[Solved] AKPO PKA 30 830 Induction Hob: Stopped Heating, Display Symbols Flashing, How to Repair?
Temudżyn 32814 2
  • #1 18539896
    Temudżyn
    Hello. :)
    Today I used the induction hob as usual (Akpo PKA 30 830). I started to fry and after a while, it stopped heating and two symbols flash on the display
    ___
    | __ __
    | alternating with |
    After holding your finger on the on / off button for 10 seconds, it beeps twice and then nothing. It does not react to anything else.
    On the nameplate:
    Akpo
    Ceramic hob
    PKA 30 830
    220-240 V ~ 50/60 Hz
    Max power 3000W
    Class I
    18 32
    Does anyone know this problem?
    What is it about?
    How can it be repaired?
    Thank you all in advance for your answers :)
  • #2 18540055
    CodeBoy
    Help: 138
    Rate: 690
    Check it "In order to disable the keypad lock, press and hold the" + "key for about 2 seconds until
    two symbols "[] []" "appear on the display
  • #3 18542123
    Temudżyn
    It only beeped after 10s. holding the ON / OFF button - it was the only reaction and there was no lock on.
    In the end, it was enough to turn off the fuses and it works.
