[Solved] Why does the RGB LED strip power supply squeak when changing colors?
jankes93 14079 10
Why does my RGB LED strip power supply squeak when the color or dimming level changes?
The squeaking comes from looseness inside the power supply, not from the LED strip settings themselves; the advice was to check for any looseness between the carcass and the core [#18619040] The original poster confirmed that it was very loose [#18619213] A temporary fix suggested in the thread was to pack it with cardboard so the parts cannot vibrate, though this was explicitly noted as not professional advice [#18619254] In the end, the issue was solved by replacing the power supply with a good one [#19009186] The poster also reported that a second, more powerful unit from the same company behaved the same and later burned out, which points to poor PSU quality rather than insufficient wattage [#19009186]
  • #1 18618908
    jankes93
    Rate: 30
    Hello, I have a problem with a squeaking LED strip power supply. I have a 200w 16.5A power supply, radio controller with remote control. I have a 20mb tape connected, several sections on separate cables. After adding another 3.5mb, the power supply starts beeping. When I set the color to green, blue or red and the brightness is at maximum, the power supply does not beep. In other color and dimming configurations it squeaks. Where is the cause seeker?
  • #2 18618913
    Freddy
    Help: 1394
    Rate: 2818
    Maybe in the design of the power supply?
    Show some clear photos of the interior, because it`s hard to tell.
  • #3 18618948
    jankes93
    Rate: 30
    This is the second power supply, the previous one was 150W, I thought the power supply was too weak. It`s the same on this one.
    Why does the RGB LED strip power supply squeak when changing colors? Why does the RGB LED strip power supply squeak when changing colors? Why does the RGB LED strip power supply squeak when changing colors?
  • #4 18618959
    Freddy
    Help: 1394
    Rate: 2818
    Does it bother you a lot? Such design and workmanship, and it is not damage.
  • #5 18618973
    jankes93
    Rate: 30
    This squeak is a bit annoying, I`ll have to get used to it. At most I will exchange it for another set. Overall I am very dissatisfied with the quality of this. Weak LED light. Maybe you recommend some sets with a controller, preferably RGBW.
  • #6 18619040
    Freddy
    Help: 1394
    Rate: 2818
    Check for any "looseness" between the carcass and the core.
  • #8 18619254
    Freddy
    Help: 1394
    Rate: 2818
    Maybe some cardboard to hold it in place :) although this is not professional advice ;)
  • #9 18619291
    jankes93
    Rate: 30
    Can I glue it with silicone up to 1300 degrees Celsius?
  • #10 18619446
    Freddy
    Help: 1394
    Rate: 2818
    The cardboard is so much better that it is easy to remove if necessary :)
  • #11 19009186
    jankes93
    Rate: 30
    The problem was solved by replacing the power supply with a well one. I bought a second, more powerful one from the same company and it was unchanged. After prolonged use, it burned down.
✨ The discussion revolves around a squeaking issue with a 200W, 16.5A power supply connected to an RGB LED strip. The user reports that the power supply beeps when changing colors, particularly at lower brightness levels, while it remains silent at maximum brightness for certain colors (green, blue, red). Suggestions include examining the power supply's design, checking for loose components, and using makeshift solutions like cardboard to stabilize the unit. The user expresses dissatisfaction with the quality of the LED setup and considers replacing it with a better RGBW controller. Ultimately, the problem was resolved by replacing the power supply with a more reliable unit, although the second one also failed after prolonged use.
