Acer Nitro 5. The system does not detect the hard drive during installation
ozilla 24489 7
  • #1 18679901
    ozilla
    Hello!
    I wanted to install Windows, everything was fine until I had to select the disk on which I wanted to install it, it didn't show any disk, not even a pendrive.
    The disk is an SSD in UEFI, it is visible, but when I enter the BIOS boot tab, I can only choose UEFI SHELL and a pendrive with the System.
    The laptop model is: Acer Nitro 5 AN515-54-51DL
    Any ideas? Is it possible that the hard drive driver is missing?
  • #2 19094123
    krzysior57
    Rate: 11
    Hello, did you figure it out, I have the same problem?
  • #3 19094304
    adamadi33
    Help: 768
    Rate: 251
    During the system installation, when you go to the selection of media installation, press shift + F10, a console will appear, run diskpart, convert the disk to GPT, there are plenty of topics on the Internet.
  • #4 19213563
    pelsk8
    I have a problem that when I open list disk in the command line, my second disk is not displayed. The bios detects it and it is assigned to a volume and a letter
  • #5 19213606
    Kish69
    Rate: 8
    Download the driver from the manufacturer's website: IRST (Intel® Rapid Storage Technology) Driver and install it during the Windows installation.
    The disk should then be visible in the installer.
  • UEFI boot requires GPT FAT32 USB installer
    #6 19214806
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    What kind of SSD drive do you have, please provide the name (full name)
    What Win do you want to bet?
    NVMe PCIe M.2 or SATA3
    Since you have UEFI, try to install Windows 10 (or Win8) using UEFI-boot from a pendrive
    * about other Wins.....forget it.
    Standard (store) flash files are in (MBR)
    so that the USB flash drive always appears in the Boot list - you need... the USB flash drive must be converted to GPT, then formatted to Fat32, and then manually copy the contents of the Windows ISO.
    How to make a GPT USB flash drive
    Spoiler:
    GPT flash drive did so:
    Command Line
    1.
    Diskpart
    listdisk
    sel disk x (the number (X) of the flash drive in the list)
    clean
    convert gpt
    create part primary
    format fs=fat32 quick
    assign
    exit
    exit
    2.
    Unpack the ISO archive in the 7ZIP archiver
    Copy the contents of the Windows 8-10 archive to a GPT flash drive
    The Acer Nitro 5 model series - AN515-31, AN515-41, AN515-51 and others have... a lot of problems
  • #7 20397032
    fiodor23
    Rate: 14
    There is an easier way
    We enter the BIOS, go to the second tab - press ctrl si, enable hidden settings - disable the WMD controller, save the BIOS settings. We turn on the Windows installation and the disk is now visible :)
  • #8 20459167
    sharrim94
    Rate: 9
    Cool! Thanks for the advice. I'd buy you a beer :D
The discussion revolves around an issue with the Acer Nitro 5 AN515-54-51DL where the hard drive is not detected during the Windows installation process. Users suggest several solutions, including using the command prompt to convert the disk to GPT via diskpart, downloading and installing the Intel Rapid Storage Technology (IRST) driver during installation, and ensuring the BIOS settings are correctly configured by disabling the WMD controller. Additionally, users emphasize the importance of using UEFI boot for installation and inquire about the type of SSD being used.
