Flush Issue: Float Valve in Cistern Not Refilling Water - Valve and Hose Replacement
sjulita 155862 5
  • #1 15518084
    sjulita
    Rate: 20
    Good morning,
    I am asking for advice on what I should do. The float valve in the cistern does not draw water. When I fill it myself and press the flush button, the water runs off, but it does not draw back. I replaced the valve and hose about 2-3 years ago, so I think it shouldn't be a problem. Please help. I will be very grateful.
    Julita
  • #2 15518100
    wacekgacek
    Help: 12
    Rate: 122
    The float has to go up and down. Does it go? After emptying the water, the float falls down, the valve is supposed to open and water flows in if it is and water does not flow in, then the valve may be damaged or clogged.
  • #3 15518110
    sjulita
    Rate: 20
    the valve does not rise. What should I do then?
    PS Thank you very much for your quick reply
  • #4 15518149
    wacekgacek
    Help: 12
    Rate: 122
    It is the float that is supposed to rise while taking the water and fall while pouring the water out, if this is not the case, you need to diagnose why it is not.
  • #5 15518150
    brofran
    Help: 650
    Rate: 1408
    Disassemble and clean the valve, or replace it if it is not dismantled. Usually it gets clogged up with ferns.
  • #6 15518537
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1009
    After unscrewing the hose from the cistern, remove the plastic filter from the valve, which retains all the impurities it has caught from the water, and then clean it in the filter and rinse with water, then put it back in the valve and screw the hose to the flush valve.
