[Solved] Seagate Barracuda 1TB Disk Detected in BIOS but Not in Windows 10: Troubleshooting Guide
swag_pinguin 28266 10
How do I make a new Seagate Barracuda 1TB drive appear in Windows 10 when it is visible in BIOS but not in File Explorer?
Open Windows Disk Management by running `diskmgmt.msc`; the new drive should appear there as unallocated space [#18552842][#18552846][#18552848] Right-click the unallocated space and choose “New Simple Volume…” to create a partition, then format it and assign a drive letter [#18552854][#18552862] After that, the disk will show up in My Computer/File Explorer [#18552854][#18552864]
  • #1 18552826
    swag_pinguin
    Help: 30
    Rate: 65
    Hello, I bought a seagate barracuda 1TB disk today and the bios reads this disk but it does not show in windows. What to do?
  • #2 18552833
    safbot1st
    Help: 2719
    Rate: 1585
    You can't see it in disk management too? As unformatted, no partition, it's normal that it won't show up in My Computer.
    New disk? If not, replace SMART with CDI by the way.
  • #3 18552838
    swag_pinguin
    Help: 30
    Rate: 65
    Brand new from the store, it detects it, when I enter the status system, it can be seen.
    Added after 47 [seconds]:
    In bios I mean MSI B450 tomahawk max motherboard
    safbot1st
    Help: 2719
    Rate: 1585
    You had to enter disk management ...
    In Start-> run, enter:
    diskmgmt.msc
  • #5 18552844
    swag_pinguin
    Help: 30
    Rate: 65
    But where? In bios or Windows?
    Added after 33 [seconds]:
    Never mind sorry, I didn't notice this news
    safbot1st
    Help: 2719
    Rate: 1585
    Disk management is ... under windows.
  • #7 18552848
    swag_pinguin
    Help: 30
    Rate: 65
    It does not detect but writes unallocated.
    safbot1st
    Help: 2719
    Rate: 1585
    Maybe because you have to ... allocate? Now create as many partitions as you want with this "disk management" and assign them letters.
    That's all. After this action, these partitions will be visible in My Computer.
  • #9 18552858
    swag_pinguin
    Help: 30
    Rate: 65
    Come on, I'm a little green on this topic, so how do I allocate the partition?
  • #10 18552862
    safbot1st
    Help: 2719
    Rate: 1585
    Right-click on unallocated space and select - "new simple volume ..." and so on.
  • #11 18552864
    swag_pinguin
    Help: 30
    Rate: 65
    Okay, resolved, all you had to do was add a new volume and format the drive. Thank you for your help
The discussion revolves around a Seagate Barracuda 1TB disk that is detected in BIOS but not appearing in Windows 10. The user initially struggles to find the disk in Windows, despite it being recognized in BIOS (specifically on an MSI B450 Tomahawk Max motherboard). Responses suggest checking Disk Management in Windows, where the disk is shown as unallocated. The solution involves creating a new volume and formatting the drive, which resolves the issue and makes the disk visible in My Computer.
