32A Pre-Meter Protection: Minimum Connection Power Requirements for 16kW Power Load
Pavel7606 274200 20
How much do I need to increase my connection power to replace a 25A pre-meter protection with 32A protection?
A small increase from 16.0 kW to 16.2 kW will probably not change the pre-meter protection; a change of about 1–2 kW is suggested, with 17 kW described as a sensible minimum [#18544756][#18545441] One reply notes that in the table, 32A corresponds to roughly 16.1 kW up to 20.6 kW, so 17 kW should fall into the 32A range [#18544844] Another important caveat is that increasing the protection also requires checking whether the WLZ/installation cross-section is suitable [#18544844][#18547368] The tripping you see may also be caused by load conditions: the heater was measured at about 23.6 A, and a 24 kW three-phase heater can draw nearly 35 A per phase, so a 25A breaker can legitimately trip after some time [#18545490][#18545514]
  • #1 18544564
    Pavel7606
    Rate: 48
    Hello! I am urgently looking for a current table that would show what the minimum connection power I need for the 32A pre-meter protection. Currently, I have 25A with a connection power of 16 kW and this protection has already worked for me several times. At home I have everything for electricity - a stove, a water heater, etc. On the Internet I have met with various tables, and you can't reach Tauron now ... Thank you in advance for your answers. greetings
    The unit of power is kW. You can throw out the garbage, the security devices work or trip. I corrected. / zbich70 /
  • #2 18544663
    jurkuc
    Help: 146
    Rate: 315
    The table is always up to date:
    • 32A Pre-Meter Protection: Minimum Connection Power Requirements for 16kW Power Load Warto?ci zabezpieczeń przedlicznikowych dostosowane do mocy w EnergiaPro.JPG (57.74 KB) You must be logged in to download this attachment.
  • #3 18544737
    Pavel7606
    Rate: 48
    Do I understand correctly, in order to be able to install a 32A protection, it is enough to increase the connection power to 16.2 kW from the current 16 kW?
  • #4 18544756
    jurkuc
    Help: 146
    Rate: 315
    I am afraid that the change of the connection power from 16.0 [kW] to 16.2 [kW] will not change the pre-meter protection. I propose to make a change by eg 2 [kW]. I think that Tauron will not accept the application for a power change by 0.2 [kW], and if it does, it will decide that the pre-meter protection is not subject to change.
  • #5 18544761
    kokapetyl
    Help: 1787
    Rate: 2101
    Hardly any difference.
    The table shows 25A for 16kW, and for 35A it is 20.6kW.
    And that's not all, the installation (cross-section) decides about the possibility of increasing the power.
  • #6 18544817
    takijasiu
    Help: 91
    Rate: 161
    You don't mean installation on the receiver side, do you? After submitting the application for increasing the connection capacity, at most the power plant may need to perform work on its side - but we probably do not expect it when switching from 16kW to 18kW - right?
  • #7 18544844
    kozi966
    Help: 599
    Rate: 1288
    kokapetyl wrote:
    The table shows 25A for 16KW, and for 35A it is 20.6KW.
    The table shows that 32As start from 16.1kW to 20.6kW.
    This means that the author may apply for a change, e.g. by 1kW, and they should change the value of the security.
    takijasiu wrote:
    You don't mean installation on the receiver side, do you? After submitting the application for increasing the connection capacity, at most the power plant may have to perform works on its own side
    Changing the security to a larger one will require verification of the WLZ in terms of permissible parameters.
  • #8 18545415
    Pavel7606
    Rate: 48
    17 kW will probably be the lowest sensible value in the new proposal so that it doesn't look silly?
  • #9 18545441
    takijasiu
    Help: 91
    Rate: 161
    17kW will be OK - it is commonly done.
    However, the question is - why 25A overcurrent works and what is its characteristics. Maybe the reasons for activating the protection should be found in improperly balanced phases of the load (e.g. that you have all the kitchen equipment on one phase).
  • #10 18545490
    Pavel7606
    Rate: 48
    An electrician was there yesterday and checked the current with the water heater on and it was something in the region of 23.6 A, so close to the protection limit. No other appliances with high current consumption were running at the time. The activation of the protection always occurred when the water heater was running, although there had been no problems for over a year as I have lived here, until last month.
  • #11 18545492
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    Pavel7606 wrote:
    17kW will probably be the lowest sensible value in the new application so that it does not look stupid?
    Contact your local ZE even by e-mail and ask for a table.
    "Values of pre-metering protections adjusted to the power in EnergiaPro.JPG"
    The table from the second link is not Tauron, is it? For me, for example, the power is increased by 0.5kW.
    How will they accept the application and the cash register, why should you be stupid? After all, these are the standards. And the fact that you currently have the highest power with a given protection and you want to have more protection at the lowest cost is not a reason to be ashamed. Most people do that. I think they look more strangely at people who take one of the greatest powers with a given security.
    Write down what you have enabled at the same time and what power in the event of triggering the security.
    takijasiu - overload protection characteristics does not matter.
  • #12 18545506
    Pavel7606
    Rate: 48
    The protection was recently activated even with only the 24 kW water heater in operation.
  • #13 18545514
    takijasiu
    Help: 91
    Rate: 161
    If it is a 3-phase instantaneous water heater that loads about 24A per phase, then the protection actually has the right to work when something else is connected to it. And this pre-meter protection, what is the characteristic? Is it a power limiter in the form of a modular apparatus?
    Maybe someone adjusted the desired temperature on this heater a month ago? Depending on the model, it may consume less electricity when you turn the knob.
    Not current but time in this case [TM]
    Since it is not our characteristics that informs about how a given security will behave with known values of load and time, what determines this?
    Pavel7606 wrote:
    The protection was recently activated even with only the 24kW water heater operating ...
    Well, the 24kW 3-phase heater gives almost 35A per phase, the 25A protection in the form of e.g. eSki or Etimat T will work within several dozen seconds.
  • #14 18545606
    Pavel7606
    Rate: 48
    After the last activation of the safety device about 10 days ago, I lowered the temperature on the heater by 5 degrees and there is peace of mind.
  • #15 18545775
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    Does this heater have any electronic temperature control? If so, the problem will recur next winter. If there is electronic temperature control, the output of the heaters is then also dependent on the feed water temperature. In winter the water is unfortunately colder and more kW is needed.
    What is the cross-section of the wires from the meter? Maybe you should think about increasing the power by two values? What you have now is sufficient only for the water heater and practically nothing else. 32A won't give you comfort of use either, because you won't be able to switch anything current-consuming on at the same time as the heater.
    Is the protection activated at the moment the heater is switched on or after a while? If it activates immediately, maybe the heater is faulty?
  • #16 18546231
    Pavel7606
    Rate: 48
    Yes, the heater has electronic temperature control and the protection was always activated after the heater had been in operation for some time - never at the moment of switching it on.
    From the meter there go wires of about 1 cm in cross-section judging by the layman's eye.
    Moderated By Topolski Mirosław:
    Please read the instructions regarding the cross-sectional area of the wires feeding the heater and the current consumption at a given wattage of the heater - a thorough reading of the instructions should take place before the heater is installed.
    Far more than 32A would have to go hand in hand with a much higher connection power, so a considerable cost for the whole operation.
    The water heater is a Kospel PPE2 18/21/24
  • #17 18546382
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    24kW is a lot for a consumer. Do you realise that if you increase the protection by one degree, you will still be balancing on the borderline of protection tripping? The number of appliances in the home is increasing every decade, not decreasing. You would have to be on guard all the time.
    The cost is something in the region of 70 PLN, if I remember correctly, for each additional kW above what you have. A total of several hundred zloty.
    Another option is still to replace the heater with one with a lower output. But I suspect this is even more out of the question. 24kW, that's quite boiling water flying.
    You write that an electrician has been and measured the current. Did he say anything, have any suggestions?
  • #18 18546447
    Pavel7606
    Rate: 48
    The electrician suggested a minimum power increase that would allow 32 A protection to be put in place.
  • #19 18546709
    Ktoś_tam
    Level 40  
    Help: 505
    Rate: 2906
    In that case, increase the power to these 32A, the cost is only a few dozen zlotys. It will definitely improve the situation. If it is not enough, at most you will go through the entire procedure from the beginning + several hundred zlotys.
    The biggest problem may be in winter, where you need to raise the temperature by an additional few degrees.
  • #20 18547354
    Pavel7606
    Rate: 48
    This is what he plans to do. If that doesn't help, will have to spend more, hard to do. Anyway, thanks a lot for the hints.
  • #21 18547368
    kokapetyl
    Help: 1787
    Rate: 2101
    Just do not forget that increasing the protection from 25A to 35A requires checking what the installation is and whether its cross-section is appropriate. It has already been discussed.
The discussion revolves around the minimum connection power requirements for a 32A pre-meter protection system, particularly in the context of a 16kW power load. The original poster seeks clarification on whether increasing their connection power from 16kW to 16.2kW would suffice for the installation of 32A protection. Responses indicate that a more significant increase, such as to 17kW or 18kW, is advisable to meet the requirements. Concerns are raised about the existing 25A protection tripping under certain conditions, particularly when a high-demand appliance like a water heater is in use. The conversation highlights the importance of verifying the installation's wiring and load balancing, as well as the potential need for a larger connection power to accommodate future electrical demands. Suggestions include contacting local energy providers for updated tables and considering the characteristics of the water heater, which may affect power consumption.
TL;DR: For 3‑phase homes, 32A starts at 16.1 kW; "Changing the security to a larger one will require verification of the WLZ." Request ~+1 kW, not +0.2 kW, and check wiring before upsizing. [Elektroda, kozi966, post #18544844]
Why it matters: For homeowners with large electric loads (e.g., instant heaters), this helps stop nuisance trips and choose the right connection power.
What minimum connection power unlocks 32A pre‑meter protection?
On 3‑phase, the 32A bracket starts at 16.1 kW and runs up to 20.6 kW. If you sit at 16 kW, request at least +1 kW. “32As start from 16.1kW to 20.6kW.” Check WLZ capacity before upsizing. [Elektroda, kozi966, post #18544844]
Will a 0.2 kW bump (16.0 → 16.2 kW) change my pre‑meter fuse?
Unlikely. Utilities may not accept such a tiny increase, or may leave the pre‑meter fuse unchanged. Request +1 to +2 kW instead to justify a 32A change. [Elektroda, jurkuc, post #18544756]
Why does my 25A pre‑meter protection trip with a 24 kW heater?
A 24 kW three‑phase heater draws almost 35 A per phase. A 25A breaker will trip after several dozen seconds at that load. eSki or Etimat‑type breakers trip in tens of seconds at ~35 A. [Elektroda, takijasiu, post #18545514]
My electrician measured ~23.6 A with the heater on. Why does it still trip?
23.6 A sits only 1.4 A below a 25A threshold. Even a small added load or a heater ramp can exceed 25A. Plan loads or increase connection power to add margin. [Elektroda, Pavel7606, post #18545490]
Do I need to upgrade wiring (WLZ) to move from 25A to 32A?
Yes. The operator verifies the feeder (WLZ) parameters before increasing protection. “Changing the security to a larger one will require verification of the WLZ in terms of permissible parameters.” If it fails checks, you must correct issues first. [Elektroda, kozi966, post #18544844]
How do I apply to increase connection power for 32A with Tauron/ZE?
Use this quick process:
  1. Contact your local ZE/Tauron by email and request their pre‑meter table.
  2. Submit the smallest increase your operator allows (often 0.5–1 kW).
  3. Pay the fee, then schedule meter‑side changes after approval. [Elektroda, Ktoś_tam, post #18545492]
Is requesting 17 kW a sensible minimum?
Yes. 17 kW is commonly accepted and avoids a trivial‑change request. It also gets you into the 32A bracket with headroom. [Elektroda, takijasiu, post #18545441]
How much does increasing the connection power cost?
Plan for about 70 PLN per extra kilowatt, depending on the operator. Expect several hundred PLN overall for modest increases. [Elektroda, Ktoś_tam, post #18546382]
Will lowering the heater temperature help reduce trips?
Yes. Reducing the heater setpoint by about 5°C eliminated tripping in the reported case. Lower demand reduces current draw and nuisance trips. [Elektroda, Pavel7606, post #18545606]
Trips happen after a while, not instantly. Is the heater faulty?
Delayed trips match overload timing, not a hard fault. If it trips immediately at switch‑on, suspect a heater fault and investigate. [Elektroda, Ktoś_tam, post #18545775]
Will 32A be enough with a 24 kW heater?
It helps but still limits simultaneous use. “32A won’t give you comfort of use either,” so avoid other high‑draw loads while heating. [Elektroda, Ktoś_tam, post #18545775]
How should I balance phases to avoid nuisance trips?
Distribute kitchen and heater loads across phases. Unbalanced phases can trip one pole even if total power looks acceptable. [Elektroda, takijasiu, post #18545441]
What cable size do I need for a high‑power heater or 32A upgrade?
Consult your heater’s manual for conductor cross‑section and current at each setting. Do this before installation. Example: Kospel PPE2 18/21/24 owners should read the wiring section. [Elektroda, Topolski Mirosław, post #18546231]
What if my WLZ or installation cross‑section is undersized?
Uprating gets blocked until wiring complies. Have an electrician verify cross‑sections before moving from 25A to 35A or similar increases. [Elektroda, kokapetyl, post #18547368]
