Methods for Cleaning the Cooking Plate on a Tiled Stove: Seeking Advice
Vwuac 33960 31
What is the best way to clean the metal cooking plate on a tiled stove?
Clean the plate with a hand brass wire brush or a spatula, depending on how much carbon buildup there is. For light dirt, the brush is better and less messy; for heavy soot, scrape first with a spatula, then brush [#18536819] [#18536823] [#18536830] If the plate can be removed, take it outside and use a grinder with a soft wire brush and WD-40, then finish with fine abrasive paper for a smoother surface [#18600417] One reply also suggests caustic soda after the rough cleaning step [#18536860]
  • #31 21143684
    filipratkowski
    Dear Friends! I admire your knowledge and willingness to help your fellow man, but.... RESPONSE! Try to write orthographically (I don't mean typos, because those happen to everyone). The kids are reading and will be in terrible trouble in class.
  • #32 21148453
    Stachu.G
    Help: 5
    Rate: 40
    Sam's paste and final rubbing with edible oil.
The discussion revolves around methods for cleaning the cooking plate of a tiled stove. Various cleaning techniques are suggested, including the use of a wire brush (brass or abrasive), spatulas for scraping, and caustic soda for heavy soiling. Some participants mention the effectiveness of sandblasting and using WD-40 for maintenance. There is a debate about the distinction between tiled stoves and coal stoves, with some contributors sharing personal experiences and historical context regarding the maintenance of these appliances. The consensus suggests that regular cleaning can be achieved with simple tools, while more thorough cleaning may require specialized methods.
