[Solved] Understanding Phase in Alternating Current: Simple Explanation & Its Role in Sinusoidal Waves
Trzcinkan 14265 15
What does phase mean in alternating current and sinusoidal waves?
Phase is the position of a sinusoidal wave relative to the chosen origin, in other words its shift in time or angle [#18547636][#18552425] The initial phase is the offset at t = 0; if a sine wave starts at t = 0 its initial phase is 0°, and shifting it left or right changes that initial phase [#18552425] It is commonly written in the sine formula as u(ωt) = Umax sin(ωt + φ), where φ shifts the waveform relative to the coordinate origin [#18552425] When voltage and current are discussed, “in phase” or “out of phase” means the angle between them [#18555586]
  • #1 18547525
    Trzcinkan
    Level 4  
    I have a question, what is phase in alternating current? (I mean such a simple phase that is presented at the beginning of learning alternating current)
    The term "phase" is portrayed in books and on websites, but nowhere is it explained what it actually is. On some English site I found the statement that "A phase is a given point in time in a sinusoidal wave" and nothing else. Maybe someone will explain to me or confirm whether this statement is true.
    Thank you in advance
  • #2 18547618
    miroslaw wielki
    Conditionally unlocked
    Help: 148
    Rate: 362
    Alternating current from the English alternating current, AC a characteristic case of periodically alternating current in which the instantaneous values are subject to changes in a repetitive, periodic manner, with a specific frequency, e.g. 50 times per second, our current in Polish sockets.
  • #4 18547647
    Trzcinkan
    Level 4  
    So it can be said that it is the distance from the initial phase (t = 0)?
  • #5 18552409
    Aleksander_01
    Help: 1167
    Rate: 3436
    Phase - has several concepts in electricity.
    The first and most important thing is something a la source. In order for the current to flow from this source, a so-called neutral conductor is needed, now called neutral.
    All over the world, power generators are three-phase, that is, they generate electricity in three separate "sources". These "sources" are out of phase (the latter term) by an angle of 120 °.
    There must be a potential difference for the current to flow. Such a difference is between a given source (given phase) and the neutral wire (in Poland it is 230 V), or between two sources (phases) (in Poland 400 V).
    The concept of phase is very difficult for a beginner to understand, but with time it will become bread and butter.
    You have certainly seen a single-phase plug, i.e. two pins, phase and neutral. Maybe you saw or maybe not the three-phase plug. Currently, it has 5 pins, 3 of them are phases (each is shifted by 120 ° in relation to the other), the fourth is neutral and the fifth is protective.
    You have such a simplified drawing
    What my colleague SuhaK01 described below is the third phase concept, the so-called initial phase.
  • #6 18552425
    SuhaK01
    Trzcinkan wrote:
    So we can say that it is the distance from the initial phase (t = 0)?
    Regarding the concept of phase understood as a phase shift:
    The initial phase is the distance from t = 0.
    For example, when a sine wave "starts" at t = 0, the start phase is zero. However, if we shift this course to the left or right (in relation to the coordinate system), the initial phase will be the distance from the beginning of this shifted course to the coordinate system (i.e. time t = 0). Of course, the phase is given in degrees, and it ranges from 0 ° to 360 °.
    As you have probably seen, the general formula for a sinusoidal voltage waveform is: $$u(ωt) = U_{max}sin(ωt + φ)$$ where ? is your phase which shifts the waveform with respect to the origin of the coordinate system.
  • #7 18554335
    Trzcinkan
    Level 4  
    So from what I understand the phase is shortly called a phase shift? So then in this slide, phase angle = phase shift = phase? Understanding Phase in Alternating Current: Simple Explanation & Its Role in Sinusoidal Waves
  • #8 18554412
    kozi966
    Help: 599
    Rate: 1288
    "Phase" as a term used by "Mr. Mietek" is a voltage sine wave.
    The second phase is also a voltage sine wave, but shifted by 120 degrees from the first.
    The third one is similar, but shifted from the first by 240 degrees, and from the second by 120 degrees.
    That is why Mr. Mietek has "three phases". Because each one against the neutral wire will shock him, and each one will shock him in relation to a different phase.
    Phase voltage - a variety of "phase" understood more by electricians, it is the effective value of the voltage between the selected phase conductor ("phase") and the neutral conductor or the star point.
    In electricity, a phase shift is not considered to be "phase".
  • #9 18554460
    miroslaw wielki
    Help: 148
    Rate: 362
    And so it's less complicated how to say? Instead of a phase
  • #10 18554536
    Trzcinkan
    Level 4  
    But I don't mean any three-phase system, but what is a phase, because I don't know which answer is right anymore
  • #11 18554593
    ewoo
    Level 30  
    Help: 158
    Rate: 410
    Yes, for peasant reason. Phase is what it kicks.
  • #12 18554865
    Trzcinkan
    Level 4  
    Well, explaining to myself, it will be difficult to understand what I have to learn
  • #13 18554889
    kozi966
    Help: 599
    Rate: 1288
    I don't mean what my friend is about.
    Phase is derived from power. The power supply is, as a rule, three-phase.
    Phase, as I wrote before, is a voltage sine wave. There can be one, there can be three, six, twelve, as many as you like.
    Phase, colloquially, is the supply voltage on one line with respect to the neutral point.
  • #14 18555219
    Trzcinkan
    Level 4  
    Okay, so the phase is a voltage sine wave otherwise, and it can also be a current sine wave because there is current and voltage in the phase shift?
  • #15 18555586
    kozi966
    Help: 599
    Rate: 1288
    Trzcinkan wrote:
    and it can also be a sine wave of current because there is intensity and voltage in the phase shift?
    This is either we use simple definitions for understanding or we go "deeper".
    When we speak of "current in phase" or "out of phase" we are already talking about shifts. So the angle between voltage and current.
    Generally speaking, the term "phase current" is used, but it is the current flowing in a conductor in which the "phase" occurs.
  • #16 18555915
    Trzcinkan
    Level 4  
    Oh, the phase is a voltage sine wave and that's enough for me, thanks
Phase in alternating current (AC) refers to a specific point in time within a sinusoidal wave, often described as the distance from the initial phase (t = 0). It is crucial for understanding how AC operates, particularly in three-phase systems where each phase is a voltage sine wave shifted by 120 degrees from the others. The concept of phase can be complex for beginners, but it essentially relates to the voltage or current sine waves and their respective shifts. The phase angle is measured in degrees and indicates the relationship between voltage and current in AC systems.
TL;DR: In three-phase power, phases are 120° apart; “Phase is a voltage sine wave.” Learn phase vs. phase shift and wiring basics. [Elektroda, kozi966, post #18554412] Why it matters: Clear phase concepts help beginners avoid wiring mistakes, read AC waveforms, and size equipment correctly.
What is “phase” in AC, in simple terms?
Phase describes where a sine wave is in its cycle relative to a reference. Electricians also say “phase” to mean a live line. “Phase is a voltage sine wave.” In three‑phase systems, each phase is a sine separated by 120°. [Elektroda, kozi966, post #18554412]
Is phase just the distance from t=0 (initial phase)?
Initial phase is the angular offset at time t=0. If φ=0°, the sine starts at the origin. Shifting the waveform left or right changes φ. “The initial phase is the distance from t=0.” Values are given in degrees from 0° to 360°. [Elektroda, SuhaK01, post #18552425]
How do phase, phase angle, and phase shift differ?
Phase (power context) labels each sinusoidal supply line. Phase angle φ specifies a waveform’s position relative to the reference. Phase shift is the angular difference between two waveforms; electricians do not call that just “phase.” [Elektroda, kozi966, post #18554412]
What are single‑phase and three‑phase supplies, and what does 120° mean?
Single‑phase uses one sinusoidal source and neutral. Three‑phase uses three sources, each 120° apart. In Poland, phase‑to‑neutral is 230 V, and phase‑to‑phase is 400 V. Five‑pin plugs carry three phases, neutral, and protective earth. [Elektroda, Aleksander_01, post #18552409]
What is phase voltage, and why does it matter?
Phase voltage is the RMS voltage between a chosen phase conductor and the neutral or the star point. It matters for selecting insulation, breakers, and equipment ratings, and for safe measurements. [Elektroda, kozi966, post #18554412]
Can current have a phase too, or is it only voltage?
Yes. We say current is in phase or out of phase with voltage. That describes the angle between the current and voltage waveforms. “Phase current” often means the current flowing in a phase conductor. [Elektroda, kozi966, post #18555586]
How do I calculate phase shift from a measured time delay?
Use φ(°)=360°·f·Δt, where f is frequency and Δt is the time difference between corresponding points on the waves.
  1. Measure Δt between the same waveform feature on both channels.
  2. Multiply by frequency: φ=360°·f·Δt.
  3. Assign sign based on which leads or lags. “Phase (waves)” explains the time–angle relationship. [“Phase (waves)”]
What does φ mean in u(ωt)=Umax·sin(ωt+φ)?
φ is the phase angle. It horizontally shifts the sine wave relative to the time origin. φ=0° starts at the reference; nonzero φ moves the waveform left or right without changing amplitude or frequency. [Elektroda, SuhaK01, post #18552425]
Is the statement “phase is a given point in time on a sine wave” correct?
Not exactly. Phase is an angle, not a time. Time relates to phase via ωt. Initial phase specifies the angular offset at t=0, which sets where the sine wave starts on the time axis. [Elektroda, SuhaK01, post #18552425]
Why do electricians talk about “three phases” in buildings?
Utilities generate three separate sinusoidal sources. Each is 120° apart, enabling 230 V to neutral or 400 V between phases. This supports balanced loads and higher power capacity for motors and distribution. [Elektroda, Aleksander_01, post #18552409]
What’s the typical range for a phase angle?
Engineers typically express phase angles from 0° to 360°. You can wrap angles by adding or subtracting 360° without changing the waveform’s physical state. [Elektroda, SuhaK01, post #18552425]
What happens if voltage and current are 90° out of phase?
In an ideal purely inductive or capacitive load, the average real power is zero at 90°. Apparent power flows, but no net energy is transferred each cycle. Power factor equals 0 in this edge case. [“Power factor - Wikipedia”]
