The Electrolux EWT 136541W washing machine does not load water
Adam_Heniek 4128 13
Why does an Electrolux EWT 136541W washing machine briefly drain, then stop and repeat the cycle without drawing water, even though the water supply, inlet strainer, pump, and drain filter have been checked?
Check the inlet solenoid valve first; if it is not opening, the machine will not take in water [#16629917] Test it by confirming the valve’s rated voltage and applying that voltage directly (for example, 230 V); if it clicks, the valve itself is probably good, and if the machine has voltage at the valve too, the inlet valve should be opening [#16629997][#16630484][#16630506] If the valve and its supply voltage are okay, look at the hydrostat/pressure switch and its hose, including any bends or blockages [#16630382] Another possibility mentioned was a faulty programmer/control board, which may need replacement [#16630396] Service mode was also suggested for diagnosis, but no working procedure was provided in the thread [#16630413]
  • #1 16629862
    Adam_Heniek
    The electrolux ewt 136541 washing machine does not draw water.
    I checked the water supply from the hose is ok (the strainer on the solenoid valve is also clean). However, there was a very clogged filter at the drain. The washing machine still does not work after cleaning. Ie. - the washing machine, after selecting any program, ejects the water for a few seconds, then "stands still". After a few seconds, it ejects water again for a few seconds and still nothing happens. This cycle repeats itself. I checked the pump - it works.
    Request for help.
    best regards
  • #2 16629917
    jarek225
    Help: 64
    Rate: 221
    Check the solenoid valve on the water supply, it may be burnt and not opening.
  • #3 16629943
    Adam_Heniek
    how to check?
  • #4 16629997
    jarek225
    Help: 64
    Rate: 221
    The first thing you need to do is check what voltage it is controlled by (there should be a description on the solenoid valve).
    Let's assume that the solenoid valve is powered by 230v, so remove the pins and power it from the 230v socket, if it is operational, it should click.
  • #5 16630311
    Adam_Heniek
    The solenoid valve is checked - it is good - that is, it reacts as in the hint. So what? :(
  • #7 16630396
    jarek225
    Help: 64
    Rate: 221
    In this system, you will probably have to replace the programmer.
  • #8 16630413
    Gobro
    Help: 207
    Rate: 503
    Check what will be prompted in the service mode.
  • #9 16630418
    Adam_Heniek
    How to put it into service mode and how to read it? Somewhere, I found information that this clogged filter caused a blockage, and the washing machine may be blocked somehow.
  • #11 16630463
    Adam_Heniek
    I have the impression that this is a description for older models, My washing machine has no markings like in the reference that was indicated, but thank you. I'm still standing still ...
  • #12 16630474
    niewolno2
    Level 40  
    Help: 630
    Rate: 1262
    Check that the solenoid is energized.
  • #13 16630484
    Adam_Heniek
    This is how voltage comes to the solenoid valve.
  • #14 16630506
    jarek225
    Help: 64
    Rate: 221
    If there is voltage to the solenoid valve, and the solenoid valve is functional, the washing machine should draw water at this point. So there is something wrong with the water supply.
The Electrolux EWT 136541W washing machine is experiencing issues with water loading. The user confirmed that the water supply is functional and the solenoid valve's strainer is clean. However, after cleaning a clogged drain filter, the machine still fails to draw water, repeatedly ejecting water without progressing through the wash cycle. Suggestions from the forum include checking the solenoid valve for proper operation and voltage, inspecting the hydrostatic system, and ensuring that the water supply to the solenoid valve is unobstructed. If the solenoid is functional and receiving voltage, the issue may lie with the water supply or the programmer needing replacement. The user also inquired about entering service mode for diagnostics.
TL;DR: If your Electrolux EWT 136541W won’t fill, confirm the inlet valve gets 230 V and listen for a click—“there is something wrong with the water supply” if power and valve are OK. [Elektroda, jarek225, post #16630506] Why it matters: This FAQ shows how to diagnose no-fill, drain-cycling issues fast without replacing good parts; it’s for DIYers and technicians troubleshooting EWT 136541W.
Why won’t my Electrolux EWT 136541W load water?
Start at the inlet valve and supply. If the solenoid receives 230 V and the valve is good, the fault points to water supply restrictions or plumbing to the machine. Check the tap, hose, and any kinks or blockages before suspecting controls. “There is something wrong with the water supply.” [Elektroda, jarek225, post #16630506]
How do I test the inlet solenoid valve safely?
Read the valve’s rating label. If it’s 230 V AC, disconnect the coil, then briefly power it from a safe test lead. A sharp click indicates the plunger moves. If silent or buzzing, replace the valve. Use an RCD and insulated connectors, and never touch live parts. “It should click.” [Elektroda, jarek225, post #16629997]
The washer drains for a few seconds, pauses, then repeats—what does that indicate?
Short, repeated drain cycles with no fill suggest the control is waiting for a valid water‑level signal or water entry. Confirm the pump isn’t stuck on and verify the machine can admit water. Clear the drain filter and recheck fill behavior afterwards. [Elektroda, Adam_Heniek, post #16629862]
How do I confirm the valve is getting power?
Measure AC voltage at the valve coil during the fill stage. Set the program to start, then probe the two coil terminals. Presence of mains voltage means the control is commanding fill; absence points to wiring or control issues. [Elektroda, niewolno2, post #16630474]
What is a hydrostat (pressure switch) and can it block filling?
The hydrostat senses tub water level via an air tube. If stuck in a “full” state or its hose is blocked, the control inhibits filling even with a good valve. Inspect the air hose for clogs, reseat it, and verify switch action with gentle pressure. [Elektroda, jack200, post #16630382]
How do I enter service mode to read errors on this model?
Use the model’s service mode to display stored prompts or codes before replacing parts. The thread advises entering diagnostics and reading what the washer reports; follow Electrolux’s service sequence for your EWT panel layout. [Elektroda, Gobro, post #16630413]
Could a clogged drain filter really stop the washer from filling?
A severely clogged drain filter can disrupt initial cycles and confuse level sensing. Clean the filter completely, reassemble, and retry a standard program. If the symptom persists, continue with inlet, hydrostat, and supply checks. [Elektroda, Adam_Heniek, post #16629862]
The valve clicks and sees 230 V but no water enters—what next?
Verify upstream supply immediately. Open the faucet fully, straighten the inlet hose, and check the wall-side strainer. If the plumbing is restricted, the machine won’t fill despite a healthy valve and command. [Elektroda, jarek225, post #16630506]
3-step how-to: rapid no-fill diagnosis
  1. Read the valve label to confirm it’s a 230 V AC coil.
  2. Command a fill and measure for 230 V at the coil terminals.
  3. Bench-test the coil briefly at 230 V; a clean click confirms actuation. [Elektroda, jarek225, post #16629997]
When should I suspect the control board (programmer)?
If the valve tests good, receives correct voltage intermittently or not at all when commanded, and plumbing is clear, escalate to the programmer. Replace or repair only after ruling out hydrostat and wiring. [Elektroda, jarek225, post #16630396]
What tools do I need to troubleshoot this fault?
Use a true‑RMS multimeter for AC measurements, insulated probes, and a safe mains test lead if bench‑testing the coil. These let you verify the 230 V command and confirm valve action quickly and decisively. [Elektroda, niewolno2, post #16630474]
Is there an edge case where everything tests fine but filling is still slow?
Yes. A bent or partially collapsed inlet hose can allow a click and voltage yet still starve flow. Straighten or replace the hose to restore normal fill rate before suspecting electronics. [Elektroda, jack200, post #16630382]
Does a pump that runs briefly at start mean it’s broken?
Not necessarily. Many programs purge residual water first. In this thread, the pump worked, but filling never followed. Treat the short drain as informational, then verify fill command and supply. [Elektroda, Adam_Heniek, post #16629862]
What’s a safe rule for mains testing on this washer?
Work de‑energized unless measuring. When live testing a 230 V coil, use insulated tools, avoid exposed conductors, and keep one hand clear. “It should click” quickly—if it doesn’t, disconnect and reassess. [Elektroda, jarek225, post #16629997]
My panel labels don’t match older service guides—what then?
Electrolux updated control layouts. If your buttons differ from older guides, still enter diagnostics and read prompts, then map functions by response rather than icon. Prioritize reading what the machine reports. [Elektroda, Adam_Heniek, post #16630463]
I cleaned the inlet strainer—what else should I inspect upstream?
Open the wall tap fully, check the wall-side strainer, and verify building water pressure. A clear machine strainer doesn’t guarantee upstream flow. Address supply issues before replacing internal parts. [Elektroda, jarek225, post #16630506]
