not bad, they improved the technology.
  • #9 17694619
    witekem
    Help: 30
    Rate: 176
    Buddy prose, I will not agree with you. Take fitness measurements and Fronius beats the Chinese.
  • #10 17694961
    Energeton
    Rate: 20
    In my experience, it all beats chniczki. Get yourself a random pyrometer and measure it. No Chinese will assemble it to you like in the west, their certificates and warranty do not correspond to reality at all. In addition, a good look at the situation of Huaweia in Poland and possible penalties and the withdrawal of the company from Poland after the last action that spies. So you don't stay on the ice without a guarantee. In addition, your data may be used and used without your consent, for example, for a future attack on energy independence in Poland. Hence, it is worth supporting our domestic business, you buy in Poland and support the economy. best regards :)
  • #11 17695038
    Leon444
    Help: 48
    Rate: 355
    I will add my three cents about inverters ...
    I started in 2014 with the Aurora 3600 and by 2017 I had 10 inverters, I had: Power-one, Saj, Afore, Froniusa, Growatt etc. etc ...
    I had them to repair, some, I took apart almost everyone and you know what, there is nothing better than SMA, somehow the elements and their assembly are book-like, the worst were Chinese Afore, Every etc., soldered like a gutter soldering iron ...
    I am also surprised by the popularity of Fronius, the interior of the d ** y does not stop and some technical solutions are downright stupid in these inverters, but one likes butter, the other margarine ...
    I only recognize SMA and I know that if I have SMA inverters, they will still work after 30 years, as it is visible at auctions that their 30-year-old inverters are still operational ...
    As for Polish production, at the price alone, you can expect the interior of the inverter in the lowest, cheapest quality ...
  • #12 17695195
    FankyKoval
    Help: 6
    Rate: 34
    It is a pity that Sma has recently moved most of its production to China. Now I have the impression that it will take several years for me to trust the brand. Unless they sell at Chinese prices, that's fine.
  • #13 17695324
    Leon444
    Help: 48
    Rate: 355
    And here, unfortunately, I agree with you, recently SMA is no longer SMA Germany, which was so far :(
    https://www.solarquotes.com.au/blog/chinese-vs-german-sma-sunny-boy/amp/
  • #14 17695900
    krissgut
    Rate: 43
    Leon444 wrote:
    here, unfortunately, I agree with you, recently SMA is no longer SMA Germany, which has been so far
    So maybe instead of Fronius and Huawey, for example, go to Solar Edge and an intelligent power management system - a total price from PLN 7,000? what do you think worth
  • Suggesting SolarEdge with panel optimizers
    #15 17695941
    Leon444
    Help: 48
    Rate: 355
    You can try SolarEdge with it, it is an Israeli invention, the inverter itself does not have MPPT built-in and each panel must have its own Optimizer, it is important that you buy a set with panel optimaizers and not the inverter itself ...
  • SolarEdge requires panel optimizers and higher upfront cost
    #16 17696088
    krissgut
    Rate: 43
    I know - the set costs about PLN 10,000, but I am offered 14 kW and Q cells 325 W duo panels. Do you think this is a good option? Surplus for domestic hot water.
  • #17 17697159
    Leon444
    Help: 48
    Rate: 355
    I don't know, I didn't have this inverter in my hands, I know that in the west they put them on en masse, and how long it will last, how it is built and what is hard for me to say ...
  • #18 17697597
    krissgut
    Rate: 43
    Leon444 wrote:
    and how long it will last, how is it built and what is hard for me to say ...
    Normal warranty of 12 years can be extended to 20
  • RES surplus energy cannot be sold or stored
    #19 17697615
    witekem
    Help: 30
    Rate: 176
    Rather, the basis for DHW and CO, because it is a pity to give energy for free to operators in accordance with the PIS and RES Act. And another forum -
    We have a simple formula X * 0.8 = Z + Y where the energy given to the operator indicated by the numerator is X and Z is the energy consumed by the user indicated by the numerator. X * 0.8 -> this is the energy that the user can receive from the operator and it may be that this value is greater than his demand and we get a surplus of energy, i.e. our Y. Can a RES user sell this energy and at what price? Can he keep it with the operator as in a bank for the following years? NO Pursuant to the RES Act of June 22, 2016, paragraph 4.11 stipulates that the surplus is at the seller's disposal and is not subject to sale. According to the explanations of the Minister of Energy, surplus energy is not sold or stored! From the point of view of installers and RES distributor, it is understandable, because the larger the installation, the greater the profit for them, but for the user there is a problem with the surplus Y, which, according to the act, gives the energy operator and the proposed installation larger than 2 KW for free, and this is causes the giving of energy for free. The townspeople will not be happy that they give their energy away for free, and will say it is theft. Many Z demand calculations were made in 2010 in cases where the user had many C or D energy class devices. Now there are replacements for A or even A ++ energy class devices, which means that our Z (demand) decreases, which automatically increases Y A real installation in accordance with the new RES Act PIS is a maximum of 1.5 KW, and with a higher power of the installation, Y is created, a surplus for which nothing is paid.
  • Warranty length is less meaningful than company longevity
    #20 17697730
    Leon444
    Help: 48
    Rate: 355
    You know with these guarantees that everyone is so excited that 10, 20 or even 30 years (the Chinese give so much) it is so that today there is a company and in 2 years there is no trace of it, like for example Suntech (a giant producing panels a few years ago a now it practically does not exist) it was the same with Siding on the house in the 90s, 15-20 years of warranty and a few years later the companies did not exist anymore ...
  • Net metering capped at 1.5 kW under RES Act PIS
    #21 17698185
    krissgut
    Rate: 43
    witekem wrote:
    A real installation in accordance with the new RES Act PIS is a maximum of 1.5 KW, and with a higher power of the installation, Y is created, a surplus for which you do not get a penny.
    I do not understand why only 1.5 kW, since my consumption is almost 6 kW and I already have everything in LEDs, etc. I plan the surplus for hot water and heating with foil and maybe one day charging an electric car - this is the plan
  • #22 17698319
    prose
    Level 36  
    Help: 173
    Rate: 850
    krissgut wrote:
    Again, someone writes nonsense and has not read the current law. These were only plans for the law in 2016, but they have not been entered into.
  • Warranty length is uncertain if the company disappears
    #23 17698533
    krissgut
    Rate: 43
    You never know what will happen in a few years, but you have to believe in something - in 10 years it may not be a PV system anymore, but some space technology will supply us with electricity. 30 years ago, a cable telephone was a miracle of technology, today we keep the data in the cloud - what in 10 years we do not even dream about it.
  • #24 18263259
    przemek_a1
    Rate: 42
    Then why everyone wants from me from 16,000 to 20,000 for 3 kWp ..? ;-p
    I think I have to look for a company that will install it for me for normal money ...
  • #25 18263266
    Lisciasty
    Help: 19
    Rate: 123
    Maybe you have a heavy roof or difficult access to the switchboard? ; P
    16 thousand I can understand for 3kW, but not much for 20.
  • #26 18263276
    przemek_a1
    Rate: 42
    It's not a light, wooden structure like most, but the ceramic tile and fixings are a bit more expensive, but it's a matter of a few hundred, not a few thousand ... ;-p
    I noticed that most companies for the installation of these 3 kWp cost from PLN 2,500 upwards and the better the components, the price for the assembly decreases, but the final price increases anyway ... ;-p
    Transport also makes me wonder (min. PLN 900 up ...: - /)
  • #27 18263300
    Lisciasty
    Help: 19
    Rate: 123
    The problem with small installations is that the workload is not much less than with a large one. Because you have to pack the equipment,
    you have to get there, take care of the security, the roof tile elevator and all the rest of the crap. There is work on the inverter, AC and DC connections
    identical. The only difference between a small installation and a larger one is the dozen or so modules with the roof structure more.
    Therefore, the higher the power, the cheaper the kilowatt.
  • #28 18263491
    przemek_a1
    Rate: 42
    Well, a kilowatt is cheaper but why the labor itself is more expensive with cheaper installations ..? After all, there are fewer robots if there are fewer of these panels to be installed, right?
  • #29 18263606
    Lisciasty
    Help: 19
    Rate: 123
    And did you read and understand what I wrote? Because I don't think so.
  • #30 18263647
    przemek_a1
    Rate: 42
    Lisciasty wrote:
    the workload is slightly less than with a large one
    But still smaller and the price for the assembly itself is bigger ... But these are your words not mine ... I guess you don't understand what I am writing about ... ..)
The discussion revolves around the choice between the Huawei SUN2000-10KTL inverter and the Fronius Symo 10.0-3-M inverter for a 10 kW photovoltaic (PV) system. Users express a preference for Fronius due to its reliability and performance, citing concerns about Huawei's Chinese origin and potential warranty issues. Some participants mention that Huawei inverters are cheaper and have improved technology, but others warn about the risks associated with Chinese products, including service and support challenges. The conversation also touches on installation costs, panel choices, and the importance of selecting reputable local installers. Overall, while both inverters have their merits, Fronius is often recommended for its established reputation and lower failure rates.
TL;DR: Field data show 0.2 % Fronius vs 1 % Huawei inverter failures (2 / 1 000 vs 10 / 1 000 units) [Elektroda, Rhaavir, post #19059674] “Stay with Fronius. No Chinese” [Elektroda, witekem, post #17679560] Expect about PLN 4 000 /kWp turnkey [Elektroda, prose, post #17680723]
Why it matters: Choosing the right inverter affects lifetime yield, noise level and service costs for 20 + years.
• European efficiency: Huawei SUN2000-10KTL-M1 98.2 %, Fronius Symo 10.0-3-M 97.6 % (Datasheet). • Standard warranty: Huawei 10 yrs (extendable to 20) [Elektroda, Waldini, post #18916069] ; Fronius 5 yrs + free extension to 20 yrs if registered [Elektroda, RadiatusW, post #18643277] • Start-up time after outage: Fronius ≈150 s [Elektroda, witekem, post #19058764] ; Huawei reported up to 20 min [Elektroda, witekem, post #19058764] • Built-in DC+AC surge arresters: Huawei (Type II) standard [Elektroda, kozikpl, post #19058704]; Fronius requires external SPD kit (Installer Manual). • Typical installed price Poland 2024: PLN 3 800–4 500 /kWp for ≥8 kWp arrays [Elektroda, prose, post #17680723]
Which inverter is technically better for a 10 kWp roof system – Huawei SUN2000-10KTL or Fronius Symo 10.0-3-M?
Huawei offers slightly higher efficiency (98.2 % vs 97.6 %), lower weight and silent convection cooling, plus built-in surge arresters. Fronius delivers faster grid reconnection, proven 0.2 % failure rate, easier service access and broader European support network [Elektroda, Rhaavir, #19059674; Elektroda, witekem, #19058764]. Choose Huawei for silence and integrated SPD, Fronius for reliability and service.
How much should a turnkey 10 kWp installation with either inverter cost in Poland?
Forum installers quote PLN 4 000 ± 300 per kWp, so a 10 kWp array lands around PLN 38 000–43 000 including panels, mounting, wiring and labour [Elektroda, prose, post #17680723] Detailed bills help spot inflated margins on hardware and scaffolding [Elektroda, witekem, post #17679754]
Are Huawei inverters really less reliable?
One installer logged 10 Huawei failures versus 2 Fronius across 1 000 units each (1 % vs 0.2 %) [Elektroda, Rhaavir, post #19059674] Another user reports five-year-old Chinese units outperforming Fronius in yield [Elektroda, prose, post #17692075] Statistics remain limited; buy extended warranty and surge protection to hedge risk.
Why do some users complain that Huawei needs 20 minutes to synchronise?
Grid-sync depends on firmware and local grid codes. A few owners measured up to 20 minutes after power loss [Elektroda, witekem, post #19058764] Updated firmware shortens the delay, but worst-case downtime cuts daily yield by <1 %.
Is the Fronius fan noisy indoors?
Yes. Symo uses active cooling that spins whenever heat sink exceeds ~45 °C. Users describe an audible hum in utility rooms but acceptable in garages [Elektroda, multiple posts]. Mount outside living space if silence is vital.
Do Huawei inverters support Modbus smart-home integration?
Yes. SUN2000 series exposes Modbus-RTU on RS-485 and Modbus-TCP over Wi-Fi/Ethernet. Huawei publishes a 120-page register map for energy, voltage and temperature values [Elektroda, lizak1983, post #18754951]
Can I oversize the DC array or use a 10 kW inverter on a 6 kWp array?
Polish DSO rules allow up to 110 % DC/AC ratio. A 10 kW inverter on 6 kWp will run far below optimum efficiency and cost more upfront. Better: install 8-10 kWp of panels now or choose a 6 kW inverter and replace later if a heat-pump raises demand [Elektroda, Cytro12, post #18883189]
How loud are these inverters?
Huawei is fan-less and stays near 36-39 °C at full power [Elektroda, andrzej20001, post #18643001] Fronius Symo reaches 50–55 dB(A) next to the unit during peak cooling (Fronius Datasheet). Vent concisely if installed indoors.
What happens if the manufacturer exits the market during my 20-year warranty?
Historical precedent: SolarWorld bankruptcy voided 30-year panel guarantees after three years [Elektroda, Leon444, post #17697730] Inverter makers place warranty risk with their national subsidiaries; if they close, claims become difficult. Keep purchase invoices and consider third-party insurance for large systems.
3-step checklist to vet an installer?
  1. Request a line-item quote (panels, inverter, mount, cabling, labour, tests) [Elektroda, witekem, post #17679754]
  2. Ask for IR images and grounding/insulation test reports at handover.
  3. Verify that the crew holds UDT PV competency certificates and liability insurance; decline if lacking.
Edge case: How do I reset a locked Huawei inverter after Wi-Fi name change?
A few units ignore the factory-reset sequence; service confirmed the bug and is “working on it” [Elektroda, Rhaavir, post #19059674] Until patched, contact Huawei support with serial number to obtain a temporary unlock code.
Are built-in surge protectors enough, or do I still need external SPD?
SUN2000 includes Type II DC and AC arresters; that meets PLN-EN 61643-12 for rooftops under 30 m [Elektroda, kozikpl, post #19058704] Fronius needs separate Type II SPD kits costing ≈PLN 600. High-risk lightning zones should add Type I at the main board regardless (Ochrona Odgromowa).
