Garmin venu - File language polski "poland.in4" needed
Atmand34 24075 19
How can I install or enable the Polish language on a Garmin Venu watch?
You can set Polish in Garmin Connect or directly on the watch if the language is already available: in Garmin Connect go to Devices > Venu > General > Language, or on the watch open Settings > System > Language [#18929351] If Polish is not listed, use the Polish language file from the Venu Polish edition and copy it into the watch’s TXT/language folder [#20565434] Several users report that the file only works after deleting one existing language and renaming the Polish file to that language’s filename, for example `french.ln4` or `suomi.ln4`, then selecting that language on the watch [#19140189][#19261146][#19144504] One user also confirmed that the latest language file from the Polish Venu TXT directory works on Venu and even on Vivoactive 4 after renaming it to another supported language name [#20565434][#21129167]
  • #1 18644616
    Atmand34
    I need Polish language files for the Garmin Venu watch
    You have to enter Gramina through the computer -> text -> copy Poland. In4
    Regards
  • #2 18817130
    pati2208
    Rate: 14
    does anyone have a poland.in4 file ?? :) I need a Garmin Venu watch for my watch
  • #3 18865195
    Patinka23
    Rate: 36
    do any of you have this file?
    Regards
  • #4 18889555
    Patinka23
    Rate: 36
    Problem solved. Garmin support helped
  • #5 18892096
    kyngaskrzypiec
    Rate: 8
    Can someone please explain to me how I can change the language from garmin venu to polish?
    By the way, send this file to gaskakinga.96(_at_)gmail.com?
    Thank you for your answer.
    Added after 40 [seconds]:
    Hey, could you please help me change the language as well?
  • #6 18929351
    leon_w
    The language on Venu changes on the Garmin Connect app. Garmin menu / devices, click Venu, select "general" and look for a language there.
    You can also use the watch: you hold the bottom button "you enter the menu", click on the "gear" (settings) / system, the second from the top is the language.
  • #7 19135820
    Lichy666
    Rate: 11
    I have a problem with the Polish language in Garmin Venu. Namely, I would need the polish.in4 file for the above watch. I do not have Polish on the menu, nothing can be done through Garmin Express. Please help.
    Regards
  • #8 19138195
    Titos1910
    Lichy, you already have this file because I'm looking for someone to send?
  • #9 19139974
    zamsz
    If anyone has polish.ln4 file for Garmia, please send me.
  • #10 19140189
    multivac535
    Rate: 15
    Hi
    Download file
    https://www.dropbox.com/s/hby3t6n3ph0kd3w/polish.ln4?dl=0
    I just loaded and it works fine, but I had to remove one of the languages (I chose French) and changed the name of the file with Polish to "French"
    Regards
  • #11 19142899
    Titos1910
    Thanks tomorrow I will test you
  • #12 19144441
    Dani2020
    I downloaded the file, thank you.
    But as after exploring the catalogs on the watch, he adds to the directory with languages, then after disconnecting from the computer, this file disappears and the watch does not see it, after reconnecting to the computer, this file is missing
    I tried to remove another language, e.g. Finnish, and it worked
    Do you have an idea how to save this file permanently?
  • Rename Polish file to a deleted language name
    #13 19144504
    multivac535
    Rate: 15
    Changing the name helped me, if you deleted the Finnish language, change the name to "suomi" in the file "polish"
    Unfortunately, in the watch you will have to choose the "Suomi" language and it will be Polish
    I tried in various ways and only this one I succeeded, i.e. delete one existing file and change the name in Polish to the one that was deleted.
    I emphasize that then you have to use language in nemu, which has been deleted, because its name will remain so.
    I don't know if it can be done otherwise.
  • #14 19259942
    patsi21
    Hello, I have a problem with the language, I do not know how to remove e.g. French and install Polish that I downloaded, please help, best regards
  • #15 19261146
    Lichy666
    Rate: 11
    Hello, I changed the name of the file poland.In4 to french.In4, I changed the file on my watch. Later I chose French on the menu and it worked.
    Regards
  • #16 19261611
    patsi21
    So I have to paste the downloaded file Poland.in4 into the text folder and change it to the name of what you wrote, and jyz is enough and it is enough to disconnect the watch from the computer and search for French on the watch, for example, sorry for such trivial questions but I am green in all of this, greetings and thanks for the time
  • #17 19339103
    ela2021
    for help please. I downloaded the language file and what next? I can't cope.
  • #18 19341518
    alexxx777
    I have vivomove 3s, I had the Polish language file downloaded, I did the same, i.e. replacing the file and name, but when trying to set the language on the watch, the watch jammed. Now only a white triangle (such as the logo) is displayed and the watch is not responding, neither the computer nor the phone can see it. Can anyone solve this problem?
  • #19 20565434
    romblacko1
    Rate: 8
    Upload the latest language file from the TXT directory of VENU from the Polish edition ;-)
    • VENU PL.rar (26.57 KB) You must be logged in to download this attachment.
  • #20 21129167
    LightOfWinter
    Help: 369
    Rate: 935
    romblacko1 wrote:
    Upload the latest language file from the TXT directory with VENU from the Polish edition ;-)
    The above file also works on the VIVOACTIVE 4 model.
    I uploaded by changing the name to "brazilia.ln4" and I have the Polish language :)
    Thanks!
The discussion revolves around obtaining Polish language files for the Garmin Venu smartwatch. Users express the need for the "poland.in4" file to enable Polish language support, with several participants seeking assistance in acquiring or modifying the necessary files. Solutions include changing the names of existing language files on the watch and using the Garmin Connect app to adjust language settings. Some users report success by renaming files and removing other language files, while others encounter issues with the watch becoming unresponsive after modifications. A few users share links to downloadable files and confirm their functionality after renaming. The conversation highlights the challenges and methods involved in customizing language settings on Garmin devices.
TL;DR: 3-step rename adds Polish on Garmin Venu; "Changing the name helped me." Replace a language .ln4 in the Text folder, then select that language. This is for Venu/Vivoactive owners who can't see Polish in menus or Express and need a quick fix. [Elektroda, multivac535, post #19144504]
Why it matters: It lets you enable Polish fast while avoiding common pitfalls like disappearing files or device freezes.
How do I add Polish to my Garmin Venu using the file method?
Use a simple 3-step rename:
  1. Delete one language file you don’t need on the watch.
  2. Load the Polish language file onto the watch.
  3. Rename the Polish file to the deleted language’s filename (e.g., “French”), then select that language. “I just loaded and it works fine.” [Elektroda, multivac535, post #19140189]
Where do I copy the language file on the watch?
Connect the watch to a computer, open its storage, and paste the file into the Text folder. Users mention placing poland.in4 there, then renaming to match a replaced language. Select that language on the watch after disconnecting. [Elektroda, patsi21, post #19261611]
How do I change language via Garmin Connect or on the watch?
You have two options. In Garmin Connect: Menu > Devices > Venu > General > Language. On the watch: hold the bottom button, tap the gear (Settings), go System, then choose Language (second from the top). “The language on Venu changes on the Garmin Connect app.” [Elektroda, leon_w, post #18929351]
The Polish file disappears after unplugging—how do I keep it?
Replace an existing language instead of adding a new filename. For example, delete Finnish, then rename the Polish file to “suomi.” Choose Suomi on the watch; it will show Polish content. “Changing the name helped me.” [Elektroda, multivac535, post #19144504]
Do I need to delete another language to add Polish?
Yes, one user reported success only after removing a language first. They deleted French, then renamed the Polish file to that language’s filename. After selecting French on the watch, the interface displayed Polish. [Elektroda, multivac535, post #19140189]
Can I just rename poland.in4 to french.in4 and choose French?
Yes. One owner changed poland.in4 to french.in4 on the watch. After selecting French in the menu, the interface switched to Polish and worked. This approach avoids the file disappearing issue. [Elektroda, Lichy666, post #19261146]
Will this method work on Vivoactive 4 as well?
One user confirmed it on Vivoactive 4 by renaming the file to “brazilia.ln4.” After selecting that language, the watch displayed Polish. This suggests cross‑model compatibility for the rename approach. [Elektroda, LightOfWinter, post #21129167]
Can these file tweaks brick my watch?
There is a risk. A Vivomove 3s user reported a freeze showing only a white triangle, with no PC or phone detection after a language-file change. If that happens, stop and contact support. [Elektroda, alexxx777, post #19341518]
Garmin Express doesn’t offer Polish—what should I try instead?
Use the Garmin Connect path or the on-watch Settings route to switch language. If Polish still isn’t listed, consider the file-rename method described in other answers. This gives you two official paths before file edits. [Elektroda, leon_w, post #18929351]
If I removed Finnish, what should I name the Polish file?
Rename the Polish file to match the deleted language’s filename. For Finnish, rename it to “suomi.” Then select Suomi on the watch; Polish will display under that slot. This avoids the file being auto-removed. [Elektroda, multivac535, post #19144504]
Who can help if I still can’t get Polish working?
Contact Garmin Support. A user who struggled reported, “Problem solved. Garmin support helped.” They can guide you through official steps or service if needed. [Elektroda, Patinka23, post #18889555]
