Best Material for Workbench Top (2000x800mm) for Light Home Workshop Use: 18mm Plywood vs OSB
Tom1403862020 19092 12
  • #1 18628196
    Tom1403862020
    Level 4  
    Hello. I am going to make a table (2000 mm x 800 mm) for light work in a small home workshop. I wonder what to use for the table top, I wanted 24mm plywood, but it is much more expensive than, for example, OSB, I thought I could use OSB and thin plywood to make the surface smooth. I would love to see your tables. There will be nothing too heavy on the table, e.g. the box below and some basic tools.
    I have just checked and 18 mm plywood is not so expensive, because PLN 218, would 18 mm be enough for such a table?
  • #2 18628283
    anders11
    Level 30  
    Help: 197
    Rate: 204
    Tom1403862020 wrote:
    would 18mm be enough for such a table?
    It is enough if the table frame is sufficiently stiff and ribbed with crosspieces that support the board
    It's good to put a piece of hard workshop rubber on top, you get a water and oil resistant surface
    as well as resistant to all kinds of scratches and dents, which is very easy to do in the workshop
  • #3 18628296
    bearq
    Help: 414
    Rate: 1605
    I wonder what to use for the countertop, I wanted 24mm plywood, but it is much more expensive than, for example, OSB, I thought I could use OSB and thin plywood to make the surface smooth
    And not better boards?
  • #4 18628369
    Tom1403862020
    Level 4  
    I want smooth surfaces so the boards fall off
  • #5 18628426
    palmus
    Help: 232
    Rate: 744
    OSB and coat it with some epoxy.
  • #6 18629157
  • #7 18629209
    bearq
    Help: 414
    Rate: 1605
    101pawel wrote:
    Buy an MDF board, a kitchen worktop to be exact. In a construction hypermarket they will cut for free.
    If the MDF catches moisture, the next day it will be twice as thick as it left the factory.
  • #8 18629547
    Tom1403862020
    Level 4  
    bearq wrote:
    If the MDF catches the moisture, the next day it will be twice as thick as it left the factory.
    Exactly the MDF board comes off. I thought to buy an osb board and a rubber for it and it will come out at the same price as plywood and in addition I will have a rubber on the table
  • #9 18629919
    andrzej lukaszewicz
    Help: 622
    Rate: 2107
    Ordinary furniture board, laminated on both sides, 18mm or 28.
    I have made a table top from it for 15 years and it is a cheap and durable material.
    In the workshop on the table, I do not do anything with water, so a weak argument. You can always vene the edges or stick them on silicone, e.g. in the table frame.
    I have a CD 28 for pennies, bought as waste, because it was a bit scratched, it falls off the furniture top, and it fits perfectly in the workshop.
  • #10 18630417
    bearq
    Help: 414
    Rate: 1605
    It all depends on what you do in this "workshop" because this plate, after two blows of the hammer, is good as a furnace insert which, of course, is not allowed to burn. In addition, after slight damage, it degrades because it is not concise in itself. It is better to buy OSB, at least after damage it will still be useful for something.
  • #11 18630631
    andrzej lukaszewicz
    Help: 622
    Rate: 2107
    bearq wrote:
    It all depends on what you do in this "workshop" because this CD is after two hammer blows
    It all depends on what hammer (s). I wrote that I have had such a plate for 15 years and nothing is damaged, I use a hammer to tap the anvil on a vice. Laminate is very hard, it is used for kitchen worktops for a reason and can last for many years. Scratches or other minor blemishes are normal on any table top, even steel or sheet-covered.
    In your opinion, the boards will be better on the workbench ??? An idea from 50 years ago, like nothing was there.
    Thick, seasoned boards are expensive, cheap, thin boards will bend, will dry out, full of gaps, require time-consuming assembly with screws or bolts etc.
  • #12 18631087
  • #13 18634583
    buczkog
    Help: 22
    Rate: 33
    MDF or OSB will not swell overnight. If you want to put 2 OSB boards on top of each other (about 48mm) on the so-called gumoleon and you have a locksmith's / workshop table.
    PS
    I have worked in a locksmith for almost 25 years, so I anticipate the posts ... But I know what I am writing.
✨ The discussion revolves around selecting the best material for a workbench top (2000x800mm) suitable for light home workshop use. The user initially considered 24mm plywood but found it too expensive and is now contemplating 18mm plywood or OSB with a smooth plywood surface. Responses suggest that 18mm plywood is adequate if the frame is sturdy, while others recommend using OSB coated with epoxy for durability. Some participants advocate for laminated furniture boards, citing their cost-effectiveness and longevity, while cautioning against MDF due to moisture issues. The consensus leans towards OSB or laminated boards for their resilience and practicality in a workshop setting.
TL;DR: A locksmith with 25 years says "MDF or OSB will not swell overnight"; stacking two OSB sheets (~48 mm) on gumoleon makes a robust workbench top for light home use. [Elektroda, buczkog, post #18634583]
Why it matters: This FAQ guides DIYers building 2000×800 mm light-use benches to choose a smooth, durable, budget-friendly top without overbuilding.
Is 18 mm plywood enough for a 2000×800 mm light-duty bench?
Yes, if the frame is stiff and ribbed with crosspieces. Secure the top to the frame. Add hard workshop rubber for water and oil resistance, plus scratch and dent protection. This setup keeps the thinner panel supported. “It is enough if the table frame is sufficiently stiff and ribbed with crosspieces.” [Elektroda, anders11, post #18628283]
How should I brace the frame under a thin top?
Use crosspieces to rib the frame so the panel is supported. Align ribs perpendicular to the span. Fasten the board along the perimeter and onto each rib. This increases stiffness and load distribution. A braced frame prevents bounce and helps 18 mm tops feel solid. [Elektroda, anders11, post #18628283]
How can I make OSB smooth and finished?
Coat OSB with epoxy. This suggested approach simplifies finishing without adding a second layer. Apply evenly and allow full cure. [Elektroda, palmus, post #18628426]
What surface layer resists water, oils, scratches, and dents?
Lay a sheet of hard workshop rubber on top. You get water and oil resistance. The surface also resists scratches and dents. This protects the board underneath and improves grip. Replace the rubber when worn. [Elektroda, anders11, post #18628283]
Is a kitchen worktop a quick, cheap option for a bench top?
Yes. Buy an MDF-based kitchen worktop and have it cut to size at a big-box store. Many construction hypermarkets cut panels for free. This option is convenient if you need a ready-made surface. [Elektroda, Anonymous, post #18629157]
Will MDF swell if it gets wet in the workshop?
It can. One member warns that if MDF catches moisture, it can swell significantly by the next day. This edge case highlights MDF’s sensitivity to water. Keep MDF away from spills and damp environments to reduce risk. [Elektroda, bearq, post #18629209]
Are laminated furniture boards durable for workshop use?
Yes. A user reports 15 years on a laminated furniture board top, with good durability and low cost. He suggests veneering the edges or setting it into a silicone-sealed frame. This helps protect edges and extend service. [Elektroda, andrzej lukaszewicz, post #18629919]
Are solid wood planks a good idea if I want a smooth surface?
No, for this use they are not ideal. One member calls plank tops an outdated idea. Thick, seasoned boards are expensive. Thin boards can bend, dry out, and leave gaps. Assembly is also time-consuming. Smooth laminates or sheet goods are simpler. [Elektroda, andrzej lukaszewicz, post #18630631]
Will a laminated top survive occasional hammering?
In light work, yes. A user has run such a top for 15 years. He reports no damage from tapping on an anvil in a vise. He adds that laminate is very hard, as in kitchen worktops. Minor scratches are normal on any top. [Elektroda, andrzej lukaszewicz, post #18630631]
Is OSB more forgiving after damage than laminate furniture board?
Yes, according to one member. He argues laminate can degrade after slight damage because it lacks internal cohesion. OSB remains useful even after minor damage. If you expect knocks, OSB is a pragmatic choice. [Elektroda, bearq, post #18630417]
How thick should I go if I expect heavier tasks?
Stack two OSB sheets to reach about 48 mm and place them on gumoleon. This setup makes a sturdy locksmith’s or workshop table. It adds mass and stiffness for impact work. A veteran fabricator recommends this approach. [Elektroda, buczkog, post #18634583]
How do I build a simple light-duty top with a protective surface? (3-step)
  1. Build a stiff, ribbed frame with crosspieces.
  2. Fix an 18 mm panel to the ribs and perimeter.
  3. Add a hard workshop rubber sheet on top. [Elektroda, anders11, post #18628283]
Do MDF or OSB really swell overnight?
No, according to a professional with 25 years. He states MDF or OSB will not swell overnight. This addresses alarmist moisture claims. [Elektroda, buczkog, post #18634583]
