Yoke Holding Injection Tightening Torque for Citroen c4 II b7 1.6 hdi 92KM
cichy koksik 52629 17
What is the tightening torque for the injector retaining yoke on a Citroën C4 II B7 1.6 HDi 92 KM?
The injector retaining yoke is tightened in two stages: 7 Nm, then 80° [#18697122][#18697232][#20449530] One reply also says the retaining bolts should be replaced rather than reused [#18697268]
  • #1 18696651
    cichy koksik
    Rate: 84
    Hi
    Does anyone have access to the service center to check the tightening torque of the yoke holding the injection?
  • #2 18696732
    madamsz1
    Help: 1057
    Rate: 1711
    In Ford, this engine has 4Nm +65° - 1.6 tdci PSA
  • #3 18696747
    cichy koksik
    Rate: 84
    I just read about tdci engines, but I don't believe that there is so little in my engine because it is now tightened at ~ 27Nm and somewhere on the forum I found such info, but I would prefer to be 100% sure.
    I will add that the injection system is Bosch.
  • #4 18696765
    madamsz1
    Help: 1057
    Rate: 1711
    With Siemens injections, Ford gives 7Nm and 85°. How in HD? I don't know. 27 is probably too much.
    Lemon gives:
    Injector mounting flange nut:
    Pre-tightening 0.5 ± 0.1 daNm
    Angular tightening 65° ± 5°
    WloczykijMalaMi
    Help: 15
    Rate: 140
    Stage 1 7Nm
    Stage 2 80°
    Regards, WIM
  • #6 18697139
    cichy koksik
    Rate: 84
    @madamsz1
    @WloczykijMalaMi
    But gentlemen, there is no nut there, only an ordinary screw and it seems to me that this moment given by you is wrong.
  • #7 18697187
    WloczykijMalaMi
    Help: 15
    Rate: 140
  • #8 18697196
    cichy koksik
    Rate: 84
    If this is from my car, I'm very surprised, but also a little bit disbelieving :)
  • #9 18697205
    WloczykijMalaMi
    Help: 15
    Rate: 140
    I compared in four different places, including information from Citroen with what I found on the Internet. The last option is a purchase for information on the manufacturer's website or from a person who makes Lemons every day. I won't help any more :)
    Regards, WIM
  • #10 18697216
    cichy koksik
    Rate: 84
    Well, the problem is that "I fix it myself" materials are not available for free for this car.
    What's more, in c4 II, the entire injection system is slightly changed, there are other lugs and other mountings.
    Anyway, thank you for your help :)
    On the other hand, if someone tightened the injections and it should be as you write, nothing but cry.
    madamsz1
    Help: 1057
    Rate: 1711
    Everyone gives so much for this engine, I think Citroen would not screw the screw at 27Nm - probably a bit too much, and there is a long and quite thin screw
  • #12 18697232
    cichy koksik
    Rate: 84
    Okay gentlemen.
    You were right - 7Nm +80°
    The data comes from a citroen service from a kind college from another forum.
    I'm looking at it now and I don't believe it :)
    But someone smart must have screwed it up :(
    And so now I will rummage with the injections, so new washers and sealing will go.
    Do you think the bolts should be replaced too?
  • #13 18697263
    madamsz1
    Help: 1057
    Rate: 1711
    How they were so dragged for sure :)
  • #14 18697268
    WloczykijMalaMi
    Help: 15
    Rate: 140
    Screws are a must, don't even think about it.... :D
    Regards, WIM
  • #15 18697269
    cichy koksik
    Rate: 84
    How about the paws?
    If they're durable enough, they're probably indestructible :)
  • #16 18697273
    WloczykijMalaMi
    Help: 15
    Rate: 140
    I will write this if you are to have trouble from the client later and you see that, as you wrote, "someone turned the wrong way", then there is only one answer.
    Regards, WIM
  • #17 18697294
    cichy koksik
    Rate: 84
    I am the customer :)
    In general, I pull out the injections anyway (me or the mechanic because I don't have a key with such a low scale) to check / regenerate, so I would like to do everything right, but I don't want to buy something that is not necessary.
    I will pay for the recovery itself :)
    Maybe I will visually assess the condition of these paws because buying replacements may not be a good idea.
  • #18 20449530
    mariuszgawor
    maybe late for the answer, I did so 7nt 80 degrees and it's ok, the first time I turned by feel the broken paw holding the injection and not immediately, only after some time, I only realized how the inside smelled of exhaust fumes
The discussion revolves around the tightening torque specifications for the yoke holding the injection system in a Citroen C4 II B7 with a 1.6 HDi engine. Users share various torque values, with a consensus emerging around 7Nm plus an additional 80° angle for proper tightening. There is some confusion regarding the correct specifications, as one user initially reported a torque of approximately 27Nm, which was deemed excessive. The conversation highlights the importance of using correct torque settings to avoid damage, and users recommend replacing screws and checking the condition of the mounting components during maintenance. The injection system is identified as Bosch, and there are references to different torque specifications for similar engines, including those from Ford.
TL;DR: Citroën C4 II 1.6 HDi injector clamp bolt: 7 Nm + 80°. "Stage 1 7Nm, Stage 2 80°." This FAQ helps DIYers and techs set hold‑down torque fast and correctly. [Elektroda, WloczykijMalaMi, post #18697122]
Why it matters: Correct torque prevents leaks, misfires, and cracked injector clamps on PSA 1.6 HDi engines.
What is the correct tightening torque for the injector clamp bolt on a Citroën C4 II B7 1.6 HDi 92KM?
Use torque‑angle: 7 Nm, then tighten a further 80 degrees. This figure was confirmed from Citroën service information. As one member summarized: "You were right - 7Nm +80°." Apply it to the injector hold‑down clamp bolt. [Elektroda, cichy koksik, post #18697232]
Is 27 Nm acceptable for the injector clamp?
No. 27 Nm is excessive for this long, thin clamp screw and risks damage. As noted by a contributor, "27 is probably too much," given the fastener’s design. Re‑set using the 7 Nm + 80° method instead of a high static torque. [Elektroda, madamsz1, post #18697230]
Do I have to replace the clamp bolts after removal or over‑tightening?
Yes—replace the clamp bolts. They are treated as single‑use in practice after removal or any over‑torque. As one expert put it: "Screws are a must, don't even think about it...." New bolts help ensure reliable clamping at the specified torque‑angle. [Elektroda, WloczykijMalaMi, post #18697268]
Can I reuse the injector clamp (“paw”), or does it need replacement?
Inspect the clamp carefully. If it was over‑tightened or shows any crack or distortion, replace it. A user who tightened “by feel” later found the clamp had broken and noticed exhaust smell inside the car. That failure mode indicates the clamp was compromised. [Elektroda, mariuszgawor, post #20449530]
Is the fastener a screw or a nut on the C4 II injector clamp?
On the C4 II described, the injector is held by a clamp with a screw, not a nut. The torque‑angle spec still applies to this clamp bolt configuration. Always identify your exact hardware before tightening. [Elektroda, cichy koksik, post #18697139]
I found 4 Nm + 65° for Ford 1.6 TDCi—does that apply to my Citroën?
That 4 Nm + 65° figure appears in Ford’s PSA 1.6 TDCi context. It does not automatically apply to your Citroën. Always follow the specification for your vehicle and hardware. "In Ford, this engine has 4Nm +65° - 1.6 tdci PSA." [Elektroda, madamsz1, post #18696732]
I saw 0.5 ± 0.1 daNm + 65° in some Citroën docs—when is that used?
That value is listed for an injector mounting flange nut configuration in Citroën documentation. If your setup uses a flange nut, this may apply. Quote: "Injector mounting flange nut: Pre‑tightening 0.5 ± 0.1 daNm; Angular tightening 65° ± 5°." [Elektroda, madamsz1, post #18696765]
How do I correctly torque the injector clamp—what’s the step‑by‑step?
  1. Pre‑tighten the clamp bolt to 7 Nm.
  2. Using an angle gauge or marked reference, rotate the bolt a further 80°.
  3. Stop at 80°. Do not add extra torque beyond the angle step. These two tightening stages set the correct clamping load. [Elektroda, WloczykijMalaMi, post #18697122]
Can I tighten the clamp by feel without a torque wrench?
Do not tighten by feel. One user did so and the clamp later broke, with exhaust odor entering the cabin. After redoing it at "7nt 80 degrees," the setup was fine. Use the torque‑angle method to avoid clamp damage and leaks. [Elektroda, mariuszgawor, post #20449530]
Do I need a low‑range torque wrench for this job?
Yes. The required tightening level is low, so a torque wrench with a low scale is necessary. The original poster noted they lacked a wrench calibrated that low, which complicates accurate tightening. Use a suitable low‑range tool for reliability. [Elektroda, cichy koksik, post #18697294]
How can I verify torque data if I can’t access free manuals?
Cross‑check multiple reputable sources, then obtain official data. As one member advises: "The last option is a purchase for information on the manufacturer's website or from a person who makes Lemons every day." Professional confirmation reduces risk. [Elektroda, WloczykijMalaMi, post #18697205]
Which exact engine/trim does this FAQ address?
This thread and guidance target the Citroën C4 II B7 with the 1.6 HDi 92KM engine variant. Confirm your VIN and hardware before applying any figures. [Elektroda, cichy koksik, post #18696651]
What injection system was referenced on the car in this thread?
The car discussed uses a Bosch injection system, as stated by the original poster. This context supports the clamp bolt torque guidance here. [Elektroda, cichy koksik, post #18696747]
Should I replace injector sealing washers when refitting the injectors?
Yes, replace the sealing washers when you remove and refit injectors. The original poster planned new washers and seals during injector work, which aligns with good sealing practice to prevent combustion leaks. [Elektroda, cichy koksik, post #18697232]
