Installation of Win10 Lenovo y520 l - Installation of Windows 10 Lenovo Y520 SAT
reefu 9396 13
How can I make a Lenovo Y520's SSD appear in the Windows 10 installer when the drive is visible in BIOS but not in Setup or Linux tools?
If the SSD is visible only in BIOS and not in the Windows installer or Linux tools, the thread points to a hardware or compatibility problem rather than a missing driver. First try disabling Secure Boot in BIOS [#17075710] If the drive still does not appear in Minitool, Ubuntu, or Windows Setup, the disk is likely faulty and should be handled under warranty [#17075793][#17076164] Also check whether the drive is actually an M.2 SATA model, because the Y520 supports only M.2 PCIe/NVMe in the M.2 slot, not M.2 SATA [#17189791]
  • #1 17075657
    reefu
    Hello, hello and hello!
    Today I received a Lenovo Legion y520... FreeOS laptop with a SATA SSD :( Micron 1100 (MTFDDAK256TBN).
    The disk is visible in bios, but not during installation of windows 10 ...
    USB image recorded with Rufus (GBT for UEFI).
    The rest of the BIOS settings:
    Installation of Win10 Lenovo y520 l - Installation of Windows 10 Lenovo Y520 SAT Installation of Win10 Lenovo y520 l - Installation of Windows 10 Lenovo Y520 SAT Installation of Win10 Lenovo y520 l - Installation of Windows 10 Lenovo Y520 SAT
    During installation it looks like this:
    I can't find any extra rudders disk drivers.
    Diskpart does nothing.
    Help, thanks in advance for your answer!
  • #2 17075710
    Krzychu7
    Level 40  
    Help: 695
    Rate: 530
    Disable the option in the BIOS Secure Boot
  • #3 17075733
    kranzio
    Help: 91
    Rate: 139
    If that doesn't work, check the disk on another computer.
  • #4 17075753
    reefu
    I disabled Secure Boot, still the same. I can't take the drive out because they sealed the case.
    I have now launched some Minitool 9.1 from USB, it does not see the disk at all, only a bootable flash drive.
  • #5 17075793
    kranzio
    Help: 91
    Rate: 139
    It comes out that the disk is damaged.
  • #6 17075804
    reefu
    Only in Bios it detects it. The question is whether you need any additional drivers or are they actually dead ..
  • #7 17075816
    RADU23
    Help: 2428
    Rate: 1732
    reefu wrote:
    However, the drive in Bios visible during the installation of Windows 10 does not ...
    Have you checked if this image flash drive works on another computer?
    Try installing a different OS (lower version).
  • #8 17075827
    kranzio
    Help: 91
    Rate: 139
    From what you can see in the photos, the system also detects the disk, but it does not see its capacity. I used to have a similar problem with ssd. Bios saw it, and during installation the system couldn't format it.
  • #9 17075841
    reefu
    at the moment I put ubuntu on a flash drive, see if it sees the disk .. if it sees it, I will do GBT and if not, I send it to the complaint ... The question is how everything will work under Linux and still not under Windows ..?
    RADU23 I have 3 pendrives with Windows 7, 8.1, 10 and each works on a different computer ... but not on this one ..
  • #10 17075868
    RADU23
    Help: 2428
    Rate: 1732
    Start by setting the correct date in the BIOS.
    One more thing. The disk is visible but has no allocated space.
    Essential question. Is there any partition on it at all?
  • #11 17075903
    reefu
    There is no partition because the disk is visible only in the bios. Until now, no program can see the disk, including the windows 10 installer, in which I always created partitions, then I continued installing the system ... suck ubuntu live, run on linux.
    Linux doesn't see the drive at all. To sum up, the disc is visible only in the bios. Bootable programs like minitool, ubuntu, gparted and many others see only the pendrive it boots from. Any other ideas? Is shipping under warranty?
  • #12 17076164
    kranzio
    Help: 91
    Rate: 139
    Shipping under warranty. If there was no seal, you could check on another computer. Try to restore the BIOS defaults again.
  • #13 17076184
    reefu
    I fired it on Windows Life with some kind and here it can be seen but it will not be able to initialize the disk ..
    I think I've exhausted my options.
  • #14 17189791
    jbmar
    What is the disk format? M.2 or 2.5 "?
    For Y520, only M.2 PCIe / NVMe disk can be supported in M.2 interface, while M.2 Sata is not supported.
    You probably solved the problem already, but it may be useful for posterity ...
The discussion revolves around the installation of Windows 10 on a Lenovo Legion Y520 laptop equipped with a Micron 1100 SATA SSD. The SSD is recognized in the BIOS but not during the Windows installation process. Users suggest disabling Secure Boot, checking the SSD on another computer, and verifying the disk's format. The author reports that various tools, including Minitool and Ubuntu, fail to detect the SSD, indicating potential disk damage. Further troubleshooting includes checking BIOS settings, ensuring the correct date is set, and considering warranty service due to the SSD's limited visibility. The conversation highlights the compatibility issues with M.2 SATA drives on the Y520 model.
TL;DR: On a Lenovo Legion Y520, 3 USB installers were tested — "each works on a different computer" — yet the SSD wasn’t detected by Windows setup, pointing away from media issues and toward hardware/compatibility. [Elektroda, reefu, post #17075841] Why it matters: This FAQ helps Y520 owners fix "Windows 10 can't see my SSD" fast and decide when to send it for warranty.
Why does Windows 10 not see the SSD even though BIOS does on a Y520?
That pattern often indicates a faulty SSD. In the thread, a helper concluded the drive was damaged. When BIOS lists a disk but installers and tools can’t, suspect hardware. Swap testing is ideal, but the sealed chassis limits that. Proceed to warranty if software checks fail. [Elektroda, kranzio, post #17075793]
Does the Legion Y520 M.2 slot support SATA (M.2 SATA) drives?
No. The Y520’s M.2 interface supports PCIe/NVMe, not M.2 SATA. As one expert put it, “only M.2 PCIe / NVMe disk can be supported in M.2 interface, while M.2 Sata is not supported.” Use an NVMe drive in M.2 or a 2.5-inch SATA SSD in the bay. [Elektroda, jbmar, post #17189791]
Should I disable Secure Boot before installing Windows 10 on my Y520?
Yes. Disable Secure Boot in BIOS when the installer can’t see your storage. It can block boot loaders or media chains. Reboot after changing the setting and retry the install. Restore BIOS defaults later if needed. [Elektroda, Krzychu7, post #17075710]
How do I check that my USB installer isn’t the problem?
Try this quick validation:
  1. Boot the same USB on another computer.
  2. Try a different OS installer to compare behavior.
  3. If both work elsewhere, the media is fine; investigate the laptop or drive. These steps rule out a bad image or stick. [Elektroda, RADU23, post #17075816]
Linux Live USB also can’t see the SSD—what does that indicate?
If Ubuntu/GParted see only the USB stick and not the SSD, while BIOS lists the disk, software isn’t the culprit. That cross-check points toward drive failure or platform incompatibility. At that stage, prioritize warranty support. [Elektroda, reefu, post #17075903]
Disk Management shows the drive but can’t initialize it—what next?
When Windows PE or Disk Management detects a device but won’t initialize it, your software options are likely exhausted. Document screenshots and error text. Keep BIOS changes minimal and recorded. Then engage vendor warranty for replacement or service. [Elektroda, reefu, post #17076184]
Can DiskPart fix an SSD that setup can’t find?
No. DiskPart can’t act on a disk the OS does not enumerate. In the case discussed, “Diskpart does nothing.” Focus on firmware settings, media validation, and hardware evaluation instead. [Elektroda, reefu, post #17075657]
What interface speed should I expect from the 2.5-inch SATA bay?
Typical 2.5-inch bays use SATA III. The link rate is 6.0 Gb/s, which is about 600 MB/s theoretical throughput. Real-world SSD speeds are lower due to protocol overhead. This is adequate for a Micron 1100-class SATA drive. [SATA-IO, 2009]
Was this problem caused by missing Windows 10 storage drivers?
In this thread, responders attributed the failure to the disk itself, not drivers. Windows 10 normally handles SATA AHCI without extra drivers. Focus troubleshooting on hardware health and slot compatibility first. [Elektroda, kranzio, post #17075793]
Could an incorrect BIOS date or empty partition table be the reason?
Set the correct BIOS date first. An invalid date can interfere with installer trust. Next, check if any partition exists once the drive is visible. If no space is allocated, create partitions during setup. [Elektroda, RADU23, post #17075868]
When should I reset BIOS to defaults or send the laptop for warranty?
Reset BIOS to factory defaults once, then retest detection. If the SSD still fails across installers, follow the advice: “Shipping under warranty.” Do not break a factory seal to avoid voiding service. [Elektroda, kranzio, post #17076164]
Does the Y520 accept a 2.5-inch Micron 1100 (MTFDDAK256TBN) SATA SSD?
Yes, via the 2.5-inch SATA bay. In this case, BIOS detected the Micron 1100 SATA SSD, confirming the SATA path exists. The issue was OS-level detection, not BIOS presence. [Elektroda, reefu, post #17075657]
My Y520 is sealed. How can I test without opening it?
Use Live USB tools like Ubuntu or MiniTool from a flash drive. If they list only the USB and not the SSD, collect screenshots and proceed with warranty. Avoid breaking the seal. [Elektroda, reefu, post #17075753]
Should I try Windows 7/8.1/10 installers to debug the issue?
Yes, for validation. The OP tested three installers and noted “each works on a different computer.” That rules out bad media. If your Y520 still fails, focus on hardware or compatibility. [Elektroda, reefu, post #17075841]
What’s the best storage upgrade path for a Legion Y520?
Use an NVMe SSD in the M.2 slot for performance. Avoid M.2 SATA there, as it won’t be recognized. For SATA drives, use the 2.5-inch bay. This avoids detection pitfalls. [Elektroda, jbmar, post #17189791]
Could Intel RST/RAID mode hide the drive during Windows setup?
Yes. If the controller is set to RAID/RST, Windows setup may need the Intel RST driver. Load it during install, or switch to AHCI in BIOS if supported. Back up first before changing modes. [Intel, 2020]
