The remote control does not switch NC+ channels. I have to artificially enter the decoder menu.
sekosek23 27102 2
  • Remote needs menu to re-enable channel switching
    #1 19979548
    sekosek23
    Hello, some time ago I changed the decoder to 4K ULTRABOX+ from Cyfra+. Everything worked fine for a few months, recently I can`t change channels normally using the Prog+/- buttons. I.e. I can, but first I have to artificially enter the decoder menu and then go back to artificially call up the channel change bar at the bottom and only then can I change channels with the remote control (Prog+/-). Has anyone encountered such a problem? Is there some strange function/lock enabled?
    The remote control does not switch NC+ channels. I have to artificially enter the decoder menu. The remote control does not switch NC+ channels. I have to artificially enter the decoder menu.
  • #2 19982701
    mischa
    Help: 58
    Rate: 200
    The remote control has no lock. It can only control turning off the TV and adjusting its volume. However, they behave strangely when the batteries run out :) Press the TV button, the red LED will light up. And now press any key. When the diode dims to zero, the batteries need to be replaced. Even though e.g. the volume works.
  • #3 20085205
    vektroda
    Level 4  
    Rate: 15
    Maybe the remote control is so defective that it doesn't work, I had such a case once.
