[Solved] AKPO - PKA30830 Induction Hob: FF Error, No Halogen Lamps, Alternative Solutions?
Anieqq 20922 2
  • #1 18751422
    Anieqq
    Rate: 22
    Hello!
    These two symbols on the induction hob appear alternately. It had never been seen before, but now there was no electricity for a while and suddenly it came on. Of course, I reached for the manual and the description of the "F" symbol reads as follows "It means that the controller is exposed to too much, for example, a halogen lamp. In this case, turn off the light and the controller will resume its operation." The problem is that I don't have any halogen lamps - but to prevent any light from reaching it, I covered it with a towel - to no avail. It makes no difference either to place the dishes on it, or to wash it on both sides with water. Unfortunately, I do not have access to traffic jams because I live in a block of flats and they are secured. Anyone have any ideas or had a similar situation? : /
    AKPO - PKA30830 Induction Hob: FF Error, No Halogen Lamps, Alternative Solutions? AKPO - PKA30830 Induction Hob: FF Error, No Halogen Lamps, Alternative Solutions?
  • #2 19057509
    oliwia3004
    Rate: 50
    Hello, could you please tell me how you dealt with this problem? Because currently I have the same and no methods work, and there is little written on the internet about it. Thank you in advance.
  • #3 19470636
    Anieqq
    Rate: 22
    The problem is resolved after disconnecting the power and reconnecting the induction hob.
