Hissing Noise from Steel Hose at Cistern: Indication of Water Pressure Issues?
Efcia72 16557 7
  • #1 18674951
    Efcia72
    Rate: 9
    I have a question about the hose at the cistern. Steel hose, installed about 1.5 years ago. For a long time, maybe even from the beginning I can hear some hissing at the hose from time to time. Is this an indication of some water pressure and that something is letting go somewhere? You can't hear it all the time.
  • #2 18674966
    stanislaw1954
    Help: 2013
    Rate: 4673
    Efcia72 wrote:
    For a long time now, maybe even from the beginning, I have been hearing some hissing at the hose from time to time
    When does this happen, is it while the cistern is drawing water, or while the cistern is filled and "waiting" to be used?
  • #3 18674970
    Efcia72
    Rate: 9
    This happens when the cistern is waiting
    stanislaw1954 wrote:
    Efcia72 wrote:
    For a long time now a long time, maybe even from the beginning, you can hear at the hose from time to time some hissing
    When this happens, Is it while the cistern is drawing water, or while the cistern is filled and "waiting " for use?
    Added after 29 [minutes]:
    Efcia72 wrote:
    This happens when the switch is waiting
  • #4 18675325
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    My opinion is that there is a minimal loss of water from the tank, when it "escapes so much water that the valve must "admit" water then and there is a hiss. That is, in my opinion, a slightly leaking drain/flush valve.
  • #5 18675374
    Efcia72
    Rate: 9
    wojtek1234321 wrote:
    My opinion is that there is a minimal loss of water from the tank, when so much water escapes that the valve has to "admit" water then and there is a hiss. So in my opinion a slightly leaking drain/flush valve.
    Thank you very much. I can now hear that it hisses from the cistern side rather than the wall.
  • #6 18675388
    Tommy82
    Help: 455
    Rate: 1074
    There is also the option that the water level is too high and escapes through the overflow and the valve allows.
  • #7 18676293
    wiesiekmisiek
    Help: 259
    Rate: 524
    Unfortunately, there is also the option of the valve locking float getting stuck. Remove the cover and check if the float is well aligned. Often due to the loosening of the nut holding the valve, this device moves losing alignment.
  • #8 18677223
    Tommy82
    Help: 455
    Rate: 1074
    The main thing is to fix it quickly because such a cistern can "make the bill" for water.
    As the valve at the cistern is not 100 years old and just touching it is not risky, turn off the full cistern for the night. If it is empty or incomplete in the morning, too much escapes from it, that is, the automatic drain lets through if it is full, it means that too much is pouring and escapes through the overflow. This means that filling is the culprit.
The discussion revolves around a hissing noise emanating from a steel hose connected to a cistern, which has been present since installation approximately 1.5 years ago. The noise occurs when the cistern is not actively drawing water, suggesting potential water pressure issues. Responses indicate that the hissing may be due to a minor leak in the drain/flush valve, an overflow condition caused by excessive water level, or a stuck float valve. It is advised to monitor the cistern's water level and check the valve alignment to prevent water wastage and potential increased bills.
