[Solved] Acer Nitro 5 Laptop: Windows 10 Installation Issue, 512GB SSD/Micron 2200 Not Detected in BIOS
replikat 17349 10
How can I install Windows 10 on an Acer Nitro 5 when the Micron 2200 SSD is visible in BIOS information but no disk appears as an install target?
Install Windows from a newer 64-bit Windows 10 1909 image, make the USB installer in GPT/UEFI mode with Rufus, and boot the laptop from that USB in UEFI mode; that solved the no-disk problem in the thread [#18612363][#18612408] The old 3-year-old Windows image was the likely cause of the drive not showing up during setup [#18612382][#18612408] If you need to obtain the ISO, one reply suggested Windows ISO Downloader as an alternative to the Microsoft download tool [#18612525]
  • #1 18612285
    replikat
    Rate: 11
    Hello, I bought a new Acer Nitro 5 laptop and I can't install Windows on it because it doesn't detect my drive. I would like to add that the laptop was bought without a system and without an HDD, but it has a built-in 512GB SSD, but it does not show it to me in the bios in the boot tab, but if I enter the bios in information, it shows me that a micron 2200 ssd is connected. What to do I have reviewed all the posts Googled it and no one else has encountered this problem. Sorry if this post is in the wrong place, I'm new here.
  • #2 18612347
    madamsz1
    Help: 1057
    Rate: 1711
    Also, specify what media you are installing win10 from and how this media is prepared. Is there UEFI in Bios?
  • #3 18612359
    replikat
    Rate: 11
    Only UEFI has no legacy. with a pendrive because I don't have a cd rom. I will add that I took my disk from an old laptop hdd with win 7 installed and connected it to nitro 5 and it does not detect it for me. and on the old lap everything runs beautifully nicely :)
  • #5 18612382
    replikat
    Rate: 11
    in this video I can do the same, I run the windows installer from a pen, but when I want to choose which partition to install windows on, I have nothing to choose from and a message pops up that there is no disk. I will add that winows is from 3 years ago somehow. Maybe you need to download the latest version because the laptop was bought a few days ago.
    madamsz1
    Help: 1057
    Rate: 1711
    Download a new image 1909 (64bit), make a pen in GPT with Rufus and try to install.
  • #7 18612425
    replikat
    Rate: 11
    another problem arises here because when I want to download the latest win 10 from microsoft, it downloads to my C drive where I don't have space and I don't know how to change it to download to D drive and not to C
  • #9 18612637
    replikat
    Rate: 11
    Thank you gentlemen works hehe you are the masters 3 days I was sitting in front of this problem :D . I have another question, the disk is 512 gb I want to make a 100 gb disk for windows and the rest for me and I have 3 partitions already done: disk 0 partition 1: uefishell type: system, disk 0 unallocated space 468gb, disk 0 partition 2: winddriver. Which can I delete or format?
  • #10 18612658
    safbot1st
    Help: 2719
    Rate: 1585
    Where did you get the partitions from when you formatted the disk with the "clean" command?
  • #11 18612661
    replikat
    Rate: 11
    I did not use any commands, the new downloaded win10 was enough to read the disk to me.
    Added after 15 [minutes]:
    Thanks for your help closing the issue :)
The discussion revolves around an Acer Nitro 5 laptop experiencing issues with Windows 10 installation due to the built-in 512GB Micron 2200 SSD not being detected in the BIOS boot tab. The user initially attempted to install Windows from a USB drive but encountered problems selecting a partition for installation. Suggestions included ensuring the USB drive was prepared in GPT format and using a newer Windows 10 image. The user later resolved the issue by downloading the latest Windows 10 version, which allowed the SSD to be recognized. They also inquired about partitioning the SSD for Windows and personal use, leading to further guidance on managing disk partitions.
