Vordon 4.5 Navigation: Connectivity Issues with PC & Updating Map of Poland Lifetime Updates
Xernax321 6420 7
  • #1 16277017
    Xernax321
    I warmly welcome!
    Today I bought the Vordon 4.5 navigation, I would like to update the map of Poland, but unfortunately, after connecting the navigation to the computer via a USB cable, no disk shows up, just nothing.
    He writes that the navigation has a lifetime update, maybe it updates itself?
  • #2 16277224
    2323wojtek
    Help: 29
    Rate: 84
    Write what system you have installed on your computer and a detailed description of the navigation (type, model).
  • Vordon GPS 4.5 not detected over USB for updates
    #3 16277272
    Xernax321
    Windows 10, VORDON GPS 4.5 "CAR NAVIGATION
    from the back of the navigation says:
    4GB 128M
    GPS 4305
    GPS Satellite Navigation
    Output: DC 5V 1.5A-2A
    The box looks like this:
    http://s-trojmiasto.pl/ogloszenia/foto/599800.../1_Nawigacja-Vordon-GPS-4-5-World_900x700.jpg
    I have tried to update from this manual
    https://www.youtube.com/watch?v=7AAlWss8BVY,
    but it does not read the navigation disk, but I have a disk: c, if I connect the navigation with a usb cable to my laptop, there is no reaction. I do not have a memory card inserted in the navigation but it probably does not matter because it has a built-in memory.
  • #5 16277602
    2323wojtek
    Help: 29
    Rate: 84
    "Xernax321 @" - on the video to which you provided the link, the update is loaded on the memory card (Mass Storage), therefore you cannot see the connected navigation, because you do not have a memory card in the navigation. Either you buy it and then do as in the movie or instead of selecting Mass Storage choose Active Sync mode and try then.
  • #6 16277707
    japycz321
    Help: 92
    Rate: 141
    A memory card is not needed. The device memory should be visible like a flash drive. Write what operating mode of the USB device you have selected in the settings. Try on a different cable, other USB ports.
  • #7 16277904
    vaczak
    Help: 50
    Rate: 141
    Hello all
    Xernax321 wrote:
    connecting the navigation to the computer via the USB cable, no disk shows up, just nothing.
    It is important that an operating system with ActiveSync or Mobile Application Center is installed.
  • #8 16315251
    wiesiek_rog
    Rate: 17
    Do you have an original cable? Maybe it's just the cable's fault. Is the navigation running when connected to the computer?
The discussion revolves around connectivity issues with the Vordon 4.5 navigation system when attempting to update the map of Poland. The user reports that their Windows 10 computer does not recognize the device when connected via USB, and they are unable to access the navigation's internal memory. Suggestions include checking the USB operating mode settings, trying different USB cables and ports, and ensuring that the device is powered on during connection. It is noted that the navigation may require a memory card for updates, as indicated in a referenced video tutorial. Additionally, the importance of having ActiveSync or Mobile Application Center installed on the computer is highlighted.
